Results 1 to 40 of 72
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    DIY: Fix broken glove box hinge
    The right side hinge on my glove box door broke and I didn't want to pay $300 to replace the entire glove box, so I did a few searches and found an AZ member who sells hinge repair kits... His name is Fritz and he goes by PCYC. I figured "what the hell" and ordered one.
    Fritz made the bracket and I received it just a few days later. It's a quality part, made of really strong steel. The screw holes were counter sunk, he included the screws and the whole thing was painted matt black.
    I followed the included instructions and managed to remove the two hinge pins that held the glove box door, and removed the door. Here's a shot of my broken hinge:
    The bracket Fritz provided fit the curves of the hinge perfectly. I spent some time making sure it was lined up properly, drilled four 1/16" pilot holes for the screws, and installed the bracket. I also put a liberal amount of crazy glue on the break, but it really wasn't necessary.
    While I had the door off I removed the piston that is connected to the door. Just unclip the wiring harness, and twist the piston around until knob that connects it to the glove box lines up just right and it will pop off. I tried to move the piston in and out and had to really use a lot of force, clearly this was the reason that the hinge broke in the first place. I considered leaving it disconnected, but if I did that the light wouldn't work. So, I drilled a small hole in the end of the piston, and dribbled some oil in there. After I worked the piston back and forth a few times it started moving easily. The hole isn't very big, I used the same 1/16" bit, so there is still some negative pressure that slows the piston's movement a bit.
    Here's where I drilled the hole:
    And here's the piston attached back to the glove box, it just needs to be rotated back around so the back of the part (with the hole) is pointing toward the front of the car:
    When I reinstalled the glove box door I found that the hinge bracket was rubbing against the part of the glove box that surrounded it, so I used my dremel to sand just a tiny bit off the front of the surround to make it a bit bigger. I didn't take any pics of that, but it will be obvious where you need to sand if you run into the same problem. Problem solved, so I reinstalled the pins holding the door to the glove box, connected the piston and the wiring harness, and that was it.
    I can't say enough about the quality of the part that Fritz makes, it was well worth the $25. The bracket is practically invisible from inside the car, you have to be looking for it to even see it, and the repair makes it just like the glove box door was never broken. If you have a broken hinge on your glove box this is the way to go, just pm PCYC and he will set you up.
    Dave
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Re: Fixed broken glove box hinge - writeup w/pics
    Nice write up Dave. I'm sure it will be helpful to quite a lot of people.
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    ^What he said^
    I'LL BE BACK.........
    Never forget SWAY
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Would you mind crossposting this or letting me crosspost it in the B7 A4 section? There's a lot of guys over there who could really use this info, myself included.
    + rep
    Mar 15 2008
    TX
    Quote Originally Posted by 12sA4 View Post
    Hi, go right ahead, I don't mind at all.
    Dave
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Same method I used, there is a DIY on here about making the bracket yourself.
    Mar 15 2008
    TX
    Quote Originally Posted by beemercer View Post
    Yeah, I know, but I didn't have an appropriate piece of metal on hand nor do I have the right tool to cut it into the proper shape so buying the completed bracket seemed like the way to go. $25 shipped was a cheap price to pay to get my glove box back in service, and the install was involved enough that I was still able to get a pretty good "diy high" out of the deal.
    Jul 30 2009
    Nashville
    I have a 2005 A4 with this exact problem. Audi dealership wants $427 to replace glove box door. Please let me know how to order hinge repair part from Fritz. Thanks
    Senior Member Two Rings S4Sumi's Avatar
    Jan 22 2008
    Black B7 S4, gsxr 600
    San Jose, CA
    Mine just broke last weekend..Thanks for sharing!!
    Mar 15 2008
    TX
    Quote Originally Posted by Dougsville View Post
    Just go to your profile and click on "send new message" in the Private Messages section on the left side of the screen. Enter his username (PCYC) in the recipient box, type your message and click "send."
    Dave
    Jul 30 2009
    Nashville
    Thanks dave, just sent request to Fritz.
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Nice I didn't know this product existed, looks a little rough but sure beats 300$. Thanks for sharing with the class, bookmarked for when mine breaks.
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Nice write up dave. i am sorry i havent seen this yet. for anyone wondering I still make these, just Pm for details.
    hope this helps everyone
    Jul 10 2008
    Austin, TX
    Just fixed mine with your kit. Cant thank you enough!! I was about 12 hours away from my appt with the dealer to get it replaced ($435) when I saw this thread.
    The hardest part was getting those damn pins out. Nothing some needle-nose pliers and a hammer can't fix though.
    Thanks again!
    Active Member One Ring RAudiS4's Avatar
    Dec 05 2004
    Cardiff by the Sea
    Thanks, Dave and Fritz. The first time around I paid the dealer to replace it. Now seeing that this is a common problem I will use this remedy should I experience a repeat break. The other common hinge that breaks is in the armrest. I guess that there are probably some forum notes on this somewhere, too.
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    i had the same problem with my glove box, broken hinge. i've read a few threads here and saw somebody got his fixed by dealership at no cost. so i took my car in, they looked at it and they ordered some part they said. they called me when got the part and had it installed. i was surprised to see that the actual part was the hole glove box and the nice part it was no cost, the car still being under the factory warranty. i tought this would be helpfull for some of u guys. they cannot really say it's tear and wear, when they made a bad piston. i think they should have recall for that problem. so give it a try and go there showing that u know the problem.
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I must have missed this the first time around. Great writeup, Ive seen this before on several peoples cars at car meets. Now Ill have a link to send them
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    How the hell did you get the 2 pins out that hold the box in. I tried to grab them with a visegrip but they dont move!
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Good timing. Mine broke last week.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Mar 15 2008
    TX
    Quote Originally Posted by brad65ford View Post
    You just have to have patience and keep at it, the first time you remove those pins it's a real pita. One of the pins on my glove compartment seemed like it just wasn't going to come out, I messed with it for more than an hour. I finally got it by putting the vice grips on it, then moving the vice grips back and forth while tapping on the vice grips with a hammer to move the pin out.
    May 30 2005
    fl
    wow I spent 15 mins tring to get them to move and I got no where I'll keep tring. I would be so much easier to work on with the door out.
    Mar 15 2008
    TX
    It's probably easier if you take the glove compartment out of the car first, I would have done that if I knew what a pain it would be to get the pins out.
    Jul 10 2008
    Austin, TX
    I took the glovebox out, grabbed the pins with a pair of needle-nose pliers, queezed REALLY HARD with one hand, and used a hammer with my other hand to hit the pliers until the pins came out.
    May 30 2005
    fl
    Man how the hell designs these stupid things. So stupid
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    now do one on 'my glove box was too stiff, so I fixed it'
    my glovebox was nightmarishly stiff from new. I read a couple of threads and found last week that there is a TSB and the dealer will fix the 'too stiff' piston that causes the problem. Called the dealer, and told them...service guy came out to check the car and when I click the latch, WHAMMO...no longer stiff. Works perfectly.
    So strange. Anyway, mine is cured. No idea how.
    Sep 08 2008
    Tucson/Portland
    I have the broken glovebox problem and disassembled the piston and am working on removing the two hinge pins under the glovebox to remove the door and they will not budge. has anybody else had this problem? ive tried almost everything and no matter how hard i pull they will not come out. can anyone help with this?
    Mar 15 2008
    TX
    Quote Originally Posted by JKells05 View Post
    Clip the vice grips on the pin, then move them back and forth while tapping on the vice grips with a hammer to back the pin out of the hinge. It's a major pain but the pin will come out, you just need to keep at it.
    Sep 08 2008
    Tucson/Portland
    yeah these pins will not budge a bit ive tried just pulling them, twisting them, pretty much everything and im not getting any movement out of them. any other ideas?
    Sep 08 2008
    Tucson/Portland
    i actually got them out about 10 minutes after that post haha. that was a bitch, vice grips and leverage are a must
    Mar 15 2008
    TX
    Glad you got it to work!
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    just got back from the dealership and they wanted $330 for this, lol
    pm incoming PCYC!
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    Mar 12 2007
    Boston
    So weird..... the lower right hinge on my glovebox snapped this morning. Look like I will be referring to this thread in the near future.
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Junior Member One Ring
    Nov 21 2009
    FL
    oh man, i think the plastic housing around my pin is going to crack before i get this pin out. I can already see a crack forming. I've almost chewed the head off completely using vice grips.. Mine is not budging AT ALL.. It's not even moved 1mm.
    I'm thinking about drilling a hole from the outside, so i can bang it out.. It seems the other side has a hole so you can bang it out.
    Aug 03 2004
    Wilsonville, OR
    I was having a hell of a time, but a small pair of vice grips worked. Just twisted it a bit back and forth and both pins came out. Weird that vice grips arent working for you.
    I had to do a little bending and what not to get the hinge to fit, and dremeled part of the glovebox surrond, but it ended up working.
    Also had to drill a hole in the piston head and oil it a little bit, because that thing was not moving back and forth at all.
    '07 rs4
    '91 spec miata
    Nov 21 2009
    FL
    Thanks, I finally managed to get the pins out... On one side, there's a hole so i managed to punch it down with using a hole punch and hammer.. On the other side, being that there was no hole, i had no choice but to drill one.. Using vice grips was not working for me.. I even dremmelled out some of the surroundings to get a better grip. None of which worked. I even nearly broke my nose tip pliers and vice grips from over use of my hammer.. Mine were not coming out.. So this is for those who have the same problem.. Drill a hole and punch it out... Yes i have a small hole now, but it's very low down and you'd never notice it unless you were looking..
    As for the rest of the job, i'd say it's fairly complicated.. I had trouble lining it all up.. The part never really was a snug fit and it took some playing around and in the end i had to re-install it a two or three times to get it all lined up...
    But it's in now.. i hope it holds with the new bracket? Time will tell...
    Sep 07 2007
    Atlanta GA
    the pins DO suck. I am still in business, as long as its not to much troble I will keep helping everyone out.
    THanks Guys
    Fritz
    Feb 20 2009
    central coast, california.
    Just ordered a fix it kit from Fritz.
    2 S4's 3 broken glove boxes. The first 2 were under warrantee. In spite fo carbon fiber trim curling off, broken glove boxes, leaky valve covers, and some disappearing oil, this S4 is still my most favorite car to drive in my 40+ years of owning a lot of different rides. Really.
    Sep 07 2007
    Atlanta GA
    thanks everyone!
    Wanna Fix your Glove box?
    i make brackets to fix your Broken Glove box. PM for Pricing!
    DIY/Info
    Established Member Two Rings SpiderBy's Avatar
    Mar 20 2009
    2008 BMW 535i Manual
    I am yet another happy customer.
    Got the bracket this week and got the glove box fixed yesterday.
    Thank you Fritz!
    Sep 17 2009
    2004 S4
    San Francisco
    i canNOT for the love of god remove the passenger side pin. I used vicegrips and even dremeled around the pin to gain clearance for a better grip but to no avail. the door is off because i got the other pin out, but i need to remove the last pin to get to the hinge. any other tips?
