Originally Posted by
B5A4Kevin
if the lighter does not stay down by itself, the retaining tabs are out of adjustment. remove the fuse as previously stated (to avoid shocking the shiz out of yourself) and use something like a butter knife or pick or screwdriver (flat head from the trunk kit works fine), and bend both of the tabs slightly inward.
Kevin,
I am at work presently so can't inspect the socket or the lighter, but I do know the lighter has slit(s) in the side of the part that is inserted, and in these slots there are tabs that serves as a guide to ensure that the moving part slides straight down.
Don't know what tabs are in the socket.
What tabs, therefore, are you saying that has to be bent slightly inward -- ones on the socket or ones on the lighter. Sounds like the ones on the socket ...?
