Results 1 to 23 of 23
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    Service intervals for B6/7 A4-S4.
    Well I took the time this morning to add this to the The Audizine Wiki: B6/B7 S4/RS4 Platform since "sway" requested it. My manual says nothing about after 95,000 miles, but there is a pattern through out the mileage intervals. This is just for the 04-08 A4/S4. I left out the stuff for other Audi's that was in there.
    http://www.audizine.com/forum/showthread.php?t=278805
    Dec 08 2008
    Re: Service intervals for B6/7 A4-S4.
    Service at 5,000 miles (8,000 km) or 6 months after delivery, whichever occurs first.
    Engine oil/filter
    Service reminder indicator display- reset
    Check the following:
    windshield wiper and washer/ headlight washer- add fluid if necessary
    tire and spare wheel- check for wear and damage. Rotate tires. Check tire pressure.
    Road test- Check braking, kick down, steering, electrical, HVAC system, automatic shift lock,
    and power accessories.
    Every 2 years regardless of mileage/kilometers:
    Cloth top:
    Check function and roll-over protection with cloth top down.
    (Audi A4/S4 cabriolet only)
    Service at 15,000 miles (25,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Engine-check for leaks
    Engine-OBD, check fault memory
    Service reminder indicator, reset
    Dust and pollen filter-replace
    Check the following for leaks/damage/ add if necessary:
    cooling system
    exhaust system
    battery
    AT and final drive
    MT and final drive
    Tires/spare wheel
    Brake system
    Doors- Lubricate hinge mechanisms
    Sliding roof
    Lights
    Drive shafts
    Front axle- Check dust seals on ball joints and tie rod ends, check tie rods
    Snow screen for air cleaner- Cab only
    Replace brake fluid( every 2 years regardless of mileage.)
    Cloth top:
    Service at 25,000 miles (40,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Service reminder, reset
    Cloth top:
    Service at 35,000 miles (55,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    cooling system
    exhaust system
    battery
    AT and final drive
    MT and final drive
    Tires/spare wheel
    Brake system
    Continuously variable transmission (Multitronic) Change ATF
    Sliding roof
    Lights
    Drive shafts
    Power steering fluid
    Cloth top:
    Service at 45,000 miles (70,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Cloth top:
    Dec 08 2008
    Service at 55,000 miles (85,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Spark plugs- replace
    Air cleaner- replace
    cooling system
    exhaust system
    battery
    AT and final drive
    MT and final drive
    Tires/spare wheel
    Brake system
    Sliding roof
    Lights
    Drive shafts
    Cloth top:
    Service at 65,000 miles (100,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Cloth top:
    Service at 75,000 miles (115,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    cooling system
    exhaust system
    battery
    AT and final drive
    MT and final drive
    Tires/spare wheel
    Brake system
    Sliding roof
    Lights
    Drive shafts
    Cloth top:
    Service at 85,000 miles (130,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    Cloth top:
    Service at 95,000 miles (145,000 km) or 1 year after last service, whichever occurs first.
    Engine oil/filter
    cooling system
    exhaust system
    battery
    AT and final drive
    MT and final drive
    Tires/spare wheel
    Brake system
    Sliding roof
    Lights
    Drive shafts
    Cloth top:
    Very good information to have... Subscribed.
    Jul 23 2009
    Newport News, VA
    what about the timing belt and water pump for the 1.8t. the dealership in va beach told me its due with the 75,000 mile service
    2004 A4 1.8t Quattro Black USP
    Dec 08 2008
    Quote Originally Posted by mchupe View Post
    They are right. It says to replace the timing belt on a 1.8T at 75,000 miles but nothing about the water pump. I always replace the water pump when doing the timing belt on my other cars, same with the tensioner (sp?).
    Dec 08 2008
    Edited so the service intervals are in Bold.
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    DO IT AT 60k! Its cheap insurance, my 1.8 stripped 8 teeth at 64k, ended up costing me more than 4 gs!
    Dec 08 2008
    That sucks, maintain your car!
    Mar 01 2004
    Northern NJ
    The dealer told me a month before " Nah theyre good til 90, dont worry about it"
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Quote Originally Posted by Audi0s View Post
    The likelihood that your is not stock and thus you may have in its life stressed you engine a little more than stock. They can tell you it is good until a 100k but if it goes next week it's going to be your bill. You may want to consider that.
    Mar 01 2004
    Northern NJ
    This was years ago, I fixed it myself, and later recieved a check from AUdi for almost the full amount from a class action lawsuit.
    What should I be considering?
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Should all these services be covered under the CPO warranty. I'm asking because mine is a CPO and when I had the 55k service they charged me like $400 and there were still things to do they said.
    thanks
    Jul 26 2009
    DMV Area
    thanks
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Quote Originally Posted by shiro1745 View Post
    thanks
    It seems they vary from dealer to dealer.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Feb 04 2013
    United Kingdom
    This is fantastic information but my Audi A4 (2004) B6 2.0 Diesel has just hit 115,000 miles and telling me I need a service. What would you suggest I do at 115,000 miles?
    Reading the list, I'm guessing these parts will cover it:
    Engine oil
    Engine oil filter
    Spark plugs
    Replacement air cleaner
    Battery
    Replacement windshield wipers
    Lubricate for door hinge mechanisms
    Lights kit (fog and breaks need replacing)
    Brake fluid
    I don't think the brake fluid has ever been changed, the windscreen wipers either (they don't work very well, heh), and the door hinges make a creaking sound.
    Anything else I'm missing?
    I replaced the timing belt on the car at 75,000 miles - I'm surprised the schedule above doesn't list the timing belt?
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by rgaufman View Post
    Engine oil
    Engine oil filter
    Spark plugs
    Battery
    Brake fluid
    This is the S4 forum -- totally different service schedule than yours.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Feb 04 2013
    United Kingdom
    Quote Originally Posted by dparm View Post
    The title of this thread says: "Service intervals for B6/7 A4-S4."
    Am I missing something?
    Apr 24 2009
    Frisco, TX
    The diesel A4 was never sold in North America, and it has different intervals.
    Your dealer should be able to give you the service items you need.
    Suggest you ask in the A4 forum:
    http://www.audizine.com/forum/forumdisplay.php/4-B6-A4
    Apr 10 2013
    Penticton BC Canda
    Not seeing anything about changing tranny fluid? Assuming it doesnt need to be as regular as engine oil but also dont want to waste money, any tips?
    Nov 30 2008
    05 S4, 02 A4
    Raleigh, NC
    Quote Originally Posted by darrengrutzy View Post
    Holy necro bump. Are you talking about the automatic transmission fluid? If so...here are some things...
    http://www.audizine.com/forum/showth...-Results-B7-S4
    http://www.audizine.com/forum/showth...mission-Fluids
    Kool-aid red B6 S4 Avant. JHM NAWZZZ kit, JHM headers, FI cat-back, JHM tune, JHM IM, LWCP, LW rotors.
    Apr 10 2013
    Penticton BC Canda
    Quote Originally Posted by WolfS4 View Post
    Im looking for the 6mt intervals. Searched a little longer but couldnt seem to find a conclusive answer and didnt see it done in the service intervals
    Apr 24 2009
    Frisco, TX
    IIRC it's either lifetime or 95k, which is way too long. I suggest a 50k interval for the trans and rear diff.
