Results 1 to 10 of 10
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    For those with Forge 007 DV..
    came in the mail the other day and noticed it has 3 springs (one in the DV, a blue one, and a yellow one). i put it on the way it came and it is LOUD much like a blow off valve.
    Is there a specific spring im supposed to use and whats the difference between the 3??
    thanks guys
    Established Member Two Rings SlipAngle's Avatar
    Jul 17 2008
    08' A4 S-Line 2.0T 6spd
    Boston
    Re: For those with Forge 007 DV..
    Here's some info. You shouldn't really hear it at all, maybe a bit if you have an intake.
    http://www.speedlifemotorsport.com/fodivafarocl.html
    Comes with two extra springs (yellow and blue, green is installed) so you can tune it to your boost application.
    Valve Spring color coding
    Green - 5-15 PSI
    Yellow - 15-23 PSI
    Blue - 23-30 PSI
    Red - 30 + PSI
    Aug 25 2008
    rhode island
    yes have an open intake so id expect some noise.
    Aug 25 2008
    rhode island
    okay so if you have a green spring in the dv can you only boost up to 15psi. how does that work?
    i bought the car chipped and with the forge dv already on the car and opened up to see it has the green spring inside...i know it should be spiking higher than 15....should i get my hands on a yellow spring??
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    if you are chipped, i believe you should ahve the yellow spring in there.. that is what i have heard most chipped guys use.
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Dec 05 2007
    The green spring will make the boost curve surge when running more psi than what it is rated for. I am not sure if the spring is what is holding you back at 15psi.
    You have a choice with adjusting the springs. You can add shims or decide to change the spring alotgether. For example, you can add to shims and have the green spring in vs just having the yellow spring in. The shims come with the spring kit.
    Edit: Why does your first post say you have the 3 springs, while post number 3 says you bought the car with a chip and 007 dv?
    Aug 25 2008
    rhode island
    thanks for the info guys. ordered a spring kit for $25 comes with all the springs and shims so ill see what the difference will make. i know i have a slight boost leak coming from the valve cover/intake mani area but its very faint and just cant put my finger on where the leak is coming from.
    Nov 01 2006
    Nor Cal
    the leak is probablt under the IM. they are the big ones that crack/ break and are a PITA to change...
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    Quote Originally Posted by wesleyfbm View Post
    Preventive maintenance. I would get on that.
    Put Werk Here
    [/SIZE]
    Aug 25 2008
    rhode island
    its none of the vacuum lines under the IM. i deleted most and plugged them up real good and did leak test after. i plan on new gaskets and perhaps new injector seats sometime this year when i figure out if ill be polishing or poweder coating the VC and IM. so hopefully that ish gets fixed in the process.
