Results 1 to 10 of 10
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Hand polishing a scratch and window cleaning streaks
    I noticed a tiny scratch on my car the other day, not very deep. Likely from the dealer when they cleaned my car after I brought it in for some stuff to get installed. I detailed the car today and yes I'm new to this. It came out looking quite nice but the scratch is still there. I used Adams machine polish (I don't think that's the right polish for the job, is it?) on the scratch but just used a hand pad and worked it around with little result. It looks a bit better but in no way is it gone. Any suggestions? I have a feeling I will eventually be getting this when I need to order more supplies
    http://www.detailersdomain.com/index...ROD&ProdID=432
    but for now I am just going by hand. Am I looking at a problem a hand can't solve?
    Next question,
    I was cleaning my windows, used a brand new microfiber towel, and Adams glass cleaner. I can't get my windows to look clean. I see all sorts of bubbles and smears when I wipe the window down. I assume it has something to do with that clear protection crap the dealer installs before sale and since the car has less than 1000 miles on it I assume that stuff is making it hard on me. However, I know there is a way to get the windows clean seeing as the dealer managed to do it when they washed it a week ago. Any suggestions to get around this problem? I had a little more luck when I mixed the cleaner with some water but I still see some little streaks
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Registered Member Two Rings
    Jun 18 2008
    Davis and San Francisco, CA
    Re: Hand polishing a scratch and window cleaning streaks
    Hand polishing doesn't really do a lot. Think of it this way, a machine polishes at probably 100-1800 RPM depending on the machine for several minutes. That's much more elbow grease than your joint would like to handle. If you are serious about it, the Porter Cable you linked wouldn't be a bad idea.
    As for the glass, I'd say use the side of the microfiber that isn't as fluffy. If that doesn't work, I'd go grab some glass microfiber towels. The ones you get from walmart, target, autozone, etc are only good for a few times then they start to streak.
    May 16 2008
    WA
    I am by no means a detail expert, but when my brother got a scratch on his acura after a dropped screwdriver slid down his fender, i used meguiars' swirl remover polishing/rubbing compound with a towel and a little elbow grease going in circular motions over the area. After a little bit of rubbing i wiped everything down and buffed the surface with a clean dry section of the towel to get all the remaining residue off and any remaining swirl marks. By then the scratch disappeared. I put a little wax on the area for good measure, and now its impossible to tell it was ever there. And the whole process took maybe 7 minutes
    I used this same process to get some light scratches off my trunk lid that wax alone wouldnt cover up
    again i am just stating what worked for me and not saying this is the right or wrong way to do it
    Established Member Two Rings htfan's Avatar
    Jun 19 2009
    2006 A4 Quattro 2.0T
    OC, CA
    Quote Originally Posted by getslideways View Post
    Appreciate this info. Just picked up some Swirl-X. I hoping will remove some light scratch marks I've recently noticed.
    "Try not to become a man of success, but rather become a man of value." - Albert Einstein
    Jul 11 2007
    Chicago
    Invisible Glass Cleaner - FTW
    Old "Casa - 01 S4 - Homebrew Stage X - K03/16 - FMIC - Autospeed Motor Mounts/Tranny Mounts/DTS - Stern Power Ring/Rear Differential Poly - XS Power Exhaust - JHM Shifter/Solid Link/Delrin/3rd Detent/Homebrew Shifter Knobbie weight - Homebrew SMOC -"
    New "07 Infiniti Black Sedan G35s 6MT"
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    If you are doing this by hand, the Adam's fine machine polish is not the right product for you. It is not aggressive enough for hand application, and you cannot properly break it down by hand. As others have said, get something that is designed to be used by hand and you will get better results. good luck
    oh and btw, on the outer glass, Adam's detail spray is awesome! It contains shine enhancers and if done properly (in the shade) will not leave streaks.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    Aren't you in ST:A on PBN?
    As far as the scratch, all hand polishing will do is hide it. If you want gone, you'll have to get it machine polished.
    Glass, try using window towels. I have window towels from Detailers Domain, and they leave 0 streaks.
    Dec 10 2008
    Chicago
    Quote Originally Posted by Alan View Post
    yes... I am
    I've wised up for the polishing. I plan on ordering this in the near future:
    http://www.detailersdomain.com/theub...es16ozkit.aspx
    As for the windows, the problem was the crap the dealer had sprayed onto the windows. No longer do I get streaks.... I think just giving the car a few washes took care of it.
    Jan 22 2007
    Pittsburgh, PA
    Cool, i hate windows, glad they turned out good for ya.
    As far as the PC goes, it's a good machine, I've had mine for 3 years. It will correct light scratches, just keep in mind that it can only do so much as a random orbital. For heavier scratches, you might need to have it buffed with a rotary
    Dec 10 2008
    Chicago
    At the moment, I don't have any deep scratches so I plan on just using the PC for my "details." I know I'm bound to eventually get a deep scratch and in that case, I wouldn't trust myself to do the job. That's where the professionals come in haha
    I'm not at home at the moment either so it gets tough to do a good detail but I try to keep my car as clean as possible . My roommates think I'm nuts...I disagree.
    A few pics from a couple of weeks ago after a wash/wax to keep safe for winter:
