Results 1 to 40 of 46
    Jul 26 2009
    Connecticut
    Why does my A4 2.0 sound like a TDI?
    i just bought a 2007 A4 2.0 w/ 28k. I like the albeit a smaller car than I am used to driving ( Lexus) I noticed that the car is loud at idle. It alomst sounds like a diesel. I checked the oil and it is perfect. I was told by the dealer ([North Bay Imports in Connecticut) that the car had an oil change and was checked out by the service guy. Is it normal for the 2.0T to sound this way? I am used to no noise at all from the Lexus.
    BTW, I like this forum. I am new to the German engineering world.
    Thanx!!
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Why does my A4 2.0 sound like a TDI?
    You might have a blown coilpack
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Apr 18 2009
    boston
    Quote Originally Posted by tireguy112 View Post
    Thanx!!
    yes. its normal. 2.0t can sound like a diesel
    Established Member Two Rings nikothegman2003's Avatar
    Jan 24 2008
    '03 A4 3.0Q, '01 TT-Q cab. '86 Me/Be 300SDL
    Bronx, Westchester, New York
    yea, normal, unless its really loudd, its a little four cyl, and i've noticed those are a little louder, i have the 3.2 so....
    Senior Member Two Rings jalas's Avatar
    Apr 17 2009
    Sold! - 07 RS4 Misano Red
    Austin, TX - Ya'll
    That is what the 2.0TFSI motor sounds like. Normal for this motor. Keep in mind the car will burn through oil.
    Good luck with the car.
    DUH! an Audi
    los angeles, CA
    sadly it is normal.
    Jul 26 2009
    Connecticut
    Thanks for the quick responses, The Lexus forum guys would have taken 3 days to respond!
    Nov 05 2007
    Auburn, AL
    The Gasoline Direct Injection (GDI aka FSI in Audi speak) is what makes this sound. This is the sound of efficiency and torque!
    Honestly, you are probably hearing the high-pressure fuel pump and high-pressure injector solenoids firing. Including the pump, that's 5 decently loud solenoids operating at one time. Here's a video 7 FSI injectors firing under low-pressure (100 psi) on a test stand at APR. http://www.goapr.com/media/videos/D6...7307F32D3229B/
    Your A4 is running at 725 PSI (50 bar) at idle and 1595 PSI (110 bar) under full load. Modern common-rail diesels can run up to approx. 20,000 PSI depending on the system type. The system in your Audi can't touch the diesels for pressure but the pressure and the rail pump and injector combo contribute to the noise. Just know that this noise is contributing to the responsiveness and efficiency that you have come to love in your A4.
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    i just bought a 2007 A4 2.0 w/ 28k. I like the albeit a smaller car than I am used to driving ( Lexus) ... Is it normal for the 2.0T to sound this way? I am used to no noise at all from the Lexus.
    The FSI engine in the B7 is known for its coarseness. They improved the engine in the B8, but in no way is it close to Lexus for smoothness and lack of noise. Just don;'t drive / idle next to walls.
    It is also not close to the Lexus in reliability or even fit and finish.
    That said, the Lexus is probably no comparison for driving experience -- performance, handling, etc.
    They both have their strengths. Welcome to the world of Audi. Hope you have a good experience.
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    ticka ticka ticka ticka
    Oh and I want one of those Machines Mike. I think I would make some rock music with it:)
    Veteran Member Three Rings maka's Avatar
    May 01 2009
    2006 Audi A4 2.0T Q Auto
    West Vancouver Canada
    Quote Originally Posted by Mike@APR View Post
    that was AWESOME
    Senior Member Three Rings killerb7's Avatar
    Apr 27 2009
    05.5 A4 2.0T 6MT
    Orange County, CA
    hahaha, the "why does my audi sound like a diesel?" posts never get old
    Nice!
    Senior Member Two Rings sl2.oturbo's Avatar
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    i love that noise ass engine i feel like its working hahahahaha
    2008 2.0t s-line Ti
    Dubbin' Daily
    Apr 27 2009
    05.5 A4 2.0T 6MT
    Orange County, CA
    hahahaha
    thats the noise i look forward to every morning when i warm up the b7.
    tick tick tick tick tick
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    lol i do love it tho man same here i do look forward to it !!
    2008 2.0t s-line Ti
    Dubbin' Daily
    Nov 12 2007
    Grand Junction, CO
    Audi may have installed the wrong engine in your car.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Yeah, they might of accidentally put a Volkswagen TDi engine under your hood.
    Nah, just kidding -- it's normal for 2.0 FSI to sound like that, just don't fill'er up with Diesel though; I recommend 'Super Unleaded'.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Registered Member Two Rings A4 2.0T FSI's Avatar
    Feb 22 2009
    A4 B7 2.0 TDI SE Saloon
    UK
    I have a 2.0 TDI and I have test driven a 2.0 TFSI... honestly, the reason why I did not go for the FSI was the stupid noise it makes: Diesel sound for a Petrol engine.
    The Common rail system which helps you go up in the MPG set up in these FSI engine also helps the noise go up in dB.
    So finally I opted out and took a 2.0 TDI which has sufficient punch at low rev and has a dreamy 55 mpg on average.
    Voila.
    Phantom Black A4 B7 2.0 TDI SE Saloon !
    Mar 18 2009
    2005.5 B7 A4
    West Chester, PA
    I came from a WRX with full bolt ons and turbo swap, so the a4 seems really quiet to me...but mine does have the noise at idle also.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    lexus fit and finish?? not really last i checked anyway audi interior is much nicer without all the random buttons and parts dropped from a camry. lol
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by a4dc89 View Post
    I understand, but fit and finish is a separate issue from design.
    One could design a beautiful interior but if it is put together poorly, using cheap material then that is no good. Lexus has been known as the standard for this aspect, not necessarily design innovation.
    Glove boxes that keep falling off and armrests that keep breaking do nothing to bolster Audi's claim with regard to fit and finish, innovative design notwithstanding.
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    Audi is second to none on fit and finish you moron. Put together poorly with cheap material? HA!
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Quote Originally Posted by wayneB7 View Post
    Fit and finish is how the interior fits together and how polished it looks. Audi beats Lexus and Acura hands down. Infiniti comes a close second.
    Now, the quality of said pieces used in the fit and finish is another story. Still, I've yet to have any of my interior break.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Jul 22 2009
    NoVA
    I was shopping for a A4 2.0T recently, some are MUCH louder than others. I drove an 05 with 28k that really did sound as loud as my 96 Passat TDI. It had been sitting on the dealer lot for 5+ months... no wonder no one wanted it! My 06 was probably the quietest of the bunch that I drove.
    Senior Member Two Rings A42S4's Avatar
    Apr 09 2008
    BFE
    that VID is fun to watch! Thanks for posting :)
    2012 Phantom Black A5 | Premium Plus| St Pkg | Nav | B&O | Carbon Inlays | Adv Key | APR tuned | 20% tint
    Gone: 06 A4 ÜberS-Line/APR tuned/10% tint/19' BBS CK/HID Fogs 6K/Vag-Com/STaSIS exhaust/RS4 sway/Carbonio Intake/LED -licenseplate mod/CIM vent gauge/StopTech Stage II
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    So me and buddy were arguing this last week i said Audi has the best interior so he looked into it. Sadly we finish third.... after BMW and lexus but obvy we are bias, we own these cars and i personally which this is an opinion that our int. is nicer.....then he hit me with this slap in the face...."So you kno I'm at my internship surfing the web so I decide to google top rated car interiors. What pops up none other than this "Top 10: Best car interior 35k-45k"... I would just like to share with you that your beloved slow audi car company did make the list only after BMW, Cadillac, Mercedes, and Lexus. Oh and btw it was the A5 with the navi package that made #5 But don't worry your a4 made the 25-35k list at #3 again after Bmw and Lexus. (Only cuz cadilac and benz are too expensive)."..lol he kills me then he said he would buy an S5 but have to spend all his money re doing the interior lmfao !!
    2008 2.0t s-line Ti
    Dubbin' Daily
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by /\G View Post
    Hey you little shithead, did I speak to you?! Did I call you a name?
    State your point and rebut my statement if you will, but leave personal attacks elsewhere, okay.
    Good to see how some people feel powerful hiding behind a behind a keyboard.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by Charles View Post
    I too have yet to have any of my interior break, but there are quite a few on AZ who have.
    As for the fit and finish ratings -- many will have different opinions of course. I am not doubting that Audi interiors are award winning for their design, but I already many my point I think.
    Also, from the various reviews I have seen over the years in the car mags, they tend to also regard the Lexus interiors in high regard -- above Audi from what I can tell.
    Does it really make a difference ... to me no. I don't have a Lexus, and never did.
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    wayne b7 i like you ...we should be friends lol
    2008 2.0t s-line Ti
    Dubbin' Daily
    Nov 12 2007
    Grand Junction, CO
    Cadillac, really? My Grandparents have a Caddi and it looks exactly like a piece of shit Saab on the inside.
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    i hear some hate perhaps you have not been in a caddie lately inside straight from a benzzzz-ooooo
    2008 2.0t s-line Ti
    Dubbin' Daily
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    doesn't look like a saab in the slightest nice try tho
    2008 2.0t s-line Ti
    Dubbin' Daily
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    ^^The new 09 CTS interior is nice. They have ambient lighting behind all of the trim pieces...Looks really good.
    The only Lexus that I know of that got good interior reviews was the new IS 250/350. This was seen as a break through for Lexus who was previously known for relatively low-end interior materials. Infiniti is definitely not known for their interiors either. Lots of hard plastics and monotone orange gauges. Without sounding like one of the fanbois, the germans have consistently been top of the class in this regard, but other brands are starting to step it up. The Caddie above for instance.
    Justin
    DTM S4 Sprint Blue
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    That interior looks like shitttt
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    i got my car from north bay imports...whod u deal with over there?
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    The screen stickin 3 feet outta the dash is stupid but the rest looks pretty nice, but you really can't tell from a picture.
    -Ian
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by Vorsprung View Post
    Hehehe ... I agree. They are trying and have made great improvements. They are now in the 21st century .... finally. Maybe a little bankruptcy is good, after all. Gets the bosses to learn to listen to the people.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by sl2.oturbo View Post
    Hey I am all for being friends with everyone ... as long as they show respect and debate points and not hurl insults. We all have different POVs and all are equally valid. I just wished that approach was more frequently enforced here. More lurkers might actually post!
    I like your gutsy post above, daring to state that maybe, just maybe there is some evidence that there are some reviews which support the opinion that Lexus and a few other marques might be ahead of Audi as far as interiors go.
    At the end of the day it is a preference thing and it really doesn't matter a goddamn which one is better, as long as it is better to the person driving it.
    Jul 10 2009
    A4 2.0T S-line
    East Brunswick
    agreed sir ^^ well put
    2008 2.0t s-line Ti
    Dubbin' Daily
    Apr 03 2009
    c block
    good thing this thread was brought back up because i've been worring about the same thing for the past week since i got my 06
