Results 1 to 38 of 38
    Senior Member Two Rings 561audia4's Avatar
    Feb 02 2006
    2014 BMW M6 GranCoupe, 2010 VW GTI DSG Autobahn edition
    Ocala
    Oil soaked coil pack???
    The code read a misfire on cylinder 2 and when I pulled the coil pack it was soaked in oil....what could be causing this? how can I fix it? Thanks in advance
    Carl-
    CURRENT 2014 BMW M6 GranCoupe | Competition Pkg | IND Cosmetic Pkg | Ceramic Coating | Hardwired Passport Escort 9500xi |
    SOLD 2009 A5 3.2 Quattro
    SOLD: 2002 B6 1.8T Quattro
    Apr 12 2009
    Re: Oil soaked coil pack???
    Valve cover gasket leaking or plug threads leaking, that's only two sources where oil can come from as far as I know. Was it the entire pack or just the shaft? If its the entire pack, you have have more issues than just the pack.
    Feb 02 2006
    Ocala
    It was the entire shaft....I dont understand when you ask if it was the entire coil pack....Would it be an expensive deal to fix?
    Carl-
    Mar 04 2009
    00 Audi S4, 1989 Bronco
    Medford, Oregon
    X2 valve cover gasket. Just throw a new one asap and your good to go. Under $100 fix.
    Established Member Two Rings AUDIchad's Avatar
    Nov 01 2008
    2008 A4 2.0T 6MT Q
    Middle TN
    Probably a valve cover gasket. I noticed some oil around one of my spark plugs and I noticed the gasket was leaking when I took a closer look. If it's leaking enough it could get to the coilppack.
    I recently took my car to the dealership for an oil change and they found some oil leaking from another seal (crankshaft-maybe). They told me there is a pump that vents pressure from inside and if this pump goes out, pressure builds and will start to blow out these seals or gaskets. They replaced this pump, the crankshaft seal and the valve cover gasket. It was expensive (of coarse), but I didn't have time to fool with trying to do it myself.
    Not very technical- I know, but maybe it's something you can check into...
    Feb 02 2006
    Ocala
    Quote Originally Posted by geralddh15 View Post
    Yeah im mechanically handicapped......How many hours am i looking at for labor so I dont get ripped off....
    Carl-
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Its mad easy ! If you need help let me know I can help you out
    Feb 02 2006
    Ocala
    Quote Originally Posted by HeymyA4 View Post
    i sent you a PM
    Carl-
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Valve cover gasket it is.
    IT will take you no more than 1 hour to strip all the hardware off your valve cover (tubes, lines, screws, bolts), replace the gasket, clean up the valve cover (inside), and install everything back where it was.
    Please please please, double check the bently manual for torque specs. You do not want to overtighten the valvecover. It is extremely easy to over crank it, and end up with a bigger leak.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Apr 12 2009
    Quote Originally Posted by 561audia4 View Post
    Sorry it was a bad joke, when I said it was covered in oil the joke was if the top of pack was covered then you have oil all over the top of your motor which is a bad situation. Like everyone else is saying its the valve cover gasket and easy fix.
    Cheers
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by A4 Moda View Post
    GL
    Actually, as long as you get a valve cover gasket that has metal torque limiting inserts it's pretty hard to mess it up. Just snug it down on the inserts and the rubber will automatically be compressed the correct amount. Easy peasy.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jun 11 2005
    Thank you.
    I did not know this.
    Any link to purchase these items? Is it a VW/Audi specific item?
    2003 1.8T
    Dec 28 2006
    Western Maryland
    I picked up one from Autozone. Don't recall the manufacturer but it was written in German. They didn't have a listing for an '03 A4 so i just asked for an '03 Passat. The gasket had metal inserts around each mounting bolt hole. Once you snug up to the inserts the rubber is at the correct compression. If you crank down harder you will not compress the gasket any further. You will only strip out the bolts. I think you will find that most of the decent valve cover gaskets use the inserts. I would not consider installing one without them.
    Jun 11 2005
    Thank you.
    I used my "break your bank, sell your kid" snap-on ditigal torque wrench for only a measely $400
    This information is going in my little golden b6 book for next time.
    2003 1.8T
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    to the op, if you are looking to just fix it and not worry about it for a long time. its really only about a 30 min job. If you have down time don't need the car, you can look into cleaning up your engine bay..
    [img][/img]
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Veteran Member Three Rings dino's Avatar
    May 24 2004
    2003 Audi A4 1.8T 5MTQ, 2015 Audi Q7 Sline 3.0TQ
    Recently happened to me. Here are a few pics when I replaced my valve cover gasket.
    http://www.audizine.com/forum/showthread.php?t=288270
    ~> dino
    2003 A4 1.8T 5MTQ - Brilliant Black on Ebony
    | Bose | Cold | Premium | Sport | Xenon |
    | Visor | A4 Rubber Mats | Tint | Aero Kit | Ross-Tech KEY-USB | V1 | Podi | Euro Knob |
    | APR K04/Snub | GFB Hybrid | TT225 Injectors | AMS SS | RaceTec FMIC | Hayden PSC |
    | B5 S4 Front Brakes | Hawk HPS | ECS Lines | Motul RBF 600 | RS4 RSB | PSI TP |
    Items for Sale
    Active Member Two Rings clm6113's Avatar
    Sep 03 2009
    GSX-R 1000
    Manama, Bahrain
    I recently had loss of power above 15psi. I suspected a loose vacuum/FMIC hose. The second time it happened I noticed the CEL flashing. Quick forum check lead to coil pack as the most likely source. VAG produced two notes - multi cylinder misfire and number 2 cylinder misfire. Upon extracting the #1 coil pack (and damaging a brittle clip) I found what seemed to be an incredible amount of oil around the coil pack shaft. Same with # two. Any chance the coil packs are still good and the presence of oil is the issue causing the misfires? Just wondering if I should order more coil packs when I order the gasket kit. Thanks.
    Chris
    '02 A4 1.8TQ : Stage 2+ : 034 HFC : APR cat back exhaust : AWE FMIC
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Burbs of Chicago
    Order the packs, always good to have spares. And it can be the oil, I had a head gasket leak that was soaking my plugs/packs in oil causing misfires. Coilpacks were still good afterwards.
    1.9L GT3071r 517 trans
    Mods: Eurodyne Maestro 7 / Stasis Alcon 355mm Mono6 / 034 Billet Fuel Pump 005 / Neuspeed snub mount / RS4 rear sway / Custom Magnaflow 14581 exhaust / INA adapters with FSI coilpacks / Thor Skidplate / CF S4 blades / DTH CF Roof Spoiler / RD led lp / Smoked sidemarkers / 3k HID fogs / 35% tint / Symphony II+
    Oct 02 2006
    Wadsworth,OH
    Victor Reinz gaskets are GREAT! I just installed one about a month ago. For the price you cant beat it!
    Click HERE to order or for more information.
    Let me know if you have any other questions.
    Jason
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    If your going to replace your valve cover gasket you might as well change your cam tensioner gasket too since it will involve the same process in equipment removal.
    Jun 27 2011
    +1 on the victor Reinz. Replaced mine a few months back and it worked great.
    OP don't believe everyone when they say its easy. It SHOULD be easy, but the advanced age of our cars makes the plastic parts attached to the PCV VERY brittle and prone to snapping when you remove them. I found out the hard way. What should have been a quick 1 hour Gasket replacement turned into a few days of hunting down PCV parts and jerry rigging a heater hose for the shitty plastic PCV breather.
    Now if you're fine with the possibility of more work like that, by all means do it. Its very simple! But if the idea of something else breaking scares you or you can't afford a few days downtime take it to a shot. It should be no more than an hours labor and the gasket is like $20.
    Edit: Also +1 on the cam tensioner gasket as NuVega said. You're already in there, so just replace both!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 12 2008
    South Central PA
    lol have either of you ever replaced the cam tensioner gasket? to do it right, you have to remove the cams and that involves removing the timing belt. which to do that correctly you have to pull the lock carrier forward. lol it's a lot more involved than the valve cover gasket
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 27 2011
    Really?
    Now I haven't done it myself so you may be right, but I was under the impression that it was as easy as the DIY above assuming you have the Cam Chain Tensioner locking tool.
    Edit: linked to the original DIY as the stickied DIY has broken pics.
    -CP
    2017 Q7 3.0t
    Sep 12 2008
    South Central PA
    I said to "do it right", because usually there is gasket material left on the surfaces that need scrapped off to make a good seal. otherwise it'll start leaking again in no time. I've changed like 7 of them dude lol I know all about the process of doing it properly
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jun 27 2011
    Quote Originally Posted by Dan[FN]5857 View Post
    Didn't think about leftover material, but yea that's no good. Sounds like doing it right (which I'm all for) then is a much more involved process as you say. Good to know, thanks Dan.
    -CP
    2017 Q7 3.0t
    Senior Member Three Rings andrew.k's Avatar
    Sep 08 2011
    Pickering ON
    Thumbs up
    VCG
    Sep 03 2009
    GSX-R 1000
    Manama, Bahrain
    Thanks for the info. I ordered the gasket kit above (literally shipped 8 minutes after I ordered it!) and a torque wrench. I'll let you know how it turns out in 8-10 days when the parts arrive.
    Chris
    Dec 01 2011
    Grayslake, Il
    Hi everyone, let me jump on this thread here since I started off with the same problem. I had soaked coils too. So, because I needed my car everyday I bought 4 coil packs and valve cover gasget and plugs from NAPA. I replaced them pretty easily, but came across some broken hoses at the crankcase breather, fixed that the best I could. Initally car ran fine for 10-20 miles then CEL comes on. Now i keep getting p071, p0301, p0302. I researched all sites including this one. More confused now. What next should I try? Thanks in advance. BTW, I have 04 a4 b6 1.8t Q, AMB engine.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    Quote Originally Posted by petert17 View Post
    The car ran bad from the start.. it takes those 10- 20 miles to cycle through and findthe codes.
    sounds to me you have a complete hose off somewhere. search it up, there will be diagrams. personally im gutting it as soon as i can find an acceptable route to keep my breather and booster nice.
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Jun 30 2008
    Erie, Pennsylvania
    Dan, I'm going to respectfully disagree with you here. I've had nothing but success with just replacing the gasket and not removing either camshaft. The gasket is metal and does not leave behind any significant residue. It is actually the half-moon insert that seems to cause the majority of the problem anyway. I do take time to clean the surfaces but just a quick spray down with some brake clean and mirror check is all I've needed to do. But even if you really wanted to remove the CCT entirely to clean it spotless, it certainly does not require removing the timing belt or even moving the exhaust camshaft at all. Only the intake cam need be removed to fully service the CCT. I suppose you could argue "correctly" on that. But practically speaking, nothing more is necessary.
    Dec 01 2011
    Grayslake, Il
    Ok, so I checked the hoses best I can, nothing blatantly broken or loose. I swapped the coil packs around even tho they are new and still same cylinders misfiring. p0301, p0302. Everytime I reset it the same two misfires. If a vacuum hose leak wouldnt it cause random misfire? If its the same ones all the time does that pinpoint anything else?
    Sep 03 2009
    GSX-R 1000
    Manama, Bahrain
    Valve cover gasket change was easy enough. Luckily no parts were broken in the process - minus the hood strut (ouch). Miss-fires still occurred over 15psi. Replaced all 4 coil packs with spares and it runs like new.
    Chris
    Sep 12 2008
    South Central PA
    I've done exactly what you said on a couple B6 cars, but on some B5s that I've done headwork on, like my brothers and brettj20's, when I removed the CCT, there was some material left over that needed scraped off. I have yet to see a 01+ MY 1.8T (A4 or GTi) have any gasket material left over though. Maybe the gaskets were a little different on the older ones? I certainly don't know. But any time I have changed the CCT/VVT gasket and half mooon, I always had the head removed from the cars because of other work that I was doing.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jun 27 2011
    Quote Originally Posted by clm6113 View Post
    Wow. Wait someone did a repair and didn't end up breaking other parts! Its like I just saw a unicorn...
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    heh. going through this now.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Quote Originally Posted by ryanhmusic View Post
    Holy Necro Bump Batman!
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Aug 05 2014
    Quote Originally Posted by MurkyRivers_A4 View Post
    I know but I saw chuck and I couldn't resist
