2.slowT asked, so I moved this thread.
how am I twisting words? the original statement was that straight pipes in place of x-pipe on a dual exhaust car"provide better performance". This is not in anyway true. Most people, read dyno charts to find the max output. If that's how you read charts, then the x-pipe may provide no difference on a peak number. If you decide to actually read the graph, I would bet that you would find higher low RPM torque and hp as a direct result of an x-pipe. My statement was in direct reply to that comment. I would assume by your persistence that you agree with the decrease in performance, BUT YOU DON'T. You said that it makes no difference. Do you see where I am coming from?
There are 3 possible outcomes from x-pipe installation.
1: decreased performance
2: same performance
3: increased performance
I said that you would see outcome #2 or #3, depending, but NOT see outcome #1.
And about the research, find me the documentation that proves your theory. I have searched high and low and can't find anything about the performance changes in either direction based of an x-pipe on a turbocharged car. I would love to see it the results from both setups. I'm not talking about some runs on a dyno and numbers. I would like to see something with a control and all different variations tested to make logical conclusions about what makes it better and what doesn't. Step back and think about the millions of dollars that Audi put into RD when designing the 2.7T . Do you really, truly, honestly think they would include a part that decreases horsepower and fulfills no other function.
I own an '02 AR 2.7t 6MT. So, I have driven one...I drive one everyday. Do you launch your car @ 1500 RPM's? Do you actually skip your turbo lag all together? No, you don't. You use those low RPM's to get your car moving. Albeit a small part of the equation, you can't honestly say that it doesn't make a difference.
