Results 1 to 34 of 34
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    5x114.3 wheels, need to know ASAP!!
    Guys, I just come across a set of wheels at a very good price, but the bolt pattern is 5x114.3 and I also need 5mm spacers for them. I have searched that 5x114.3 will fit our cars with wobble bolts, but is that any safe? will they just work as good as 5x112? Guys, I need to know this asap! thanks a lot!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: 5x114.3 wheels, need to know ASAP!!
    Of course it will look the same, but IMO DONT DO IT
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 05 2007
    Wobble bolts will make them fit, but wobble bolts don't work with spacers (or maybe I'm wrong). What offset are the wheels?
    Established Member Two Rings colinisneat's Avatar
    Sep 19 2006
    '01 Audi A4
    Valparaiso,IN
    wobble bolts are fine, just dont track the car on them. you can't run a spacer though with wobble bolts.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    the offset of the wheels is 40. wheels are 18x8
    Jan 20 2007
    2007 VW Gti, 1999 A6 (sold)
    Socal
    Wobble bolts are perfectly safe to run. Just make sure you have at least 1.2mm of play within the holes for them to work properly. It's the name that scares many people, although I know many people that use them, and they are fine. As far as spacers, you are allowed to run a 5mm spacer with wobble bolts, but nothing bigger then that
    Oct 06 2004
    Minnesota
    Quote Originally Posted by colinisneat View Post
    wobble bolts can be used with thick spacers if your spacers are threaded, and the spacer bolts to your hub.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Dec 05 2007
    A 40mm offset is just fine, also. You should not need spacers unless there are brake clearance issues, which I doubt, or you want more poke (the wheels closer to the fenders).
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    I will have a set of 235/40/18 tires. To make them fit I need 5mm spacer because i need 35 offset. am I correct?
    Jan 20 2007
    Socal
    Alright guys, searched and got more info about spacers. Apparently, raderwerks, the maker of wobble bolts doesn't recommend spacers with them, but many people have gotten away with running a max 5mm spacer with no problems. You just have to make sure you have enough thread on the bolt to lock it tight.
    Quote Originally Posted by A4Rob View Post
    Unfortunately you can't, unless they make longer wobble bolts with more thread, which I'm unaware of.
    Jan 20 2007
    Socal
    Quote Originally Posted by samleong View Post
    You don't HAVE to have a 35 offset... but that will sit pretty flush with the fenders. The higher the offset, the more inside the fender the wheel sits. The lower the offset, the further out it sits. So a 40 offset will sit just 5mm further in then a 35 offset. Like another person on here said, you should be fine with that. I say don't run them, tuck the wheels, and dump the car. But that's just me
    Dec 05 2007
    I would not know. A test fit can always confirm. Then get the spacers if you need them, as people said you can run 5mm spacers with the wobble bolts.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    so how do I know there is at least 1.2mm of play within the holes for them to work properly? I don't have the wobble bolts and the wheels on hand. Any suggestion? Wheels are these:
    Jan 20 2007
    Socal
    ASA AR1's.... I'm pretty sure the only way to check is to test it with the wobble bolt. But I might be wrong on that. And if necessary, you can extend the hole bigger if it doesn't have enough play. To be honest, wheels are great, but not worth going through such a hassle of running wobble bolts and spacers and all that junk. Unless you are getting an incredible deal on them; in which case if you are getting a good deal, go for it
    Feb 27 2005
    North Wales, PA
    after wobble bolts, spacers, hub rings, studs, etc, you might be better off just buying the wheels with correct fitment. It not like those wheels are rare or special. Consider what you are paying for the wheels and how much its gonna take to fit them up.
    Oct 06 2004
    Minnesota
    Quote Originally Posted by Poopie View Post
    Really good point. I was under the impression you came across something really rare.
    Instagram r_michals
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    The sell is local to me and he listed $250 for them.
    Dec 05 2007
    With tires?
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    With tires?
    no. I will have a set of 235/40 for $200
    Dec 05 2007
    Going on what Poopie said:
    Wobble bolts are ~$100 for 20
    Good spacers (5mm H&R or ECS) will be about ~$80 for 4
    Hubcentroc rings ?????
    Just something to factor into the final price.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    400 in total. if I don't need spacers for them, I might go for it..
    Jun 04 2007
    Austin/DFW, TX
    Id love to get some cheap Work VSXX
    My 5-Speed Swap DIY
    - B6 USP
    Feb 27 2005
    North Wales, PA
    i guess its cheap enough. Not a steal, but not a bad deal. 600 for a wheel tire set up is pretty reasonable plus he'll have the wobble bolts to use down the road if he finds sweet 5x114.3 wheels later.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    so what do I do with the 5mm spacers? is there any space left for me to put on the hubcentric rings after I put the 5mm spacers on?
    Looks like the 5mm spacers from ECS are not hubcentric spacers...
    http://www.ecstuning.com/Audi-B5_A4-...cers/ES252608/
    Feb 27 2005
    North Wales, PA
    depends on the center bore of the wheels you are getting. I forget the stock CB on the hub. 57.1mm?
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    2nd, my wheels are 5X114 with an 42 offset with no spacers
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I'd skip the wobble bolts and spend the 100 bucks on redrilling the wheels. The holes will elongate the original holes by 1.6mm which is about 1/16". The connection will be more secure, you won't need wobbles, and all the normal rules apply again.
    I personally would stay away from wobble bolts. I don't like the lack of even stress distribution. Concentricity goes a long way when it comes to fastener strength.
    Jim
    I Do Werk.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    Quote Originally Posted by aaronamerica View Post
    do you use wabble bolts? what tires you running?
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    some shops will redrill the wheels for you. i just did that on my work wheels. works perfect with no issues.
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    Quote Originally Posted by nizmosx View Post
    you mean redill another 5 holes on the wheels?
    Mar 09 2004
    nw michigan.
    Not really. You're drilling a 5x112 pattern inside the other pattern so 99% of the hole overlaps. You won't see it and it is a stronger connection method.
    Jim
    I Do Werk.
    May 31 2005
    Dallas
    no I have the stock bolts, and the wheels I have I bought straight from AXIS and they drilled them out a lil to work
    Jun 09 2009
    97 A4 1.8TQ
    Chicago
    I am sorry. am I missed something? Ours is 5x112, we are talking about 5x114, how can we drill the bigger holes(114) to make them like 112(smaller holes)? sorry about the noob question...
    Jul 12 2007
    Massachusetts
    It elongates the holes to make them a tad larger, so you will be able to run on the stock 5x112 bolt pattern. The new sizes will barely be noticeable over the old bolt pattern on the wheels.
    2020 SQ5
