Results 1 to 27 of 27
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    Brake Pad Warning Light - How long do i have? -- UPDATED QUESTION
    Hey guys,
    My brake pad warning light came on tonight. I have some busy weekends coming up so i'm not sure how quick i can get to this. How long can you safely ride on the pads after the light comes on? They don't feel any worse then the crappy stock brakes usually feel.
    2008 Audi A4 S-Line/Ti 2.0T Quattro
    2003 Audi A4 1.8T Quattro (crushed by tree)
    Sep 12 2008
    South Central PA
    Re: Brake Pad Warning Light - How long do i have?
    Quote Originally Posted by JayStang View Post
    Hey guys,
    well.... there is like 4mm left on the pad when the light comes on. dont wait long. it only takes a hour or so to change them, so i would find time.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    When my light went off last time I was down to the bare metal! Be careful and check your pads, I had to have my rotors turned down because the metal on metal contact.
    High speed Ferrari movement...
    Active Member Two Rings MTX02's Avatar
    May 15 2009
    Queens
    If the sensor is going off now then you defiantly need to check all the brakes because there is no sensor on the rear brake pads so you could be closer then you think. And if you hear grinding then you are S.O.L on your rotors too!
    ECS tuning OEM brake upgrade (drilled and slotted front and rear rotors) ECS tuning stainless steel brake lines, Miltek exhaust, K&N air filter, 20mm spacers, Black Plasti dipped rims
    3.0 group
    Forum Moderator Four Rings docurley's Avatar
    UK London
    I would do them this weekend or you will need pads and discs and don’t plan any long journeys that’s for sure.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Not thread jacking: After I warm up the car, I get the grinding noise when about to take off but dies off when I stop. Could this be the breaks pads?
    UK London
    Could well be either sticking pads or it can happen if left sitting for a few days.
    Nov 23 2006
    Soooouuullllll Cal!
    Well I dd my car going to work. Sometimes the noise come and goes.
    Jun 23 2008
    Boston, MA
    Thanks for the responses guys. I'm not worried about the rotors, i plan on replacing all 4 corners with pads and rotors. I'll see how long I can make these last. As of right now i'm not getting any type of grinding and they really dont feel any different to me. I wont be able to tuch these for 2 weeks due to a planned vacation (which i will no longer be taking my car on).
    Thanks for the help!
    Deactivated Four Rings
    Sep 30 2008
    n/a
    Brakes is not one of the things you want to screw with on your car. Find the time and change them. Its a matter of life and death
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Do them today, only takes like 50 mins if you have the right tools and correct parts, like said above its a matter of life and death.
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Jun 23 2008
    Boston, MA
    Well I'm going to be ordering the rotors/pads so today of course isn't an option. I'll order them now and squeeze in some time to install asap.
    Jun 23 2008
    Boston, MA
    One more question...
    Do i HAVE to get pads with the sensor wire? And if not how does that work? Does something need to be vag-com'd out?
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    Re: Brake Pad Warning Light - How long do i have? -- UPDATED QUESTION
    The warning light can be misleading too since it's only for the front inside pads. They don't always wear evenly so the outside pads could be in worse shape.
    You don't have to get the pads with the sensor wire. Cut the wire from the old pads, short them out and plug them back in. Otherwise, your warning light will remain on.
    Jun 23 2008
    Boston, MA
    Thanks teratorn!
    Sep 13 2008
    Western Chicago Burbs
    one of my pads got down to bare metal and it started to dig into the rotor. never got the warning light for some reason
    Aug 26 2005
    The later versions of the instrument cluster have an adaptation channel to enable or disable the brake pad warning light, using VAG-COM.
    The other way to properly disable the warning light for cars without the adaptation channel, is to jumper the brake pad warning circuit inside the car at the connection station under the left kick panel. It's reversible and avoids the problems often resulting from a spliced joint outside the car from salt and moisture corrosion.
    Jun 23 2008
    Boston, MA
    Hmm... i have an early 03 (manufactured in nov of 02) so i'm assuming i don't have the later version of the instrument cluster?
    Do you know of a DIY for the jumper method?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here is a diagnosticator quote from an old AW post on how to jump out the sensor curcuit. Be sure to rep him!
    Remove the lower left "A" pillar kick panel, and find the GREEN 17 PIN harness connector, The circuit to ground is at T17b/3. That is; T17b=GREEN 17 Pin harness connector. /3=PIN position number 3 (Three), and is a .22 mm^2 Brown/Green wire between the INSTCLUSTR and T17b, and a .35 mm^2 Brown/Green wire from T17b to the pad sensor connectors.
    The Brown/Green wire, is either cut, with a stud ring crimp on terminal added to ground with a screw to the body, or, a insulation piercing wire tap is placed on that circuit, with a lead to a stud ring crimp on terminal similarly attached to a clean ground at the body under the kick panel. Try and use a factory provided body ground location, as that is the best ground point.
    Grounding the pad sensor circuit as described above, eliminates problems caused by corrosion and dirt at the jumpers, effecting the warning lamp. And like the connector jumpers, is easily reversed to re activate the pad wear warning sensor function, if desired in the future.
    Mar 25 2008
    Ottawa, ON
    I'm interested in this as well if you could provide more info. I have sporatic erronious indications that are becoming annoying. I know the pads are ok as they were inspected within the last month.
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    Quote Originally Posted by Boosted3.0 View Post
    LOL i too went down straight to grindin on my rotors. But thats the excuse i wanted to have to get cross drilled rotors which i got....
    Aug 26 2005
    Your '04 instrument cluster has the adaptation channel to disable the brake pad warning light using VAG-COM.
    Aug 26 2005
    Quote Originally Posted by pandaudi View Post
    Maybe you are noticing the ABS initialization, it sounds like a grinding noise occurring at first drive off, with a little vibration in the pedals, but normally lasts only for ~1 second.
    Mar 25 2008
    Ottawa, ON
    I think that may be what I have as well. First time moving forward after the car has been sitting for awhile (first thing in the morning or after work) I notice a grinding/vibration which feels like it is coming from the driveline somewhere. Lasts like you say about a second and disappears.
    Jun 23 2008
    Boston, MA
    I have an 03, is that what you meant?
    I'm guessing VAG-COM would be the easiest solution if that's an option. Are there any instructions on how to do this??
    Thanks again!
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    My brake pad warning is intermittent. Since the warning light operates due to an open circuit, if the pads were indeed low the warning would come up every time I turned the car on. Is this true?
    Pads and rotors at all four corners were done about 6 months ago, so I doubt they're low already...
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    I'd check the wire going down to the brake pad it might have a knick or something. When my light came on my pads were still pretty decent, but I changed them anyway and it was due to some bad contacts or the wiring itself.
