Results 1 to 23 of 23
    Active Member One Ring moedog's Avatar
    Jun 18 2009
    2006 A4 2.0T Quattro
    Denver
    Cylinder 1 misfire 2.0T: SOLVED!!
    Okay here is my fyi I hope this helps someone somewhere down the line...
    My issue:Intermittent power loss trigering check engine light
    scaned codes ----> cylinder 1 misfire
    swapped coil packs from cylinder 1 and cylinder 2 and reset codes
    misfire again
    Swapped coil packs back replaced spark plugs with OEM pregapped plugs
    sparkplugs had 30k miles on them reset codes
    misfire again
    **** GAVE UP SENT TO DEALERSHIP****
    recirculation valve Intermittent defect $363.80
    - boost levels would drop triggering misfire in cylinder 1
    why would it only trigger cylinder 1 misfire IDK
    dealer techz
    "Drive it like u stole it!"
    Jan 24 2009
    Lancaster
    Re: Cylinder 1 misfire 2.0t SOLVED!!
    first time ive seen someone praise a dealership.
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    Wait - the recirculation valve? Isn't that the diverter valve?! Sorry if that is a n00b question but if it is then you just got ripped off
    2001.5 Nogaro Sport b5 s4
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by BreakMyWallet View Post
    Not all dealerships are out to get you. I have nothing but good things to say about the Acura dealership I've been visiting over the last 11 years.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    Quote Originally Posted by ggg20t View Post
    I would assume he meant EGR?
    V
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Jan 01 2008
    Long Island NY
    How would an egr valve have to do with misfires though, i don't think they can be related.
    Sep 18 2008
    Pittsburgh, PA
    I just think that if it had something to do with the boost levels dropping then that means the DV was bad... in that case - he could have got that new OEM revision for like 100 bucks or whatever and put it in himself... instead of a 300 dollar expense!!
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    That cost is a DV with a 1 hour install and a diagnostic fee. A cylinder misfire is not a typical dv code, especially one that doesn't move. As long as he got the latest rev dv, I'd be bummed but happy it wasn't worse.
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Jan 13 2009
    Quote Originally Posted by Auditude2.0T View Post
    Drawing back from memory way long ago, so take it with a grain of salt.
    The EGR recirculates hot exhaust gases back into the intake, which will increase the temp of the intake air, and slightly alters the A/F ratio. Anything that tampers in that area at least has the potential to cause misfires. If for example it could overly lean the mixture, you could be getting pre-ignition... Possibly detected as a misfire?
    Its a emissions thing, and we old school car buffs use to take our EGRs apart and seal them with copper gaskets and remounted them (hid the fact they were tampered with) for an extra pony or two.
    Hell, I haven't even looked at the Audi to know if we even HAVE an EGR....
    When the OP said "recirculation valve" I just made the mental connection to the problem and though to myself that it could certainly fit the symptoms, that's all...
    peace
    Vince
    +1 Rep for filling us in on an interesting problem!
    Sep 18 2008
    Pittsburgh, PA
    Yea definitely an interesting problem- Glad to hear it is fixed!!
    Hey RVT, what is an EGR?
    Nov 02 2007
    Albany, NY
    Huh... Never heard of anyone having an egr issue in 9 years of A4s. Ya learn something new everyday.
    2008 Ibis A4 2.0T
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    EGR = Exhaust Gas Recirculation
    Typically will trip a code that says "EGR malfunction" or something similar. Never seen one cause a misfire but i suppose its possible.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Jan 13 2009
    ^ EGR = What he said
    Vince
    Jun 18 2009
    Denver
    I just put 100 miles on it, and no new code no new issues, Maybe I overpaid but I couldent figure it out and they did. I never would have guessed recirculation valve so I say $ well spent
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Quote Originally Posted by moedog View Post
    So you aren't going to fill us in on which 'recirculation' valve was replaced? Was it the exhaust gas recirculation valve (EGR), or the boost recirculation valve (DV)? This would be good to know. If you don't know, look at the receipt and write down the part number.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Sep 18 2008
    Pittsburgh, PA
    ^ Good call - i am interested to know what valve they replaced.
    Glad your car is working again!
    Established Member Two Rings B5RiceEater's Avatar
    Nov 09 2010
    brooklyn
    which valve is it im goin thru the same problem cant come to the conclusion i see they have this valve on ecs http://www.ecstuning.com/Audi-B5_A4-.../Valve/ES5636/ is that the same thing? or is it a diverter valve???
    Oct 20 2010
    Dallas,TX
    I'm going thru the same problem. I've had my valves cleaned, changed plugs and changed out my cam follower. Waiting on getting a new injector(#3). Would like to know which of the ^ is the right one.
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    Its the turbo recirculation valve aka dirverter valve aka n249 aka blow off valve aka pssssshhhh noise.
    Audi quit using an actual EGR valve around 1998. So good luck finding it on your B7's.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by STONER View Post
    I was going to say the same thing, all these people talking about EGR and have no idea our cars don't even have it.
    I was pretty sure VAG phased out EGR on everything when they went OBD-II, everything except TDI... and of course i'm talking NA domestic market, some countries have really weird engine options.
    Glad you got the issue fixed!
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    you guys state the price of the part, and how this guy over paid. what would make him be drawn to replace the popper part? they get paid to be able to diagnose, not just sling parts out of a parts cannon at it. that would be far more money than this. smart bringing it to the experts.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Jan 11 2011
    Cyprus
    I am having a similar problem, missfires but random on various cylinders.
    My mechanic said he will make a smoke test to see whats the problem. He thinks the engine is sucking more air and he will check the electonic valve
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    OP, post your invoice with part #.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
