Results 1 to 10 of 10
    Established Member Two Rings midnyite's Avatar
    Jun 28 2007
    anyone know if a b6/b7 cluster will work for our b5?
    anyway i dont know of anyone ever trying but other then the fitment issues would it even work?
    Feb 24 2007
    Nicosia,Cyprus
    Re: anyone know if a b6/b7 cluster will work for our b5?
    Quote Originally Posted by midnyite View Post
    I will try it out in a week or so....
    The problem is that the b6/B7 Tacho receives speed ,rpm, etc with canbus.S4 Tacho receives each info through a pinout of the ECU....
    BUT the S4 ecu is ME 7.1 which is what B6 V6 also use....And it is also connected to the canbus. So it may work....
    A friends, friend already try it and I was told that it works fine.....I will know as soon as I finish wiring... I am installing a RS4 B7 tacho !!! :)
    Jun 28 2007
    you got pm
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    It is a different dash. How will it fit without looking like ass? Am I wrong here? Is the cutout the EXACT same size?
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Jun 28 2007
    it isnt which is why i am interested in seeing how he is going to make it fit.
    There is another thought which is to swap out the entire dash.
    Im looking at a easier route which is to see i can swap out the interior of the b6/b7 cluster to bring it over.
    If i can get a working model that would be great, a color lcd as opposed to our red ones.
    Dec 10 2006
    Midwest
    What makes you think the dash would fit? Pandora's box
    Wings
    Carbs
    Titaniums
    Nov 29 2013
    Finland, Lappeenranta
    This is an old thread but has anyone managed to fit B6/7 cluster into B5? I have B5 RS4 and would like to have B7 RS4 cluster on it :)
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    It's pretty obvious that they aren't interchangable just by looking at the shape of each.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 29 2013
    Shape is not a problem, is it possible to connect B7 cluster into B5? If that is not possible at all, then I need to forget the idea to have B7 cluster in my B5 RS4 :(
    Jul 05 2014
    B5 S4 Nogaro
    Littleton, CO
    B7 uses CANBUS and B6 uses K-Line. I'm not sure this matters here or not, but I thought I'd point that out.
