Originally Posted by
BLACKa4QUAT
your b6 wont have this problem since it is not a direct injection motor like the 2.0t
BullShlt!!!!
carbon buildup is a problem for any engine.
BG Induction Service FTW. Cleans Fuel Injectors, Combustion chamber, Intake Manifold, Throttle Body, Intake Valves & Seats. all for a respectable price (most dealers charge 120-170 bucks) and it only takes an hour. dont have to take off the head, manifolds, or anything. its a 3-chemical system. one is sprayed in the intake tract (seafoam would have similar effects), one is dumped in the fuel tank for continuous cleaning after the service during the next tank of gas(similar to fuel injector cleaners @ parts stores i.e. stp/gumout). and the final chemical is ran
instead of fuel, and pumped directly into the injectors (or hpfp>injectors). im not trying to advocate or advertise the product, but i do believe in it because i have had cars with so much carbon they barely start/idle and fail compression on 2 cylinders. after the service, they run better and stronger, as it shoots all the carbon out the exhaust (very smelly whitish/blue smoke, mostly burned in the catalyst & combustion chamber). anyone worried about carbon should look into a total induction service like this, especially if you are already bringing your car to the dealer for a service or something. it can also be preventative maintenance once every 2-3 years. hope this helps. peace.
