Yep, mine works great. You get the vag-com shareware (free) edition software from ross-tech's website, version 409.1. When looking for cables on ebay, find one that says "409.1" to make sure it works with the newest possible free version.
It is a bit limited, however. You can read out all the Trouble Codes, but it doesn't "decode" all of them for you. A quick search on Audizine or google usually takes care of that. Also you can only access measuring blocks up to 025, the rest are blocked. In your case you could look at and Log the MAF values, but not the Boost pressure. You can unlock it for $99, but if you are going to buy it, it is best to get an official cable and the newer software. Their newest software versions only work with their official cables AFAIK. That would be $229 and up depending on which cable you get. The more expensive cables work with newer (2003+) cars.
Here is a great thread to check out. Sections 1 & 2 discuss purchase, installation, and software stuff pertaining to the Ebay cables.
http://www.audizine.com/forum/showthread.php?t=158766
