Results 1 to 21 of 21
    Jun 23 2009
    Audi A4 3.Sloooowww
    Philadelphia pennsylvania
    A4 3.0 to 2.7tt Swap
    Does anyone know what I would need to change to do this swap and are the subframes compatable.
    Sorry if this was already covered alot.....
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Re: A4 3.0 to 2.7tt Swap
    i think there is like a 17page thread about this somewhere....try searching 2.7t in the b6 forum only you should get something
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Jun 23 2009
    Audi A4 3.Sloooowww
    Yea my bad I just did and its huge so just ignore this
    Veteran Member Four Rings Styleprojekt's Avatar
    Nov 17 2006
    Salt Lake City
    You cant really search engines (1.8t, 3.0 etc) that well in the search option. But go in google and search and it will lead you to a few threads on here.
    Everyone will tell you "its not worth it"
    Is it bad ass? Yes indeed
    Is it do-able? Probably not if you are asking questions in a basic forum because it probably means you dont have anywhere near the knowlege needed to make this swap work in terms of electronics and more
    Jan 10 2007
    VA
    The big issue with a 2.7T swap into a B6 is wiring/ecu/ect. I see no point in a 2.7T swap into a B6, if you are going to take on a project like that, you might as well swap in a VR6 and slap a big turbo on it, that'd probably be easier.
    Nov 17 2006
    Salt Lake City
    Quote Originally Posted by b6onboost View Post
    I believe it was previously said that due to the VR6 not being an Audi motor it is even less of an option for the B6 platform and wiring as well as transmission would be even bigger of a nightmare. I may have fallen on my head though and be completely wrong.
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    Why not just turbo your 3.0 V6?
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    They are really not all that hard to do. Its a lot of work of course, but not that huge of a deal. I know swapping a 2.7T into a V6 is WAY easier than doing it from a 1.8T.
    If you have alot of questions, you might want to give Greg from SSP a call. He has about 3 of these swaps on deck, and I think one B7 2.7T swap to do.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Nov 17 2006
    Salt Lake City
    Quote Originally Posted by PhunkFX View Post
    Anything can be done really, as long as you can find a parts car your pretty good to go. I found a 2001 S4 not too long ago with major body imperfections, the front was full of rock chips, bent fender, keyed doors, missing taillights as well as a cracked windshield and a broken mirror. Both front tires were flat and the front right rim had been hit with an object. The car had been vandalized. The interior was immaculate and the engine bay looked lickable clean too. The engine had 73k miles on it. They wanted $3900 for it...i wanted to get it and was gonna do the swap with a mechnic friend of mine.
    Veteran Member Three Rings reapersa4's Avatar
    Sep 25 2006
    too many
    North Vancity
    Just do a 3.0 block with 2.7 heads.
    500 AWHP 400 AWTQ
    04 1.8TQ6M USP Black on Black w/CF Trim ~ Eurodyne tuned ~ 2.0L GT3076R ~ AEB Head w/1mm oversize valves ~ 3658 cat cams ~ Direct port Meth ~ Custom FMIC ~ Custom 3" exhaust ~ Custom Intake Mani w/S4 72mm TB ~ STaSIS 4:1 center diff ~ HRE 441R 19x9.5/19x8.5 ~ STaSIS MS ~ B7 RS4 F+R BBK ~ Podi P2~ Custom S4 rear w/ 996TT tips ~ S4 Recaros Blk leather w/Dove Grey Alcantara ~ S4 bi-Xenons ~ Caractere Sides, USP w/Kerscher CF splitter ~ Custom EG CF hood ~
    Nov 17 2006
    Salt Lake City
    Quote Originally Posted by reapersa4 View Post
    Isnt the 3.0 block weak?
    Sep 23 2006
    Houston TX
    Using the AVK 3.0 block even with upgraded pistons/rods under high boost applications would probably be a bad idea.
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Styleprojekt View Post
    Powerwise the VR6 would be a much better idea. To pull off the VR though you would want SEM to run the motor and keep the factory 3.0 ECU in place to run all the feature comforts (what will still work) in the car. Of course you will have to do some integration of the two systems (SEM and ECU) to get the cluster to work.
    If you are going to go the 2.7T route, the C5 A6 2.7T is an easier swap than the B5 S4. The A6 overlapped the B6 body style and shared many of the same features. The A6 ECU is more plug and play into the B6 (which the B5 S4 setup is not). I am speaking mainly of the ECU and harness, not the motor iteslf
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Quote Originally Posted by Ill 3.0 View Post
    What do you consider "high boost"? And has anyone blown one up due to something besides a bad tune?
    -Tim
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by sandspeed View Post
    B5 S4 guys have tried using the 3.0 block to save weight.... i don't recall the breaking point, but the bottom end always tore itself apart.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Does that mean 3.0 guys could use 2.7 blocks?
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Quote Originally Posted by nein-reis View Post
    Good question. I doubt it because I would have done it already.
    High speed Ferrari movement...
    Jun 29 2007
    Raleigh, NC
    i cant wait to click one of these threads and see that it's someone posting about their COMPLETED swap instead of just asking if anyone has done it.....
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    May 24 2007
    Southern California
    Quote Originally Posted by B6Lovin View Post
    tell me bout it... these are weekly threads now...
    Kyle
    2.0L Revo GTRS Eliminator
    Senior Member Three Rings Audi-ence's Avatar
    Aug 31 2008
    2004 Audi A4 1.8T UltraSport
    Vancouver, Canada.
    Haha......that's because when the swap is finished they're too busy driving and enjoying their car to post about the results! Or maybe the swap was so expensive they had to sell their computer.
    USP Club Member #604
    http://www.cardomain.com/ride/3143073
    Feb 24 2007
    Nicosia,Cyprus
    3.0 its still a ME 7.1 motronic just like the 2.7TT is....
    I am currently swaping the 2.7TT into my H7 (B6) cabrio 1.8TQ...I made a threat about it here....
    http://www.audizine.com/forum/showthread.php?t=287998
    I have 2 issues with the wiring so far.
    1) The S4 Ecu sends out rpm,speed and overheating signals to the tacho with the use of separate wires. 7.5 motronic (1.8T) sends this info with canbus
    2) The S4 Ecu needs 3 wires (pins) to oparate the cruise control. The 7.5 motronic (1.8T) only need 1.....
    I will try the ecu out with out the above pins. If it doesnt work I will intall the original one as piggyback......
