Originally Posted by
rxbike
Not sure how my APR 2.5" DP is smaller than piggies (JHM/FI) 2.5". Must be a CA metal walls and AZ metal wall thickness since all APR exhaust are built by Billy Boat Exhast anyways...
Enough said, I just had my APR DP installed to my 3 month old APR exhaust.
Top RPM end power is there but I think at a slight loss in lower RPM BUTT response. Noise wise after a few days is not as bad as when I first got it. (I have the high flow cat ).With the windows down, you are approaching the sounds of american muscle sound, though not as loud by any means. Windows up which is how I drive most of the time, it was only a slight noise increase. You should take up the other member's offer to hear the system. i need to get some time to record a sound clip and post it vs. the 65 mustang with a 351 cu in and flow master exhaust.
2nd APR dp are good. The issue with Dp's are just the cat placement. You need to move the pre cat back further. The fact that ALL the after market Audi and only Audi aftermarket Dp's have the pre cats still is the issue that puts the Piggies up on the HP chart over the typical Dp's.
Having the cat that close to the motor is not as good has retaining your main stock cat in your Stock Dp's but removing the pre cat.
I did a write up and to just kinda skim threw it. aftermarket Dp's all help but how they help is the issue. The results with aftermarket dp's is less restriction but still a restriction too close to the motor. This is why all the other performance company's for all the other cars domestic and other wise that have PRE cats as well REMOVE the PRE cat and re place the MAIN cat in there design.
Any way you put in aftermarket Dp's you will still have the Pre cat and you will get a good boost in flow out of the exhaust. BUT take you stock Dp's and just remove the PRE cat (you will need to move one of your 02's cause you will get a cel thus this is why people send them in to get modded)
So you take you stock Dp's and just remove the PRE cat change noting else and you will get the same if not better flow but you will also get lower Exhaust temps, more ignition timing, faster A/F readings and more stable transition threw the rev range
So if your looking for the scale of power
headers
ALL after market Dp's with out cats (these are here cause of the dia and bends)
Piggies with out cats
piggies
aftermarket Dp's
A little more info
http://www.audizine.com/forum/showthread.php?t=250634
