Ok, at risk of sounding like a moron, I'm trying to decide between APR's 1 or 1+ upgrade for my B6 (04 A4 1.8T QT) with 60K miles. I've searched and searched, but I don't really see this comparison on this or any other forum, in terms of anything other than performance. Clearly, the 1+ has greater performance. I did read a thread related to the injectors, pointing out that the stage 1 probably puts the standard injectors at nearly 100% of their duty cycle (at peak?).
So, I have an appointment for tomorrow morning...I've purchased the injectors, but I'm still thinking about just doing stage 1. This car is my daily driver, and I put 60 to 100 miles on per day. I don't want and cannot afford reliability issues that would put my car completely out of commission. I understand coilpacks will go bad and the DV will need replaced (already ordered one). This is probably true either way. I do my own maintance, not too big of deal. It's more of the WAF. How much real difference (butt dyno) is there between the 1 and 1+ file, and how much harder is the 1+ file on the car? Does 1+ use higher boost, or is it just pushing more fuel? At this point, the cost is the same, but I would likely be able to sell my TT225 injectors and get my money back. Currently, I find myself at WOT more often than I would like, and I'm sure it's lack of power delivery from the stock ECU. Will Stage 1 be enough to give me low end power (1st/2nd gear) without sacrificing longevity of the car? Or is 1+ just as hard on the car as 1?
Yeah, write a book - but now you can hopefully help me....
