Results 1 to 39 of 39
Thread: A/C vent smell
    Registered Member Two Rings
    Apr 16 2009
    A/C vent smell
    Hello audizine members, i have been experiencing a really bad smell whenever i turn on the a/c.
    does anyone have same problems? If so, what would be the best way to eliminate that smell..?
    I changed the cabin filter only like 2 months ago. I bought the one with charcoal thingy on it. At first, it smelled great. no odors, really clean smell.
    After about a month and half, i started to smell really bad smell...
    i tried buying many car air freshners, keeping the ac on with air circulation internally, but whenever the ac is on... oh my.. smell is killing me.
    I will try to change the filter again to regular one.. but if anyone knows any alternative way to wipe off this smell.. help me.
    Established Member Two Rings fEArmE's Avatar
    May 18 2009
    Audi
    Re: A/C vent smell
    you're not alone.. i was about to go to the dealer and let them check it out.. mine smells like there's a rotten rat in there .... and it only happens when i start the A/C.. yuck!!
    Feb 24 2009
    cuyahoga falls, ohio
    Re: A/C vent smell
    It helps to turn off your a/c a couple of minutes before reaching your destination to help get some of the moisture out of the venting system. i have the same problem and have had decent luck with the product below:
    1Z Einszett Klima-Cleaner Air Conditioner Treatment
    You put the tube in the middle vent and spray. The foam is supposed to clean the evaporator surface of nasty stuff.
    Like I said, it seemed to help for a while. But it definitely will be a once a year thing.
    Mine smells more like melting crayons. Maybe I should check that too
    Senior Member Two Rings redkid's b6's Avatar
    Dec 20 2007
    03 1.8bat gti in the werks
    Riverside/ California/ WC
    Re: A/C vent smell
    if it smells its time to switch out your cabin filter
    she told me she was tired of players... i said relax baby girl I'm a coach
    Established Member Two Rings Bslice's Avatar
    Jun 10 2009
    B6 A4 6MT
    Re: A/C vent smell
    At the dealer we use a product called Frigi-Fresh, I use it on my cars and it helps alot.
    http://www.bgprod.com/products/climatecontrol.html
    May 27 2009
    Chitown
    Re: A/C vent smell
    Replacing the cabin filter will do the job.
    Apr 16 2009
    Re: A/C vent smell
    Quote Originally Posted by A4QSoSick View Post
    I know, but it's been only 2 months since i got the new filter...
    Apr 16 2009
    Re: A/C vent smell
    i think autozone or advanced auto parts, etc they should have some kind of cleaning stuffs.. i will try those tomorrow and see what happens..
    also the funny thing is that the cabin filter will not come off!!!
    I was trying to check if it's dirty or all used but it's like glued there.. i may have to rip that shit off
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Re: A/C vent smell
    You're not alone. It only happens when I start the a/c for the first couple of minutes. It's fine afterwards. Time to get that foam cleaning whatchamacallit.
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    Quote Originally Posted by shinbumee View Post
    Before you can get rid of the smell, you have to understand what the root cause is -- bacteria and fungus in the ducting of the HVAC system of any automobile, especially where that ducting system is not designed to drain away pooled condensed water. Here is an article -- there are tons more on the Internet.
    Changing the filter is only a symptomatic treatment of the problem, not a solution.
    You need to kill / remove the bacteria and fungus from the system. Also constant use of the A/C system helps as it tends to try out these pools of condensed water. Bactericides and fungicides sprayed generously into the fresh air intake of the ducting while the fan is running at high speed will distribute these agents into the system and help kill them off.
    Sep 27 2008
    Phoenix
    Re: A/C vent smell
    Will the dealer take care of this under warranty or should I buy one of these products?
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    Quote Originally Posted by wootwoot View Post
    Buy one of the products. This is not a warrantable item.
    However, since the dealerships I have come across usually have cans of the stuff, they may give you a complimentary treatment, especially if you (a) have a good relationship with them or (b) if the car is in for other work.
    Since it is likely a recurring problem, the best thing would be to get the stuff yourself. Maybe even ask the SA what product they use and get some.
    Jun 01 2009
    Houston TX
    Re: A/C vent smell
    Reminds me of one-time a colleague of mine projectile-vomited straight forward while in the passenger seat of a hire car I had. I spent two hours cleaning it up in the morning, only to have chunks in the a/c vents that I couldn't remove. Getting in the car that next evening after it had been baking in the Texas heat was less than pleasant. The a/c was spewing out the smell of chunder.
    Luckily it was a corporate hire car I just sent it back.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    Awwww gross!!!!
    That is a whole 'nother level of stink ...
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    Re: A/C vent smell
    heres the advice my dealership gave me run the ac in the hottest setting for like 10 minutes to kill off the bacteria in there it did it it works
    Veteran Member Four Rings chaze's Avatar
    Sep 16 2007
    2001 A4 Avant, 2009 328i
    Canyon Hills, CA
    Re: A/C vent smell
    Quote Originally Posted by praudi View Post
    The heater temp is hot enough to kill bacteria? Doesn't sound right, your dealer might have blown some smoke.
    -Chris
    2001 A4 Avant - Apr '11 to Present
    2008 A4 Sedan - In the graveyard
    May 18 2009
    Audi
    Re: A/C vent smell
    I'm gonna have to try that tomorrow. Thanks.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    I have heard that too.
    In my case (on a different car) I had set the heat up on high, fan on high and sprayed the bactericide in the cowl intake vents (base of the windshield) and that cured the problem .... for a while.
    As I said, constant use of the AC will tend to work towards keeping the smell at bay. If you stop for a day or so, the smell will tend to come back.
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Re: A/C vent smell
    that sounds like a bunch of hooha
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Re: A/C vent smell
    I just started getting this odor in my car and I only have 7500 miles on my car. :(
    Time to replace the filter and give the system a treatment.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Dec 07 2008
    Harrisburg, PA
    Re: A/C vent smell
    I find that running the heater on the "Hi" fan speed setting with the temp set to "HI" for a few mins. helps get rid of the smell.
    Jan 22 2007
    Fontana, CA
    Re: A/C vent smell
    Quote Originally Posted by JRMSLINEA4 View Post
    That certainly does help kill the bacteria/mold/fungus in the vents (I use that method too), but it does nothing when it comes to killing off the build-up in the evaporator.
    -Anil
    Jan 09 2009
    FL
    Re: A/C vent smell
    my cabin smells like funk, no lie.
    Jan 22 2007
    Fontana, CA
    Re: A/C vent smell
    Quote Originally Posted by Hyphy View Post
    Stop pressing the "funk" button.
    -Anil
    Sep 27 2008
    Phoenix
    Re: A/C vent smell
    Is there something I can pick up locally so that I can do this later today?
    Active Member Two Rings bishop13's Avatar
    Feb 28 2009
    13 Ford Focus ST / 97 Toyota Camry
    Burbank, CA
    Re: A/C vent smell
    I have this same 'funk'. I was at the dealership a couple of weeks ago getting some unrelated stuff done and they do offer an A/C service that supposedly kills off the bacteria and mildew in the system for like $130-150. I didn't get it done and I forgot to ask if there was some sort of warranty if the smell comes back before a reasonable amount of time. The only advice I got was to spray Lysol into the inlet. No thanks.
    May 18 2009
    Audi
    Re: A/C vent smell
    Quote Originally Posted by fEArmE View Post
    Did the trick.... it didnt work but i was boiling the hell in the car lol
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Re: A/C vent smell
    I recommend this:
    http://www.autogeek.net/wuachesytr.html
    used this on my previous cars and it eliminated the musty smell + it's made in Germany!
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    Quote Originally Posted by bishop13 View Post
    Lysol works. I used it before and it was just as effective as any of the "fancy" (read expensive) products.
    Nov 24 2008
    06' Audi A4
    Gatineau, Ottawa
    Re: A/C vent smell
    How do you turn off the A/C anyway? All I got is the fan control, and the temperature control.. there's no A/C on/off button.. I tried running the heat on HI and fan on HI and still kinda smelled.. and it was a "hot" smell too..
    I seem to get the smell when the a/c turns off.. if i press ECON button for example, sorta feel the cool air stops and then it starts to smell.. turn ECON off and the smell stops
    I mean its in the vents but anyway..
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: A/C vent smell
    Do some not have an OFF button? I sure do
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Nov 24 2008
    06' Audi A4
    Gatineau, Ottawa
    Re: A/C vent smell
    Quote Originally Posted by Latin Audi View Post
    What I mean is you can't have just the fan ON (at your prefered speed) with the A/C OFF
    Jan 22 2007
    Fontana, CA
    Re: A/C vent smell
    Quote Originally Posted by BerinG View Post
    That is what the ECON button is. ECONOMY mode is fan only, no AC.
    RTFM.
    -Anil
    Nov 24 2008
    06' Audi A4
    Gatineau, Ottawa
    Re: A/C vent smell
    Quote Originally Posted by Sly Raskal View Post
    RTFM.
    I thought the ECON was basically a function that turns your A/C OFF only if its not needed (saves on "load"/gas) and turns it back ON when it gets hotter. If so, its not an actual ON/OFF switch.
    Jan 22 2007
    Fontana, CA
    Re: A/C vent smell
    ECON mode is AC Off, always. AUTO mode controls your AC to be on and off as needed to keep the temperature in the cabin at the temperature you've set on the controls. There are no optimizations if your car as far as I know for when the car is under load or heavy acceleration or anything of that nature that will turn your AC off and turn it back on. ECON mode is certainly not that.
    -Anil
    Nov 24 2008
    06' Audi A4
    Gatineau, Ottawa
    Re: A/C vent smell
    I see.. well thanks for the info.. I had looked in the manual but I only got a french manual so I must've misunderstood their meaning. I thought AUTO was only to keep the temperature consistent (and control fan speed) and not actually AC on/off.
    Heard that other US cars actually had an AC on/off so I figured ECON wasn't the same (inverted)
    Feb 28 2009
    Burbank, CA
    Re: A/C vent smell
    Quote Originally Posted by wayneB7 View Post
    Interesting. I thought my SA was just shining me on. Did you just shoot it into where the cabin filter is?
    Senior Member Three Rings paulk11087's Avatar
    Mar 20 2009
    2012 VW Tiguan 4MOTION, 1998 Ford Taurus(THE RED ROCKET)
    Pennsylvania, USA
    Re: A/C vent smell
    i had the dealership use their "cleaning" tools for my car about a month ago for the AC having a musty smell when i first turn it on. they covered it under warranty and apparently there is a TSB out there for this. I've only had the car for 6 months at the time so they covered it under warranty but now i have to take it back to the dealership because the AC doesn't get as cold as it used to... sucks.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Re: A/C vent smell
    Here is what I did on other cars I had. Never had to do it on the Audi yet.
    1. Turn the car on,
    2. turn the fan on max,
    3. turn the heat on max, let it run for a while till it started to really pump out the hot air (leave the windows open and stay outside the car)
    4. Then spray the Lysol in the intake vents at the base of the windshield. Maybe 1/4 can (?) -- guesstimate.
    5. Spray liberally so that the Lysol gets good into the whole system and comes out of the vents in the car (covering leather seats might be a good idea)
    6. Turn off fan and car.
    7. Let sit for a while (overnight?)
    8. Drive with the A/C most / all of the time.
    That should cure it for a season.
    BTW -- never caused the A/C on the other cars to fail either. Since these Audis seem to throw a CEL if you fart next to them, who knows what will happen with the A4.
    Probably nothing.
