Results 1 to 15 of 15
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Bleeding air from the coolant system/air bubble in the coolant system
    So I finally got everything back together, car runs well, etc.
    I was only, however, able to get 4L of coolant (2L coolant 2L water) into the system. There must be air there somewhere, how do I bleed it? I ran the car until warm with the cap off the reservoir and its still sitting as is.
    Thoughts?
    Jan 15 2007
    san jose
    Re: Bleeding air from the coolant system/air bubble in the coolant system
    2.8 1.8? there are a couple bleed spots. i only know the ones for the 2.8.
    the lines that go to the heater have the highest bleed spot and might be on both the 1.8 and 2.8. there are two lines and one has a very small hole in it. if you take a vise grip and pull the hose clamp down and slip the hose down just a little bit while keeping it on the line going into the car you should be able to bleed the system
    i'll work on finding pics
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I dont know if this will help, but i might. Squeeze the upper radiator hose/massage it to get some air out.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 15 2007
    san jose
    sorry quick cell phone photo but thats the hole i was talking about there are two other but they are probably specific to the 2.8 and take a little bit of time to get to. hope this helps
    May 07 2007
    its a 1.8.
    i massaged the hoses and got a few air bubbles but nothing that took out too much air.
    damn, this is never ending, lol. im just relieved its now back together.
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    if you lift the reservoir in the air it helps get some of the bubbles out too
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Senior Member Two Rings VOoDooGTX's Avatar
    Mar 07 2007
    1987 Porsche 944 Turbo
    New Paltz, NY
    turn the heat on and run the car for 15-20 minutes with the cap off.
    it will bubble so be ready too add coolant if needed.
    Jun 30 2008
    Erie, Pennsylvania
    Here is a snippet from the Bentley manual. It has a section describing how to fill the coolant and bleed all the air out.
    B5 1.8T Cooling System
    Jan 15 2007
    san jose
    =amazing.....so how did u get that?
    May 07 2007
    thanks!
    it mentions raising the reservoir 100mm so i will do that. it also mentions a bleeder hole where the coolant hose meets the heat exchanger...where the hell is that?
    May 07 2007
    i used the method in the link above and it now has 6L in it (3L water, 3L coolant.) I am getting coolant out that little bleeder hole so my bubble is obviously not there.
    i tried turning the heat on but no more coolant is being taken in, and now I get an overheat warning after about 5 minutes of idling. (temp gauge is still at 90* though.)
    any thoughts guys?
    May 07 2007
    also, if i remove the water pump drain plug there is coolant there, leading me to believe the issue is not with the thermostat...does that make sense?
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by josmo View Post
    Just searching around the interwebs. Here is the rest:
    http://www.pvv.org/~shane/stasj/pics...sjon/A4-S4_B5/
    I actually have the bentley manual on CD, but its the old version. For the life of me I can't get the thing to work right. Working on exchanging it for the newer one.
    BTW, what year is your A4? I thought the AEB had a coolant bleed screw somewhere. I know my AWM doesn't have it, just the bleed hole in the heater hose. I've actually never used it, it always drank back whatever I got out of it and I never had a problem.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Make sure you have the level sensor hooked up to the bottom of the resiviror,that will trigger the light, your coolant temp switch could be out
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    May 07 2007
    Quote Originally Posted by 99blueb5 View Post
    this was my problem. the system was actually full, but the tank was almost empty to the when i tilted the reservoir up, it was triggering the sensor to flash the coolant light.
    all is well.
