Its easy enough just to check your antenna booser to diagnose if your poor reception is due to the booster. Pull off the back portion of your ceiling hard (it'll sound like you're breaking clips as you pull even though you are not).
Now it's as simple as inspecting the black rubber cap for cracks, that you see covering the majority of the green circuit board. If you see a crack, then you need to replace the antenna booster. I've heard of multiple attempts to try and fix these boosters and not a single success story. The worst part is that they are around $300 new (i got mine from manguyen for $100, thanks!).
I did a bit of investigating myself and tore off the rubber cover to find that there were almost no electrical components contained within the cover and i couldnt' see what the crack had ruptured (if anything). So i suppose the mystery of these poorly engineered antenna boosters continues....
