Originally Posted by
Fobia
imo it just "leaks" when you do not put load on it.. therefore the DV is open letting out air because the engine is not under load.. if you put it under load it will seal up.
i have had it for probably 25,000 miles.. i put 200whp down on a mustang dyno with just a apr chip so i dont know how you could say it would affect performance because those are respectable numbers.
Here's my reasoning with that:
That "leaked" air is still metered air that is supposed to DIVERT back to the intake. Having a DIVERTER valve with a spacer is, in function, the same thing as leaking with a bov.
Adverse effects are probably not noticeable to the butt dyno and will not negate gains from a chip. So just because your chip is giving you better numbers doesn't mean the spacer is adding or at least not harming your setup. The harm you are doing to your cats won't be noticed until the car is older, by then you probably won't be the owner of it anymore. ie you will probably not notice any harmfull effects of running an open atmosphere part on a closed system car in this case, BUT, you aren't gaining anything either. So you have ZERO performance gain for POSSIBLE harm. I think most people know what the SMART decision is. Now, if you are going for pure sound and sound only with no performance gain and
possible harm, then that is your decision. People have a label for that mentality, and whether or not it's a fair label is irrelevant to the fact that it is their opinion of you. You either live with it, or fight it, but it doesn't change anyone's opinion.
Coderedpl
SO whats the general idea of the Atmospheric Blow Off spacer for VAG 2.0 FSiT?
Bad on mileage?
What's the real benefit of having it?
On a closed system A4, there is no benefit other than sound.
