Heizen means heat, not sure what katheizen means, I think catalytic converter heat might be too obvious.
Spat = Late, verstellungen = adjusters, so Spatverstellungen must be timing adjustment. Spatest = latest.
Kennfeldumschaltung = characteristics switching, whatever that means.
Motormoment = engine torque
Translator results
Inverse pedal characteristic diagram for FGR enterprise (KFWPFGR) 12x16 (%)
characteristic diagram standardized mass flow over DC (KFMSNWDK) 6x16 (has km/hour and %)
Lambda characteristics with partial load (KFLF) 12x16 (%)
characteristic diagram for butterfly valve target angle (KFWDKMSN) 6x16 (has km/hour and %)
characteristic diagram measuring window beginning of knocking regulation (KFMAKR) 4x16 (%)
servo-controlled dynamic-reproached (KFDYMNT) 8x16 (C)
load dynamic recognition threshold (KFDYES) 6x16 (%)
dynamic-reproach to recognition threshold (KFDYRS) 6x16 (%)
dynamic-reproach to offset threshold (KFDYRSOF) 6x16
knocking recognition factor characteristic diagram ignition 1 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 2 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 3 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram Ignition 4 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 5 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 6 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 7 (KFKEF1) 3x16 (%)
knocking recognition factor characteristic diagram ignition 8 (KFKEF1) 3x16 (%)
factor delta Lambdasoll for construction unit protection (KFFDLBTS) 16x12 (%)
Lambdasoll for construction unit protection (KFLBTS) 16x12 (%)
characteristic diagram LDR integral action controller delimitation (KFLDIMX) 8x16 (hPa)
key-field for linearization Boost=f (TV) (KFLDRL) 10x16 (%)
LDR control parameter Q0 (KFLDRQ0) 4x16 (hPa)
LDR control parameter Q1 (integrator factor) (KFLDRQ1) 4x16 (hPa)
characteristic diagram LDR control parameter Q2 (KFLDRQ2) 4x16 (hPa)
threshold for dynamic thrust circulating air valve gear actively (KFSDLDSUA) 16x6 (hPa)
optimal firing angle (KFZWOP) 11x16 (%)
optimal firing angle variant 2 (KFZWOP2) 11x16 (%)
characteristic diagram optimal engine torque (KFMIOP) 11x16 (%)
offset of the optimal ZW with AGR enterprise (KFDZWOAGR) 11x16 (%)
relative driver desire moment from Gaspedal (KFPED) 12x16 (% PED)
relative driver desire moment from Gaspedal for small speeds (KFPEDL) 12x16 (% PED)
relative driver desire moment from Gaspedal for reverse gear (KFPEDR) 12x16 (% PED)
characteristic diagram for computation target filling (KFMIRL) 16x16 (%)
Dragging moment number of revolutions and load-sensitiveness (KFMDS) 11x injectors…????)
Closing time correction as a function of PRACTICE (KFSZDUB) (NO RPM….V vs ms)
firing angle characteristic diagram (KFZW) 12x16 (degree of KW of %)
firing angle characteristic diagram variant 2 (KFZW2) 12x16 (degrees of KW of %)
delta firing angle when continuous knocking (KFDZK) 12x16 (degree of KW of %)
threshold of the ZW-Timing Adjusters for ZW-Characteristic Switch (KFSWKFZK) 12x16 (degree of KW of %)
characteristic diagram with durable latest possible firing angle (KFZWMS) 12x16 (degree of KW of %)
min firing(ignition) angle (KFZWMN) 12x16 (degree of KW of %)
min firing(ignition) angle Kat-heat (KFZWMNKH) 12x16 (degree of KW of %)
min firing(ignition) angle for start and kind of next (KFZWMNST) 12x16 (degree of KW of %)
