Results 1 to 6 of 6
    Buncha motorcycles
    Memphis, TN
    Convertible top reset?
    My wife wanted to vaccum inside the convertible top's tray. So i thought it would be smart to cut it off half way right? um, turns out, that was a bad idea. The convertible top light just blinks. i found out how to put the top up/down manually so i put it up and have it all locked down but it still wont go back to working automatically. I disconnected the battery for an hour but no luck... any tips?
    APR Stage 2/AWE Intake
    Veteran Member Three Rings Chapunki's Avatar
    Sep 05 2008
    AZ
    Re: Convertible top reset?
    Wow, you are having just problems left and right...
    Wish I could help, did you try pressing the button down for maybe fifteen seconds?
    Dec 05 2006
    So. Cal.
    Maybe put the key in the door and do the window reset procedure. That may work.
    Buncha motorcycles
    Memphis, TN
    ugh, i know... if i cant get this shit CPOed then my engine build will have to be postponed till next year..
    is there a window reset procedure? the convertible top light is just blinking. ill go try to hold it for 15 seconds, i think have already but this blows!
    Buncha motorcycles
    Memphis, TN
    allright, for anyone else who may run into this problem... i did the key in the door window roll down to no avail then held the button for 30 seconds... one of those two finally made it work thank God!
    at first i was glad i had a convertible since the ac went out... i rarely use it anyway but if that top was going to be stuck up, i was going to have to get it fixed ASAP!
    Established Member Two Rings nerdhunters's Avatar
    Feb 12 2009
    05 S4 Cabrio
    Austin, TX
    Quote Originally Posted by Papachristou View Post
    your AC went out? how many miles?
