Results 1 to 19 of 19
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Bad Fuel Pump Diagnosis??? Need Help
    THREAD UPDATE: Replaced fuel filter first, this was not the problem. Replaced the Fuel Pump next and the problem was fixed. I would still recommend trying the fuel filter first, as it could be a much cheaper solution, and it is recommended to replace the fuel filter at the same time as the pump anyway. I'll post a photo of the gas that came out of my old fuel filter, with only 20K miles on it...and believe me it was FILTHY even though I only use Shell premium octane gasoline.
    Started my car last night and got a block away and the car shuddered, throttle was unresponsive, rpm's dropped and it shut down. I arrived at my buddy's house earlier in the evening to what sounded like a bubbling/creak/gurgling sound that wasn't too loud coming from the fuel pump area of the car. Thought oh well and just turned the car off until it died on my way home later on.
    Car wouldn't start last night after it died. Starts today, throttle is very bogged down, no way I can drive it and after a few starts it now won't stay on. Pushed the button on my fuel rail and gas squirts out initially, but then doesn't come out at all.
    -Unplugged MAF, same response
    -Checked Fuse, it's still good
    -Fuel Filter replaced at about 40K miles, I'm now at 59K
    -Never any previous issues/symptoms, happened out of the blue
    -New Coils, Spark Plugs (not the problem)
    -Only Shell 91 oct. gasoline used
    There's a Fuel Pump recall on '03-Early '04 models, hopefully that's me. If not, I need to get the problem fixed ASAP does it sound like the fuel pump is bad? What else could it be? I'm not going to get an upgraded fuel pump, how much can I get an OEM replacement for??? Thanks in advance!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Bad Fuel Pump Diagnosis??? Need Help
    Sounds like the pump.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Sound a lot like the problem I had, see here:
    http://www.audizine.com/forum/showth...ight=fuel+pump
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 25 2007
    MA
    ^^Yup, that's the thread I'm basing my diagnosis on. Just looking for additional confirmation, or additional ideas for things I should check.
    Buncha motorcycles
    Memphis, TN
    does the car run now or not? when mine died, it just shuddered and bogged like you said.. no fault codes or anything. i noticed i didnt hear the pump prime itself when you turn the key on. so i took the back seat out and couldnt hear anything. i tapped on the pump a few times and it fired off for a second so...
    make sure you get a new gasket too! and hopefully your car is low on gas its just a few lines on top, and snap it out of the tank
    APR Stage 2/AWE Intake
    Apr 25 2007
    MA
    unfortunately i have about 3/4 of a tank left. any special tools needed to replace the pump? well the car will turn on, but it dies every time and i can't get the rpm's to rev anymore, it just bogs and shuts off. was yours covered under the manufacturers recall Papa? also how many miles were on your car when it happened?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by LampyB View Post
    was yours covered under the manufacturers recall ? also how many miles were on your car when it happened?
    Check your cars manufacturing date. It can be found at the base of the "B" pillar between the front and rear doors, drivers side. Apparently it only covered cars manufactured between September '02 and March '03. Clicky click
    Buncha motorcycles
    Memphis, TN
    No special tools, at least it shouldn't overflow (much) anyway. There may be some fuel line release and fuel pump tool but I got it done in 1.5 hours without
    Apr 20 2007
    Lander, Wyoming
    Long rubber gloves are essential with that much fuel in the tank.
    Also, a well ventilated area... like outside.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    thanks old guy for the info. anyway to find out if mind been replaced before since i bought it used?
    Apr 25 2007
    MA
    as far as a well-ventilated area it's going to have to be in my underground parking garage. the car would have to be towed out, it's an up-hill driveway. I'm going to get gloves, a painters mask, and a fan for the job. hopefully my neighbors won't get too pissed about the smell...
    also, what about the Walbro 255 fuel pump? i've heard this is compatible with our cars, but it looks totally different than the OEM fuel pump. Anyone have experience with this aftermarket pump? Fitment issues? Reliability?
    Quote Originally Posted by lookaught View Post
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    It shouldn't be THAT bad. I've done them with that much fuel left in the tank bare handed no mask no fan in my garage.
    You could always go with this pump...
    http://shop.dthaus.com/product.sc?ca...&productId=191
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    You can call or email AoA and give them your VIN to find out if you qualify for the recall.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by CO AVANT View Post
    Your life expectancy is no longer 78 it is now 77.
    Heavy duty blue rubber gloves were a fantastic addition to my garage. re-useable up to 2-3 times, and perfect for super messy jobs. Gasoline is a nasty liquid to get on your skin.
    Jon
    go > show
    Ich liebe mein Audi
    Feb 12 2004
    Everywhere
    Oh I'm sure I'll go before that
    I hear ya on the HD gloves though. I use the HD snap-on rubber or similar gloves now on everything since I tend to cut myself every time I work on a car lol. Those nitrile gloves you can buy at Home Depot suck and might last all of 10 seconds before I ruin them.
    Apr 25 2007
    MA
    too much money, i didn't plan on having the pump go bad so soon. and i'm selling the car, so there's no point in spending more on a pump than the standard OEM part.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    there should be plenty of used A4 pumps availabe for you to buy and they are cheap
    you should use a used 3.0 fuel pump since 1.8t and 3.0 use the same pump.
    3.0 pumps don't take a lot of stress like the 1.8t does so we RARELY have a failure.
    how soon do you need a pump? if you aren't in a rush I can sell you a cheap one.
    if you are looking for DIY guide then Dougy wrote one but it would be better if you only have less than 1/4 tank left
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Apr 25 2007
    MA
    i'm actually in a big hurry to get the part, realistically i need it today. i'm going to change the fuel filter first tonight, and see if that's the cause. if not, i'll do the pump afterward. i need the car for work every day though, so tomorrow is the last day i will be able to use my gf's car while mine is down. send me a PM with the price of your fuel pump if you'd be willing to ship it overnight today. thanks for the help guys, really appreciate it.
    May 03 2007
    german
    heaven/hell
    I don't think I can help you, sorry man.
    USPS and UPS, their services have proven to be unreliable, so even I pick overnight, I don't think you will get it tomorrow in time. they will give all kinds of BS. I don't want you to get screwed.
    It happened to me all the time when I needed parts right away.
    get on craigslist or other sites to find a junk yard maybe you will have some luck.
    you last bet is get ass raped by the dealership.
    good luck
