Results 1 to 11 of 11
    Veteran Member Four Rings GFRRS3's Avatar
    Dec 06 2007
    LI NY
    DIY Serpentine Belt REMOVAL & INSTALL
    ADMIN PLEASE STICKY!!!!
    This is for the removal and installation of the serpentine belt on 1.8T engine.
    Whats needed:
    1-18MM open ended wrench
    1-New Serpentine Belt
    Make sure car is cool/cold no reason to burn arm on upper radiator hose.
    Dont ask how I know.
    To remove:
    Take the 18mm wrench and push/pull on tensioner bracket.
    See picture Below.
    Loosen belt and work way down, removing belt top down.
    To install:
    Drape belt down and work your way up, I started with AC compressor then center roller (bit of a PITA) then I completed bottom, pull tensioner again and replace belt over Alternator and over top pulley. Make sure belt is aligned and make sure is facing correct direction(depending on manufacturer, logo facing away from engine or towards you).
    2017 - AUDI TTS
    2017 - PORSCHE 911 C2
    2019 - VOLVO XC60 R-DESIGN
    2021- AUDI A6 ALLROAD - SOLD
    2020 - AUDI RS3 - SOLD
    2006 - AUDI A3 - SOLD
    2005 - AUDI S4 - SOLD
    2004 - AUDI A4 USP AVANT - SOLD
    1999 - AUDI A4 AVANT GT28RS - SOLD
    IG- Greyfoxresearch
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: DIY Serpentine Belt REMOVAL & INSTALL
    Tip: Put the belt over the bigger pulleys first, leaving the smallest one for last.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 06 2007
    LI NY
    Quote Originally Posted by dirtybrd View Post
    Yup do the alternator LAST. THX.
    2017 - AUDI TTS
    IG- Greyfoxresearch
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    cool post. I actually need to do this next week. Thanks
    Jun 25 2007
    San Jose, CA
    When i was doing the timing belt i notice there's like a hole after you push the torque wrench, i just slide a screw laying around into the hole to hold the tensioner bracket. This techique gave me some time to unscrew the serpentine tensioner, i would imagine it would also give you a little more time to remove and install the belt.
    Senior Member Two Rings kbasham03's Avatar
    Sep 07 2008
    02 a4 1.8tqm, 91 Talon Tsi AWD
    Streamwood, Il
    Not to thread jack, but theres not supposed to be a bolt in the top of the tensioner bracket ?
    Ming Blue 02 1.8tqm // Hitachis // USP front // Apr 1+ //TT225 squirters // Podi // SouthBend OFE SS// Vmr Tp // Forge SpltR //Pioneer f700bt // Alpine Type R Components // 2 12" diamond d3s // Plasti Dip Blackouts // Shaved Emblems // 35% tint
    Dec 06 2007
    LI NY
    That doesnt look right....Looks like the tensioner is pulled to snug to the engine. That tab should clear those bolts without a problem. I double checked directions for 02 and its the same as 04. In other words that tab should pass infront of those bolts!!!
    2017 - AUDI TTS
    IG- Greyfoxresearch
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    There are only three bolts that hold the tensioner on and all three are visible in the pic. The tab is in its normal position. It is actually well below the bolts, it's just the angle that makes it look different.
    Sep 07 2008
    Streamwood, Il
    Ok thanks for clearing that up Old guy, I thought I was missing a bolt.
    Dec 06 2007
    LI NY
    By that picture it looks like the tab was hitting the bolt....THX oldguy!!
    2017 - AUDI TTS
    IG- Greyfoxresearch
    Jun 22 2009
    Dundalk, MD
    Also, there is a "gatorbelt" that works better than the OEM belt. The design is awesome and it got rid of my squeaking for ~20k miles
