Results 1 to 29 of 29
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Cut bump stops on coilovers??
    My ST coils just arrived today and have seen in a couple threads of ppl cutting down their bump stops...is this nessecary? i mean i dont plan on being silly low but should i still do this...if so how much?
    thanks
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Cut bump stops on coilovers??
    I wanna do this too, I guess I kinda know how to do it, but does anyone have pics?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings auditech79's Avatar
    Jul 18 2007
    00 A4 1.8T
    Elk Grove, CA
    Its best to cut the bump stops. The stasis (koni) coilovers i had for my S4 said right in the instructions to cutt at least 1/2 of it off. I never bottomed out so i guess it worked pretty well.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    If you cut them don't cut them too short. You're always better off bottoming on the bump stops then bottoming out the shock piston.
    The ST's have reasonably stiff springs so if you aren't dumping it then you shouldn't ever bottom out.
    Jim
    I Do Werk.
    Jun 04 2007
    Austin/DFW, TX
    EX
    My 5-Speed Swap DIY
    - B6 USP
    Aug 25 2008
    rhode island
    so whats the verdict...cut like 1/4 off?
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    i cut mine right in half, where that groove is.. but im pretty low and i still havent bottomed them out
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by pacman View Post
    Nice, I guess I need to do that! Would you say the ride is more comfortable?
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings VirginiaBeachA4's Avatar
    Mar 15 2009
    Virginia Beach, VA
    so, you all might not like this but remember beauty is in the eye of the beholder and each person does things to their likings. so with that said, i plan on going stupid low. like 3-4" of the ground low, how much bump stop would i have to cut off?
    '99.5 Jaspis Green (Minty) 1.8TQM
    - Forge diverter valve
    - vmaxx
    - Merc Alphards
    - resonator removed
    - K&N cone filter
    Apr 25 2007
    millersville, maryland
    I'm around 3 inches right now maybe a tad more on the STs and have yet to bottom out.. without any cutting of the bump stops
    Nov 06 2006
    garage ornaments
    southeastern pa
    Quote Originally Posted by biketsai View Post
    well, my car is 22.5" ground to fender, and i have 35 series tires, so comfortable is a relative term.. but i would say that my car rides pretty good for as low as it is
    -Nic
    My Car
    Aug 25 2008
    rhode island
    so uhhhhh im gunna cut mine in half i think. what did yall use to make a clean cut?
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    dude I LOVE your car... man sooo low too
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by dcampana View Post
    X2, I cant even imagine trying to drive your car.
    If I cut the bumpstop, wont the tire be more likely to rub the fender now??
    My 5-Speed Swap DIY
    - B6 USP
    Nov 06 2006
    garage ornaments
    southeastern pa
    do you hit the bump stops now ?
    i just used a hacksaw to cut mine, they are only a soft foam
    -Nic
    My Car
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I used a table saw to cut the straight part off of mine (~1/2")... wouldn't recommend the table saw, it was a little sketch. It worked though!
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by wesleyfbm View Post
    I put them in the vise just tight enough to hold them and then use a sharp knife (long bread knife) to slice across the tops of the vise jaws. Just set them up and cut them up. Be sure to look at which end goes into the upper strut perch before cutting.
    Jim
    I Do Werk.
    Aug 25 2008
    rhode island
    so here is the front one. should i just cut the actual yellow part in half??
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    whats the advantage of cutting the bump stops?
    Aug 25 2008
    rhode island
    less of chance to bottom out...get more clearnace with less bumpstop.
    Jun 04 2007
    Austin/DFW, TX
    Hmm, I feel like I hit them occasionally but my suspension is rather stiff at the same time. For as low as I am 24.5" gtf I have never rubbed on the street or even after 3 track events.
    My 5-Speed Swap DIY
    - B6 USP
    May 07 2007
    meh im over 25" GTF, im good, lol.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    How do you know when you bottom out? How does it feel like? thanks!
    TEAM|AXION
    Nov 06 2006
    garage ornaments
    southeastern pa
    you'll know it
    -Nic
    My Car
    Mar 26 2005
    ^ so it's kind of like a blown turbo? Sound can't really be explained but you'll know it when it happens? :| haha I hate those answers :P
    TEAM|AXION
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by speedydragon View Post
    Lol, well you just kinda haev to experience it. It almost feels like hitting a REALLY bad pothole.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 06 2006
    garage ornaments
    southeastern pa
    if some one were to take hammer, and smack the inner fender... im pretty sure it would sound about the same
    -Nic
    My Car
    Aug 25 2008
    rhode island
    so how do i get the black boot off my front bumpstops on the ST coils?....they are in the groove pretty good and dont want to crack the plastic.
    Mar 09 2004
    nw michigan.
    Pull, twist, and pry. A little lubrication helps.
    Jim
    I Do Werk.
