Results 1 to 40 of 40
    Jun 17 2009
    North Jersey
    Minor Frame damage... possible repair? *pic*
    so what do you think, can i get it close enough to straight so when the bumper goes back on it doesn't look like shit if i use a heavy duty come-a-long, a lever of some sort, a large tree, and a hammer? Or do i need a body shop to get this straight? Cause I'm very tired of waiting for my body shop guy to come and pick up the car and I really don't want to spend alot of money.
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: Minor Frame damage... possible repair? *pic*
    I know nothing about body work so I say take it in
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Senior Member Three Rings PoormansA4's Avatar
    Mar 26 2009
    Wildomar,CA
    I probably wouldn't fuck around with stuff like that even tho it isnt that bad
    For sale
    wiring harness 01 1.8t
    map sensor
    stock injectors
    fuel rail
    stock FPR
    brand new front and back rotors (quattro)
    Audizine Senior Editor Four Rings Richard's Avatar
    Jun 16 2007
    Broomfield, CO
    find a local frame streightener....do not attempt to do this yourself.
    Project: 2019 Audi e tron Edition One Prestige, Daytona Grey
    Daily: 2019 Audi e tron Prestige, Glacier White Metallic
    GONE: 2002 Audi S6 | 2013 Audi A6 TDI | 2006 VW Touareg V10 Twin Turbo TDI | 2001 A4 1.8T Sport
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    ^ What he said!!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I wonder what the process entails, and the cost!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Aug 13 2008
    Indiana
    Problem is the frame damage most likely goes deeper then meets the eye. If it bent that part that much what about the part where that bar connects? Just getting the frame straightened is honestly not even that expensive compared to body work.
    -Nic
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That will probably need a frame rack. If you try using a tree and come-a-long your car will just slide bit by bit towards the tree.
    Jim
    I Do Werk.
    Aug 13 2008
    Indiana
    Quote Originally Posted by onemoremile View Post
    I have had success on old junk cars w/ a chain and bolting the chain to the part then yanking really hard w/ our Jeep hahaha.... I don't recommend this method.
    -Nic
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by biketsai View Post
    Secure the car on the rack
    Take measurements and compare to database's nominal measurement.
    Pull on bent part.
    Measure, compare, pull, measure, compare, etc.
    Frame racks look a little like boxing rings with a winch for a turnbuckle. My car had similar damage but about twice the deflection. It was about 2-300 to have it pulled straight.
    Jim
    I Do Werk.
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    when it comes to frame damage you would be amazed at what 2 mm off can do to the tracking of the car. leave it to the professionals. As Jim says, you need a frame rack for this one... make sure its 100% straight. Also the fact that its a main rail can cause deficiencies if involved in another crash...
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Established Member Two Rings AWD Mike's Avatar
    Oct 19 2008
    '14 Tacoma TRD Sport | '14 SQ5 Prestige
    Richmond, VA
    I concur.
    I thought I had bent my frame straight on my last car after the accident, sure enough, although it looked straight, it was not even close.
    Take it to a reputable place.
    Jun 04 2007
    Austin/DFW, TX
    Any pics on the damage on your car?
    My 5-Speed Swap DIY
    - B6 USP
    Jun 17 2009
    North Jersey
    Yup, forgot to take them when i first got the car home. The hammer was there cause i fixin things...
    Established Member Two Rings SevakTM's Avatar
    Oct 16 2008
    B6 A4 1.8TQM
    OC/LA, CA
    this needs to be set up and measured... if u pull it the frame too much there is ultimatley no way to fix it 100 % as it was before
    Tolerico's Body Place: "For the person whose car is more than just transportation."
    Need any of the following services?
    -Collision Repair
    -Paint / Body Work
    -Mechanical Services / Repairs
    We work with all insurance companies.
    PM or E-mail me with any questions.
    Senior Member Three Rings ed1380's Avatar
    Mar 16 2009
    ATL
    had that on both frame rails. chained the rear to a tree. winch from various points on the bumper shock to the bobcat. heat then winch some and heat some more. repeat. alot easier with 2 people. i have a b5.5 passat i can take measurements from if you need
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    That method is probably going to end up destroying the bumper shock. Try to track down a frame rack.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    yea this is something you absolutely cannot do with a tree a chain a torch and a bobcat.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by arorem View Post
    You do it with the bumper shock removed.
    I've got extras if anyone needs a couple anyway.
    Jim
    I Do Werk.
    Mar 16 2009
    ATL
    say what you want. thats what i did. of course it didnt happen in one day and the bumper shock was already damaged. it was needed for lateral force. and i had another vehicle just like it for measurements. its pretty much 99.9% to factory specs
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by ed1380 View Post
    say what you want. thats what i did. of course it didnt happen in one day and the bumper shock was already damaged. it was needed for lateral force. and i had abother vehicle just like it for measurements. its pretty much 99.9% to factory specs
    Lol, tree.
    My 5-Speed Swap DIY
    - B6 USP
    May 12 2008
    Flagstaff AZ
    fuck it use the tree its way more fun!
    Mar 16 2009
    ATL
    yall might be laughing at me but i know it was done right. not halfassed by someone at the shop. ive been around the auto repair scene for a while
    Nov 01 2006
    Nor Cal
    but you did say it is 99.9% at stock spec. i persoanlly would take to a reputable shop that gurantees the work to be back to 100% stock. that .1% can make a big difference on the drivability, the impacts (should a crash happen), tires, braking, ect... sometimes saving money upfront causes more in the future....
    just my opinion...
    Mar 16 2009
    ATL
    yeah and germ-x kills 99.9% of germs too. that seams good enough
    Established Member Two Rings SlipAngle's Avatar
    Jul 17 2008
    08' A4 S-Line 2.0T 6spd
    Boston
    I had a 97' that was involved in an accident before I bought it. About 4" had been cut off the supports and new 4" sections welded on.
    That would be the best way.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by SlipAngle View Post
    I like the idea of that, but I wonder what would be stronger. Pulling it back out? Or welding a new piece. Welding a new piece seems easier.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 01 2006
    Nor Cal
    yeah true to a degree.
    whatever works for you, eh?
    Veteran Member Three Rings stormscr3's Avatar
    Jul 08 2008
    2011 Ford Edge
    MA
    HAHA Damn Straight
    Jun 04 2007
    Austin/DFW, TX
    However, there is a reason why it is 99.9%. C'mon guys, its simple science.
    My 5-Speed Swap DIY
    - B6 USP
    Mar 09 2004
    nw michigan.
    You are better off pulling it then welding in new pieces. They crumple because they are supposed to. Anything stronger won't dissipate the loads as intended in an accident. That looks like an easy job for a body or frame shop. It is probably quicker and easier to pull it then to cut and weld accurately.
    Jim
    I Do Werk.
    Mar 16 2009
    ATL
    Quote Originally Posted by dcampana View Post
    yeah even factory spec is allowed to be off by a couple millimeters
    worked great and saved loads of cash
    Oct 24 2017
    Delaware
    I'm in a similar situation with my frame being like that. I have it on a frame machine but they can't locate the original measurements. Does anyone have them so I can relay the message lol
    Jun 30 2008
    Erie, Pennsylvania
    Just pull till it looks "a'ight".
    (Sorry, can't help with factory measurements. All I've got are jokes).
    Oct 24 2017
    Delaware
    Do you think the Bentley book will have them?
    Jun 30 2008
    Erie, Pennsylvania
    No. I don't think it would be in the regular repair manual. It would be provided to shops in the Audi authorized collision repair program, or would be published in the aftermarket, such as the Mitchell Import vehicle dimensions manual.
    Established Member Two Rings HumbleTurbo's Avatar
    Mar 28 2017
    Holland, MI, USA
    Remove bumber shock, zip-tie entire front frame and various body parts so it looks decent, daily it.
    Jun 30 2008
    Erie, Pennsylvania
    ^Basically this.
    Personally, as long as you can get it close enough to lie about, you're fine. The only thing that bolts to the frame horns is the bumper shocks (which have oversided sloppy holes) and the lock carrier/radiator support - which also has a bunch of slop. Pinpoint accuracy on this piece is really not that critical due to all the adjustment Audi gives from the factory. And you can even widen out the holes a bit if you need a little more. Even then, getting it perfect would be more for cosmetic reasons. As long as the frame horn is all there, and the the bumper is bolted up, you're good. A quarter inch isn't going to make a difference in an accident.
    Oct 24 2017
    Delaware
    ^Basically this.
    If I could figure out how to post a pic of it I would. It got impact on the drivers side so it's like the frame is pushed towards the passenger side. I'm going to tell him to just pull it until the bolts line up. I just was t sure if it'll be noticeable if it was off. You know how some cars crabwalk and look stupid I just wasn't sure
    Jun 30 2008
    Erie, Pennsylvania
    The suspension is not tied to the frame horn. It's tied the shock tower and the subframe. Since it's been knocked around, just throw it on an alignment rack when you'r done and check it out. If it's out of spec, you just slide the subframe until it evens out. Again using the factory bolt slop FTW.
