Results 1 to 12 of 12
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    ARP 11MM head studs are finally sorted out and ready to ship!
    Finally! For real this time, these are done and ready to ship. We just received the replacement nuts in yesterday after the "diameter too big" fiasco. These ones are confirmed to fit and work, and they are ready to stock. These 11mm head studs are available from ARP for AEB and other 1.8t applications! We just got these IN STOCK here today and made them their own little spot on the shelf, but they are ready to ship! This is an ARP 2000 stud kit with custom nuts just like the 10mm parts. They will work in all early 1.8t's that used an 11mm bolt. They are also an option for those making BIG power and worried about lifting your head, you can chase the 06a block out to 11mm and run these bigger studs.
    Picture does not show it, but it DOES include the ARP Moly Lube pack as well. I just hate those white packages on white backgrounds... :)
    ARP 11mm Head Stud Kit $199.99
    ARP 11mm Head Stud Kit with Tool $229.99
    Thanks guys!
    Pete
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Aug 14 2008
    Salt Lake City, UT
    Re: ARP 11MM head studs are finally sorted out and ready to ship!
    Bump for 11mm head studs from ARP!
    Mar 24 2009
    98.5 A4 1.8TQ Tip
    Carlisle, PA
    I thought there was a lot of anticipation for these things. I mean, I don't need them but still, show a little interest.
    Or maybe everyone's just buying them and not bothering to post anything, who knows.
    Anyways, bump.
    "gutting the cat makes the turbo loudddd.. everyone in my work complex thinks i'm bt. little do they know a minivan could dominate me." - CrtchRktRcr
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i thought they were coming out with ARP Bolts? Just like the OEM bolts but ARP 2000 grade bolt??
    Anyways this is a GREAT addition for anyone doing engine work. I wish these were out a year ago. I went through SOOO many sets of OEM bolts... :-(
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Aug 14 2008
    Salt Lake City, UT
    I thought so too, but these showed up first? Who knows... ARP works in mysterious ways :)
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    what is used to drive these, #10 polydrive? and what is the torque spec?
    let's see... shaved valve cover, '52 cams and these head studs -and of course the main girdle
    -as soon as I'm up and running
    Aug 14 2008
    Salt Lake City, UT
    It's a triple square, not the poly drive... Hahaha... Torque spec is a whopping 95 ft-lb! That will hold some *stuff* down.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    yeah these studs look just like the raceware set I run, but it looks like ARP are priced much lower.
    95 lbs, wow. I am putting my head back on right now and the raceware are only 55 lbs which seems pretty low seeing that I am pushing 37 psi for boost.
    Aug 14 2008
    Salt Lake City, UT
    I have them both in stock, these are way nicer then the raceware... I think anyways, and that difference in torque specs does have me second guessing the material of the raceware studs as well.
    I read the instructions carefully twice for the racewares and they claim their studs are coated in a special anti friction blah blah so they only require low torque... I find it hard to believe it could really be that much lower friction then the ARP Moly lube.
    Oh well.
    Pete
    Aug 14 2008
    Salt Lake City, UT
    Thanks for the orders guys!
    Pete
    Veteran Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    ARP >>>> Raceware
    I've seen the raceware easily snap at 50ft-lbs
    Aug 14 2008
    Salt Lake City, UT
    For sure. Racewear guys are wierd too they won't make their price or their product competitive, I'm not sure quite what their plan is really? LOL
