Results 1 to 10 of 10
    Jun 21 2009
    Honolulu, Hawaii
    Speaker Replacement Size - B5 A4 Avant
    Hi,
    I've done quite a bit of searching and come up with some conflicting information. Basically, I am looking to replace my two front door speakers. I am looking to install two-way coaxials rather than a component system (and leave the stock tweeters in place).
    So my question is: what size speaker will be the right fit for the front doors of my B5 A4 Avant? There is information that states it is a 4-inch and also that it is a 5.25-inch fit... I want to do the least amount of cutting/modifying so which is the better match is fine. Also, if anyone has info on the rear door speaker size, I'd appreciate that as well.
    Jun 21 2009
    Honolulu, Hawaii
    Re: Speaker Replacement Size - B5 A4 Avant
    One more thing...
    I have the NON-bose system...
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    5.25 fit pretty well. Are you using a set of components or a full range speaker?
    CHeck here for ideas
    http://www.audizine.com/forum/showth...=speaker+mount
    -06 A4 2.0T
    -97 A4 1.8T
    Jun 21 2009
    Honolulu, Hawaii
    I was going to use the two-way Infinity Reference series (either 4- or 5.25-inch) co-axials... and just leave the stock tweeters in place. I know this leaves me with "extra" tweeters, but oh well. Best Buy and the Pioneer website both tell me that 5.25-inch is the way to go, but I read in multiple places, that 4-inch was the best fit.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    yeah 4 inch will fit better without a question, but why not get the bigger speaker if you can still fit it without trouble?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by Kronic Budz View Post
    Your car will sound better with a proper 4" mounted, than having a larger 5.25" just hanging without a baffle. You have to use strip caulking/sealant to seal the edges of the 5.25" (or other side) driver, otherwise it will sound very empty and bottom out...even in a IB/Free-Air environment, this is very important.
    Jun 21 2009
    Honolulu, Hawaii
    OK, for the fronts gonna get the 5.25-in speaker adaptor here:
    http://caraudiosecurity.com/shop/pro...oducts_id=1883
    It's under $40 including shipping from the UK. Hopefully, that'll give me a good, snug fit, with minimal hassles.
    Still unsure about the rear door speaker size... anyone??? I have a 2000 A4 Avant (non-Bose Symphony system). Guess I should just get in there and look, but if anyone knows, please let me know what size will work... can't find adaptors for the rear doors, so I'm thinking it'll be a 5.25-inch fit with the original baffle/OEM adaptor, but I'm not sure.
    Oct 01 2007
    1997 A4 2.8 QM
    is that for both sides? Is it really necessary to get best performance and reliability by having a 5.25 in the front? Is this for sedan to?
    Jun 21 2009
    Honolulu, Hawaii
    Yes, that's for two adaptors (both sides). I was hoping to get bigger/better sound with the 5.25's (as opposed to using the 4's), hence my decision to go that route. Plus, the Infinity Reference series costs the same on amazon.com for both the 4's and the 5.25's... why not go for it? As the title of the post states, I have an Avant, not a sedan.
    Feb 23 2021
    2001 Aud S4 (B5) avant, 2002 Subaru Impreza WRX STi sport wagon
    Christchurch
    I know this is a very old thread but I just made the mistake of buying 4" and 5.25" speakers for my B5 Avant (non-bose) based on info I had found on forums and such.
    The front 4"s kind of fit (marginally too small for the original speakers surround) but the rear door speakers look to be 6.5"...
    Guess I'll use the 5.25" up front and find some suitable 6.5" for the rear.
