Results 1 to 13 of 13
    Account Terminated Two Rings
    Jan 06 2008
    Frisco 415
    Thumbs up Removing scratches from Metal dash
    I noticed bunch of small scratches on the metal / aluminum dash.
    Also - i have bunch of scratches on the metal part - the thing that opens up to expose place for coins and cig lighter.
    They are minor but visible on the reflective aluminum dash.
    Any ideas on how to go about removing them? I tried the rubbing compound that is working on the exterior of the car - for clear coat scratches - and that didn't do anything..
    Please if anyone knows - share your solutions!
    Veteran Member Three Rings stormscr3's Avatar
    Jul 08 2008
    2011 Ford Edge
    MA
    Re: Removing scratches from Metal dash
    Wet-sanding with 2000 grit sand paper
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    I think they're actually plastic or at least plastic coated. I used this stuff called displex once to remove scratches on a laptop sceen. Worked like a charm!
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    The aluminum trim is actually real aluminum in our A4s. If it scratches you are done. Stealership is the only place to get replacement aluminum molding... and it is $$$$!
    My girlfriend put a few light scratches in my cig lighter cover too... so frustrating.
    Lover of all things motorsport, powersport, sport.
    Mar 29 2008
    Costa Mesa, CA
    ECS has this piece... it is pricey...
    http://www.ecstuning.com/Audi-B7_A4-...r/Trim/ES9071/
    Dec 01 2007
    Markham, Ontario
    zagg - apple sauce
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Veteran Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    Quote Originally Posted by greene08 View Post
    125 dollars . is that for real?
    Established Member Two Rings marcl's Avatar
    May 26 2008
    Sheffield, UK
    Quote Originally Posted by dblock110 View Post
    AutoGlym do a scratch and scuff kit, it comes with what they call a "magic sponge" you can get the sponge on ebay for a few pounds.
    might work might not......cheaper than $125!!!
    07 A4 B7 2.0TQ Final Edition. Misano Red
    Inside...RNS-E, Rainbow Comp Front & Rear, JL Sub, Hertz Amp, Alcantara Wheel & Shift, RS4 Pedals, FBluetooth, Colour Trip.
    Outside...Full S-Line Styling, S-Line Spoiler, Votex SideSkirts De Chrome
    Under the Bonnet...Awe BT Kit, AWE FMIC, HFC, Milltek, Evoms Intake, Evoms Diverter, GIAC, Apex Springs, S4 brakes
    On The Way...Rods, Pistons, W/Meth, cams, AWE Boost Gauge... then ...
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    It's aluminum alright...and I've got all kinds of tiny scratches and even a small ding in mine. Looks crappy, but we (owners) are probably the only people who actually notice...
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Senior Member Two Rings intonation's Avatar
    Apr 09 2008
    Lawrence, KS
    Quote Originally Posted by stormscr3 View Post
    have you actually tried this? i'm thinking since it is in fact aluminum, this might be the way to go. kind of scared to try it on my fishcale alum trim...
    Jan 06 2008
    Frisco 415
    i didn't try the sand paper yet. though it seems reasonable. i will go to home depot which is on the same plaza as pepboys - will see who has 2000 grit.. i hope it works, i will report what will happen later.
    Thanks for all the ideas!
    Apr 09 2008
    Lawrence, KS
    Quote Originally Posted by mr.eugene View Post
    Cool, keep us posted. I might also try it on a out of the way spot like the rear ashtray cover. Only concern is that some of the scratches in the front look pretty deep - not sure they will be fixed with surface sanding. Still worth a try!
    Veteran Member Three Rings ElectroMike's Avatar
    Apr 17 2009
    2014 S4 M/T
    Exit 160 NJ
    Since we're on topic of alum trim, is there a DIY on how to remove it?
    I also have little scratches above the driver side door handle and might do the 2000 grit wet sand but would want the piece off the door first!
