Results 1 to 10 of 10
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    2010 S4 tuning potential
    How tunable will the S4 be and how much power can realistically be extracted from the new supercharged motor? Was browsing around and found a tuner in Germany claiming over 400 hp with almost 400 lb/ft of torque for the new S4.
    Feb 17 2004
    Sterling, VA
    Re: 2010 S4 tuning potential
    Well the current output for the S4 will be 333HP/324Lb.Ft.
    You can definitely pass 350HP with software alone. The question is will a pulley upgrade be possible so that they can raise the boost.
    If they can change the pulley, then you're looking at a lot more possibilites with very minor changes.
    The only limiting factor I have seen is that the intercooling is built into the stack between the supercharger and the intake manifold. If that intercooler is just big enough for the stock boost levels, it will suffer under increased boost.
    Part #23 are the two intercooler cores.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    You start entering dangerous territory when you start talking about pulley swaps. Just going from (fictitious numbers as I don't know the pulley size on the 3.0 SC engines) a 3.4" pulley down to a 3.2" pulley would make significant gains....but perhaps at the expense of some of your engine's vitals.
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    May 21 2008
    Here's the link to the German site. The English version does not work, but the numbers are impressive. Looks like there are 3 stages: http://www.bb-automobiltechnik.de/bb..._v6_30tfsi.php
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    May 30 2009
    Montreal
    The Mtm looks like a super deal. How can we in this side of the pond get hooked up with this?
    Also would this void the warranty?
    May 21 2008
    Quote Originally Posted by scottyuk View Post
    424 hp RS4 killer
    Sep 20 2006
    Essex, UK
    Quote Originally Posted by montrealspeed View Post
    Only if something breaks because of it.
    Senior Member Two Rings psiaddict's Avatar
    Feb 26 2008
    Milwaukee, Wisconsin
    translate.google.com if you want to read it. You can navigate and it continues to translate.
    Translated Page
    '01 S4 Stage 2 Imola/Alcantara +sport pkg
    Jun 04 2009
    San Diego
    This was interesting if you havn't seen it already:
    http://www.youtube.com/watch?v=Tfoa2VO8c6E
