Results 1 to 15 of 15
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    How many layers of carbon fiber weave?
    How many layers of carbon fiber weave "should" go into a body part made of CF?
    Oct 06 2004
    Minnesota
    Re: How many layers of carbon fiber weave?
    Most companies who are making hoods are using fiberglass mat 9several layres, then overlaying CF on top of that. If you are vacuum bagging molds of fenders or hoods, i would suggest at least 5 layers of weave.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jan 17 2007
    Hmm, I've got a hood I can see through...
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That isn't right. My Vorsteiner has one good layer for the vents, maybe another for reinforcement under the rest of the hood, and then a layer of honeycomb reinforcement.
    Of course, it still cracked.
    Jim
    I Do Werk.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Make sure each layer is criss-crossed too for structural purposes.
    Mar 09 2004
    nw michigan.
    think of it as plastic plywood.
    Jim
    I Do Werk.
    Jan 17 2007
    Right, my point being that I probably should not be able to see daylight clearly through the resin from one side to the other.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by DND View Post
    correct
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    The parts only need 1 layer of CF for the outer skin. The frame work will need multiple layers of CF or FG.
    I can see right thru my Fiber IMages Hood, trunk, fenders and doors when you put a light behind them since they are just 1 layer of CF.
    Jan 17 2007
    So then what you really have is a body part made of resin with the CF serving only for aesthetics and to prevent disintegration when it breaks?
    Oct 06 2004
    Minnesota
    One layer without reinforcement is like paper. You can bend it with your hands.
    Instagram r_michals
    Jul 07 2004
    socal
    Quote Originally Posted by A4Rob View Post
    CF is meant to bend and flex, it is the gel coating that cracks if it is bent too far. The frame is the reinforcement. When using fiber glass it should be layered to increase strength.
    Mar 09 2004
    nw michigan.
    That is the nature of composites. I've even used t-shirt fabric for moldmaking. It cuts easily and even tears.
    Carbon fiber, kevlar, fiberglass, FRP, etc. are fibers saturated in and encased in plastic. More layers saturated in resin means less flexibility and more strength. Real strength comes from the frame and curves have more rigidity than other shapes.
    Jim
    I Do Werk.
    The hoods I will be making for the B8 will have a total of 7 layers of carbon fiber and be one solid piece that wil never need hood pins or delaminate.
    The process we will be using wil have the upper skin laid up with three layers, then the lower frame will be four layers, all 6.5oz.
    The two layers, in thier repective molds, will be sandwiched together (with extremely lightweight calibrated foam in the voids where the inside frame is off of the hood).
    Once the molds are sandwiched and sealed, the resing will be injected in and vacuumed out, the mold will then be autoclaved (heat and pressure) and the part will be fully cured in less than an hour.
    Molds are then removed and the foam is melted out with solvent. The end result is a hood that is one solid laminated piece that can withstand hundreds of miles an hour speeds with very little flexion or distortion.
    Jan 17 2007
    Wow, sounds nice.
