by Michael Hammond and Daniel Sekijima
[edited by a4darkness aka noti]
Every time I see a post about dual rear fogs, I always think about the fantastic write-up stashed away on my HD... not doing any anyone any good.
But, it needed some polishing. So I cleaned up all the text, hosted the images and here you are. Again, thanks to Michael and Daniel for their efforts.
Summary
These steps will show how to tap off of the left side fog light to power the right fog light creating duel fog lights. If this procedure is followed correctly, it will not cause conflict with the computer or tail light monitors. No warnings or errors will show when u start the car.
Required Tools:
Also needed is a wire, about 6 feet in length(This should be more than enough, and there should be some left over.)
A 12 gauge wire was used for this write-up.
Note: Although the tap splicer as shown fits an 18-22 gauge cable it was jammed into the wire in for a tight fit with no issues.
Step 1
Empty the trunk + remove the spare tire and and take off the carpeting as shown.
(Ignore the extra wires, they are for speakers/amps)
Step 2
Locate the two screws found inside the spare tire well.
Step 3
Remove the screws with a 10mm wrench. This will make it possible to remove the black plastic trunk guard.
To fully remove this piece, pull up were the arrows are shown in the picture above.
After removing the plastic trunk guard, this is what you'll see:
Step 4
Locate the carpet circle plugs on both sides of the trunk. Then remove the screw as shown in the picture below.
FYI, these screws attach to the tail lights.
Step 5
Now that the screws affixing the tail lights have been removed, begin to pull out the tail lights.
Proper tail light removal is like pulling a book from a shelf. Keep the outside part hinged and begin pulling outwards with the inside part of the housing.
There will be green plugs connecting the tail lights to the wiring harnesses.
Step 6
After removing a tail light from the car, detach the green plug that is connected to the tail light. This will fully detach the housing from the car. (Do this for both tail lights.)
After the left housing has been removed off take notice of the bundle of wires.
Locate the wire that is grey w/ a white stripe in this bundle.
This is the wire that will be spliced to tap electricity to the right fog light.
(1) This is the 12 gauge wire, mentioned above, that will be used to run power from the left side to the right side.
(2) This is the grey w/ white stripe wire The flat head pliers, shown above, were used to crimp the wires in the splicer.
Step 7
The picture below shows separating the carpeting on the right side of the trunk.
This is how access is gained to the tail light wire bundle.
This will need to done on both sides.
Step 8
(1) Slowly work the the 12 gauge wire (red wire as shown) through the rubber seal.
An effective technique to accomplish this is the use of a screw driver to pull back the rubber seal.
Doing this will feed the wire behind the carpeting as shown in Step 7.
Place your hand into the area created by separating the carpeting from the trunk wall and feel for the 12 gauge wire that is being run through the rubber seal.
(2) Pull it all the way through so it is loosely following the original bundled wires.
Step 9
Work the thin flexible wire through the rubber seal on the right as you did with the 12 gauge wire on the left side.
Pull it through so it can be seen as in (1) and (2).
Step 10
Attach the thin flexible wire to the 12 gauge wire by taping the wires together and twisting or bending them together to make sure they stay connected.
[A coat hanger can be used for the 'thin flexible wire here.']
Step 11
Pull the thin flexible wire through the rubber seal until the 12 gauge wire has emerged through the hole.
Step 12
Cut the grey w/ white stripe wire leaving 4-5 inches of extra space
The extra space is just in case the splicing of the two wires doesn't go quite perfectly.
Step 13
Splice the red 12 gauge wire and the wire just cut together, with the same splicer used as before, and you should be good to go.
Step 14
Reverse the tear-down procedure as detailed above.
Connect the green plug back into the light housing and remember to use the book from a shelf technique when reinserting the light housing.
[editor's note: This might be a good time to test and see if all the wiring has been configured correctly as re-removal of the carpeting and trunk pieces would be a bit annoying.]
Use some force to both readjust the carpeting back on both sides and to bolt the black plastic guard back down (listen for a pop or snapping sound to signify the guard attaching correctly)
And don't forget to screw the tail lights back in. Then put spare tire + carpeting back in and please the following disclaimers + info
[begin editor's addition]
There have been some very 'colorful' threads on most Audi enthusiast forums concerning the use of dual rear fogs. Okay, some have been downright nasty. Maybe you've been witness to one? Lobbed the obligatory grenade?
That said, regardless of anyone's personal opinion [including my own], as I'm [re]posting this DIY [which BTW I take zero responsibility for... please mod at your own discretion, thx], I feel inclined to also include some additional thoughts concerning this mod in hopes of quelling the omnipresent comments that emerge whenever this topic is mentioned. And rather than directly quoting, as to not drag anyone into this, I'll simply paraphrase what I believe to be worth mentioning... be it negative or positive and leave it at that.
* Having both fog lights illuminated is often perceived as 'brake lights being on' which can be confusing / annoying / dangerous to other drivers.
* The purpose of a single left rear fog is: during times of poor weather / low visibility, it acts to warn vehicles approaching from the rear that there is another vehicle ahead of them and / or to appropriately signal to which side is ok for the approaching vehicle to pass on.
* The use of a single rear fog light is used commonly / primarily outside of the US.
* Many law enforcement officers are not familiar with the concept or use of a single rear fog light and will often perceive there to be a non-working tail light on said vehicle. Many have been pulled over and some even issues citations.
* The use of dual rear fog lights in the US is legal if, between brake and fog lights, there is 10 cm of space. The B6 A4 does not have this required spacing.
* A good rule of thumb for B6 drivers with single or dual fogs... use them only as necessary in the most inclimate of weather or visibility situations.
