Results 1 to 12 of 12
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Boost pressure sensor was the problem!
    So for months now, I have had this problem. If i slammed the gas to the floor, the car would shutter and bog for a second, then it would pick up and go. BUT, if i pushed the gas to the floor a little slower, let the rpms build up, THEN i could punch it and it would go fine.
    Idled fine, 20vac, WOT was fine, a solid 21psi. only other problem i would see is that the boost would creep up unless I floored it, and the car ran very rich (backfired a shit ton)
    I did some basic trouble shooting and realized at WOT, the fuel and ignition is controlled by the ecu mapping which would explain why the car pulled normally at WOT. THEN, since partial throttle driving is controlled by various sensors like the MAF, and MAP(boost pressure sensor on the TBB) i realized it had to be sensor related. narrowed it down to the boost pressure sensor, replaced it, and I'm back up and running!
    Feels great to be back lol
    ThorTechnik.com
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Re: Boost pressure sensor was the problem!
    Where did u get the sensor, how much was it and how hard was the install? Glad ur car is running good again!
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by DannyDeez View Post
    The MAP sensor like he said sits on top of the throttle body. Not hard to install at all. Unfortunately, it's not that cheap either @125 bucks or so...
    08 S4- Stock SOLD
    Mar 07 2007
    Belmont, MA
    brookline audi quoted me $233 for it, but got it from a local shop for $120
    ThorTechnik.com
    Sep 11 2004
    16 Q5
    Westchester, NY
    Thanks. Does anyone know where to get it or a part #? I cant find it listed for the S4 anywhere.
    Jan 29 2007
    08 S4 00 S4
    MD
    078906051.
    08 S4- Stock SOLD
    Sep 11 2004
    16 Q5
    Westchester, NY
    Sweet thanks for helping my laziness! I know I could have just pulled the plastic cover over the TBB and found it.
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by mholme View Post
    078906051.
    that is the correct part number, however my shop could not find it. we ordered one that looks exactly the same, just a slightly different part number. I will post later which one i got
    ThorTechnik.com
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by S4evr View Post
    Any update on which one you got?
    Jan 29 2007
    08 S4 00 S4
    MD
    Maybe it was the Bosch part# he got, unless it was a chinese knock off. I'm fairly sure that sensor is not shared with any other engine besides the 2.7T and 078906051 is the part number.
    08 S4- Stock SOLD
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Good to hear you solved the problem. Sounds like one of those that will drive you mad.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Its about time you figured it out. Im glad you got it and are enjoying it now.
