Results 1 to 35 of 35
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Fender to Ground, Where do you stand?
    This thread could be somewhat useful I think. We can consolidate all the ride heights into here for refrence.
    Post a pic, and your fender to Ground height.
    I know as of right now im sitting at 23.25F and 23.75R.
    Wheel info. F are 18x8.5 +40 Kuhmo Ecsta MX, R are 18x8.5 +32 Kuhmo Ecsta MX
    Unfortunately I finished my coils last night around 10 so I don't have a pic yet. But ill update this as soon as I do.
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Senior Member Two Rings ringofsteel's Avatar
    May 05 2008
    67 BETTLE,95 GOLF JOKER, B7 A4
    BODENSEE, GERMANY
    Re: Fender to Ground, Where do you stand?
    I am @ 24.75 f/r with 235x40x18 with 35et D2 Race Coilovers, H&R rear sway
    http://i380.photobucket.com/albums/o...3/DSC00509.jpg
    APR STAGE II+ APR STOCK/91/93/100/W/M/Test Pipe File,APR Full Cat-back, ZeroThreeZero TP, 034 Motor Mount, AWE DV, BSH Catch can w/PVC bypass, RS4 plastic covers, VAST W/M, D2 V3 Coil's, Cryo Rotor, ECS Steel Brake lines, Hawk Pads, 19" OZ's Ultra's 35et, 10,000k HID, AVIC D3 up front, 15" Flip down in the back with backup cam, Valentine, AWE Vent Gauge, Kenwood 8" Sub in stock local, Memphis Audio amp, 1 Farad power cap, Audi S4 blades, Audi Front Spoiler, Audi Rack system
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by Geoffafa@Wolfcars View Post
    I know as of right now im sitting at 23.25F and 23.75R. Unfortunately I finished my coils last night around 10 so I don't have a pic yet. But ill update this as soon as I do.
    I agree on the usefulness of such information -- good idea.
    I have a couple of comments through. What is the use of fender-ground height without also stating (a) tire size, (b) fender to wheel top gap height (-ve being fender lower than top of tire), and (c) type of suspension?
    For instance, consider the ridiculous scenario of an A4 with low-rider type wheels (tiny, wide, sticking out the side) -- the fender-ground height would be very low, but what about the other aspects?
    IMO, you need all of these parameters in order to -- at a glance -- see the visual effects of suspension mods and tire upgrades.
    Senior Member Three Rings Gingerkid's Avatar
    Apr 22 2009
    2007 2.0T A4 quattro 6MT
    Atlanta, GA
    25-5/8" all the way around day of suspension install, haven't measured again. Stock 17's (235/45/17) with Koni/Eibach Pro kit. Based on my measurements, the kit lowered about 1.2" as advertised. I really like the height.
    Aug 31 2007
    Miami
    Quote Originally Posted by wayneB7 View Post
    We can go that route! I was thinking more just to see how low your body sits to the ground. But if we can get into specifics then maybe we can throw it in the FAQ
    IG | @fukn_fafa
    Feb 17 2005
    Sarasota, FL
    24 1/8" - Front, 24 1/2" - Rear
    Tein SS Coils with an inch of threads left in the back and 1.5" of threads left in the front
    Wheels are 18x8 et35 w/ FK452 235/40
    Feb 13 2004
    Silicon Valley, CA
    25" front and 25,1/8" rear. Wish I could go a hair lower, but I bottom out over speed bumps in my apartment all the time.
    Kevin - Moderator, Audizine
    Established Member Two Rings IIDeuce's Avatar
    Apr 07 2008
    Mercedes 230ML
    Miami
    23.375" front & 23.75 back that was like 2 months now i am 24 all around :-) im on a v6, got on stock 17" rims 235/45 rs4 sway and 12mm spacers no rub non-sline with front cupra lip
    Audi A4 3.2 Quattro 6MT ATW!
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    25.5 all around
    Stock Tis 10mm spacer in the back and could fit an 8mm in the front.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    24.5 All the way around on 18 in. ADR Sterlings on Nexxen225/40/18s
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Apr 07 2008
    Mercedes 230ML
    Miami
    I want to see someone post a pic of 22" all around lol
    Veteran Member Four Rings VegasAIV's Avatar
    Feb 25 2009
    B7 A4
    Las Vegas
    Quote Originally Posted by bblume View Post
    gorgeous waggy man
    Turbo lag is just foreplay...
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    I'm at ~25" g/f with the pre-set Stasis damping...ride is harsh enough so tightening up the damping would only make it worse I'm happy with the way it sits, just wish ride was a little better, but something you just have to deal with. On OEM B6 USPs with 235/40/18 Contis (temporarily) with 10/12mm spacers, need to go 12/15. Ideally 17mm in rear would be good, but afraid it will rub.
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Aug 31 2007
    Miami
    Come on i know more of you can share with us!
    IG | @fukn_fafa
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Good idea to throw it in the FAQ.
    Apr 07 2008
    Mercedes 230ML
    Miami
    I want to see 22" :-0
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by IIDeuce View Post
    Maybe someone can Photoshop one for you ....
    Jan 09 2009
    FL
    haha, it can be done.. for show possibly???
    Senior Member Three Rings osag52's Avatar
    Jan 06 2009
    09 Q7, HD Deluxe, 08 A4
    Miami (305)
    i havent measured yet, but here it is on H&R sport springs and stock sport suspension.
    08 A4/Ibis White/SLine/TI Wheels/APR Tuned/APR Catback/Carbonio Intake/LED Int/LED Plate Lights/H&R Sport Springs/Cupra Splitter/Gutted OEM Cat (sounds great)/Podi Gauge/DEBADGED
    Senior Member Two Rings Rosinbag's Avatar
    Jan 27 2009
    TX
    25 1/4" all the way around
    18" VMR 708's ET38 with Mich Pilot Sport A/S Plus 235/40
    Considering spacers in rear...
    The Rosinbag
    '13 All Road P+
    Veteran Member Three Rings ZEM930's Avatar
    May 12 2008
    2006 Audi A4 Quattro
    Orlando
    25.5 all around!
    Anything less would be uncivilizied LOL : )~
    (06 Audi A4) Quattro/2.0T Quartz Grey/Black-------Lots of plans
    ---------- VMR V710s, D2 Coilovers, APR 93, RS4 Swaybars, 034 HFC---------
    Remember, you cant turn a pig into a racehorse but you can build a mighty fast pig!
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    front 25"
    reat 25.25"
    Apr 22 2009
    Atlanta, GA
    ^^^^^^For some reason I just can't get into black wheels, but that shit it HOT!
    In Limbo Two Rings
    May 29 2009
    07 Blk A4
    Minnesota
    25 inches front and back. Neuspeed Sport with VMR 708's. Falken 235/40/18.
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Quote Originally Posted by Johnnie View Post
    front 25"
    reat 25.25"
    Loving it
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    25.25 Front
    25.5 Rear
    (Stasis SS coils)
    Wheel/Tire Info: Champion/ SDS Invidia 20 x 8.5
    Vredestein Ultrac Sessanta 245/30 R 20
    Dec 21 2008
    maryland
    23.5 front and who knows rear
    this is a good thread though
    cabinkrew.
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by Rosinbag View Post
    Considering spacers in rear...[/IMG]
    This is one beautiful car. Perfect drop, nice wheels -- the whole package.
    Forget the spacers ... you don't need them. Car looks perfect the way it is, and spacers only potentially weaken the wheel-hub connection. If you must change the offset, do it with different rims, but to my tastes the present rims are classy and don't need to be messed with.
    Jan 27 2009
    TX
    Thanks Re the spacers, I think I'm with you on the risks. She rides like a dream now -- no vibration at any speed and she eats up the turns. I think I'm going to freeze the look now at 'classy sleeper' and re-focus on performance...
    The Rosinbag
    '13 All Road P+
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    That would be my approach. Good modding!
    Senior Member Three Rings dope a4's Avatar
    Apr 06 2008
    08 a4
    VA
    Sitting at 22.25front just a hair over 22.
    on 19"s and have about another inch of thread left.
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    25" front & 25" rear. Eibach Pro Kit on 18's
    Jul 03 2007
    2017 Highlander Hybrid
    Stasis S/S set at 25.0" all around.
    His: 2016 Golf R
    Hers: 2017 Highlander Hybrid
    Past: Audi 90q | A4 | S4 | RS5; VW Mk1 Scirocco | Mk2 GTI | Mk4 GTI VR6 | Mk5 R32 | Touareg TDI; '65 Dart /6
    Dec 11 2008
    06' QG A4 Avant s-line
    Tristate
    22 3/4 front*, 24 rear*
    *indicates winter ride height
    Dec 21 2008
    maryland
    ^you going to be at h2o this year?
    cabinkrew.
