Results 1 to 17 of 17
    Jun 08 2009
    Dayton, OH
    Oil leak coming from under the timing cover
    I had some problems with my engine last year (1.8t quatro on a 2004 A4 sedan), and ended up getting the coils, pcv hoses/tube/valve, plugs, o2 sensor, crankcase vent valve replaced. Basically I was losing pressure and the engine was running really rough.
    Soon after, I noticed an oil leak - it was about 1qt every 3k miles, but it seems to have accelerated lately. I had a garage take a look at it and they saw the oil leaking from underneath the timing cover, so they suspect it's the head gasket.
    I was out of warranty and I didn't have the $ at the time to fix it, so I just lived with the oil drip for awhile, and checked the oil every couple weeks.
    It's getting to the point now where I have some $ and the oil leak is getting worse, so I need to get it fixed.
    So, in y'all's opinion, where should I take my car to get fixed? I figure it's going to be expensive no matter what, if the oil was leaking from under the timing cover. Is this something that might be covered under a recall or service bulletin? Is this something I should trust to a non-dealer garage? Or should I just bend over and have the dealer service it?
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: Oil leak coming from under the timing cover
    I didn't exactly see a valve cover gasket in there... eliminate that as a possibility first.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Jun 08 2009
    Dayton, OH
    Quote Originally Posted by wolfdog View Post
    Talked with the dealer service and they mentioned it's probably the valve cover gasket or the cam adjuster seal. Based on the location of the oil leak (mostly on the passenger side) they think it's the cam adjuster shield, which would be $1200 to fix.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by ZaijiaN View Post
    Cam Adjuster seal and valve cover gasket should always be changed together. Are you serious that it's $1200? The gaskets alone only costs <$50
    Jun 08 2009
    Dayton, OH
    Quote Originally Posted by Jeff View Post
    If someone wants to point me to a reputable garage in the Dayton Ohio area, i'll be all for it. But at the very least, I'll have them verify the problem for me and confirm it's not the head gasket.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    very easy to tell if its valve cover gasket/cam adjust gasket, just look on the back/sides/front of the block around the top, if you see oil (especially behind where the crankcase breather hose comes out) then you have bad gaskets. the DIY is pretty easy, can be done in an hour, maybe a little longer if you have to do the cam adjuster gasket.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    You are saying behind the timing cover but then everyone is mentioning stuff on the back of the head which is making no sense. You are refering to the timing belt cover correct? Which is on the front of the motor. It is most likely one of your cam seals. Pop that plastic cover off and get a flashlight and shine it right through the exhaust cam gear and see if oil is leaking around the cam (leaky cam seal). On the intake cam you would possibly need to remove the 2 bolts (10mm) that hold the little cover on and pull that off to look around under there. Both of those are extremely easy to do and will take literally 2-3 minutes to check both.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 08 2009
    Dayton, OH
    I had a local garage try and find the leak, I think they put in some dye or marker and found it was leaking from underneath the timing cover, that's all the info I have.
    Apr 24 2005
    E55 AMG, CTS-V
    Go out to your car, pop that plastic cover off the front of the engine that covers the timing belt. There is a little latch on each side of the head that just clips on. After that is removed look around on the front of the head where the camshafts are and see if oil is coming from right there. Also you will see oil that has leaked down the front of the head/block if one or both of the cam seals are leaking.
    ~David~
    CTS-V 9.6@148
    Jun 08 2009
    Dayton, OH
    Quote Originally Posted by A4 TSCHUSS View Post
    I'll do that when I get home and let you know!
    Feb 18 2004
    Los Angeles, CA
    You don't need a garage. Just a 10mm deep socket rachet to remove 9 M6 nuts.
    Then you need to purchase this kit:
    http://www.purems.com/products/product.php/II=1410
    You should typically replace the rear seal for the cam tensioner as well, but start with this one first.
    Jun 08 2009
    Dayton, OH
    I wasn't able to pull off the timing cover completely, but I was able to unlatch it and peer inside a bit.
    Pictures with notes here
    Also, is this sludge?
    Apr 24 2005
    E55 AMG, CTS-V
    Yes that is sludge, nearly all the cars will look like that though. And as far as your timing cover, just unclip those two latches at the top and then pull the top forward like you did then pull it straight up and it will come out (just take the hoses out of the little holders on the front of the cover.) It just fits into a grove with the lower timing cover to connect them together on the bottom part of it so you just pull it up and out.
    ~David~
    CTS-V 9.6@148
    Jun 08 2009
    Dayton, OH
    I can't get enough clearance to remove the timing cover w/o disconnecting the hoses, there's not enough give there to clear the bottom edge of the cover around the wheels.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    pop your coolant reservoir out and move it towards the front of your car, should give you more slack. Don't remember what other hoses go through there if any.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jun 08 2009
    Dayton, OH
    Quote Originally Posted by Molotov View Post
    At this point I'm just going to take it to the dealer, they can figure out what's wrong with it.
    If it's just the valve cover gasket and/or the cam adjuster seal then i'll get it done somewhere else - if it's more than that, say, like a head gasket then i'll have the dealer do it.
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    I am 99.9% sure its not the head gasket.. It is probably the cam plug seals.
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
