Results 1 to 40 of 57
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    DIY: B6/B7 Airbag light (Audi TSB)
    The first thing to do before starting this repair is to disconnect the battery!
    I do not disconnect the battery because I am familiar with the system and know how it operates. With that said let me begin. (ALSO APPLIES FOR A4'S)
    AND SORRY FOR CELL PHONE PICS.....I forgot to take my camera
    Here is the airbag light on! (my car/happened last week)
    You will need a VAG setup of some kind
    You will also need these ( I will try and get part#'s monday)
    Tools need...you can substitute the heat gun with a lighter
    Check faults!
    Remove the 2 front bolts holding the seat
    Pop off this cover so the seatbelt can be disconencted
    Remove 2 back bolts holding seat
    Disconnect seatbelt
    Use a triple square tool size 10 with ratchet
    Remove headrest (makes removing the seat much easier)
    Push this tab to remove headrest
    Place seat in this position and then lean seat back (still connected)
    Remove this cover (just pops/slides out)
    The first three connectors just "yank" out/the airbag connector (yellow)
    has a tab to push!!!!
    Place a sheet/towl/fender cover down (prevent scratching trim)
    Remove seat/place on bench or ground
    You will be removing this connector and replacing it with 2 wires.
    THIS IS AN AUDI APPROVED REPAIR/TECHNICAL SERVICE BULLETIN FOR THIS REPAIR!!!!
    Cut felt tape wrap back to give you some room to work with the wiring
    Set up wiring with butt-connectors attached
    Using heat gun to melt heat shrink wrap (a lighter can be used/works nicely)
    The use of some electrical tape and zip tie
    Notice the fault has gone "Sporadic"
    And that's about it...MODS please move to DYI's if approved?..total time around 1 hour for me and thats with taking pictures (check clock on cluster)
    Thanks for reading and I hope this helps someone!!!
    Veteran Member Three Rings pcasso87's Avatar
    Feb 12 2009
    Jetta a4
    Re: Is your Airbag light? DYI (Audi TSB)
    Nice writeup !!!
    Oct 06 2008
    as i was driving my car out of the shop my p/s front window regulator took a shit :(
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    nice write up. thanks.
    Veteran Member Three Rings Veereihen6's Avatar
    Mar 06 2009
    Long Island, NY
    nice write-up!!!! I just had the Airbag throw a code a couple of weeks ago. I haven't had the time to look into it yet, but this looks like something I can tackle! Part numbers for the wires and butt connectors would be cool, or just what gauge wires so I can rummage through the parts bins in the electronic assembly dept at work! LOL
    Thanks again man!!!!
    2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
    1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    Excellent work..
    Sep 13 2008
    Western Chicago Burbs
    so do i need to just remove the connector and connect blue to blue and black to black?
    Oct 06 2008
    Quote Originally Posted by B6JoeA4 View Post
    this is correct..its pretty simple...here are the part #'s
    butt connectors-000 979 940 (x4)
    wire-000 979 009 (x1)
    Dec 02 2009
    great write up!
    just so i understand this correctly, basically you're just cutting the yellow clip out and then using something like 14-16 gauge wire with butt connectors in it's place? and this eliminates the sometimes faulty yellow connector?
    May 13 2008
    MQBs
    San Francisco
    Mmmmmm... SMRT people.
    Aug 06 2008
    San Diego
    This also happened to me in my 2005.5 b7 s4 but that connector has 3 wires in it. I did the same thing you guys did but with 3 wires and all my problems went away. (i had the same issue in my early 2006 GTI and fixed it the same way)
    ::2004.5 Stonehenge Gray Passat ::2006 United Gray MKV GTI 6MT::2000 Nogaro Blue S4 6MT::2005.5 Moro Blue S4 6MT::2010 Ibis A4 2.0TQ 6MT ::2017 Scuba A4 P+ Tech Sport 19" :: 2019 Tesla P Model 3 :: 2014 Ibis RS7 ::
    Current:
    ::2001 Nogaro Blue S4 :: 2012 Ibis R8 v10 Gated :: 2021 Nardo RS7 ::
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    Awesome write-up and easy!!! You have answered my prayers. Did it over the wknd and just had Pepboys clear the code - no more airbag light that has been on for roughly two years...
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Oct 06 2008
    Glad to help!!
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    I know this is old....but this doesn't affect the functionality of the airbag, correct?
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by CoreyRS View Post
    It shouldn't. If the airbag light is off then they are functioning properly.
    CEO and General Manager of the AZ Pedal Responce Team
    Oct 31 2006
    San Antonio, TX
    Why isn't this in the DIY Forum?
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Veteran Member Three Rings h_curtis's Avatar
    pittsburgh
    Firstly, thank you for writing this up.
    I got this code:
    1218 side airbag igniter
    passenger side (n200)
    001 upper limit exceeded
    Seems this situation can happen on either side and the problem can be fixed the same way. Here is the other side on a VW, but looks the same.
    http://forums.vwvortex.com/showthread.php?2815467
    '14 s5, 6sp, sport diff, b&o, panda, estriol blue
    Oct 31 2006
    San Antonio, TX
    Question....are the part numbers for the wires and butt connectors Audi part numbers? Can you buy those at the dealer?
    pittsburgh
    Thanks for this information. It worked great on the passenger side. The only difference is it didn't say, "sporadic". It said something else, but I didn't write it down. None-the-less, it worked the same.
    Jun 30 2008
    Erie, Pennsylvania
    Wow, those part numbers listed are the most hilariously overpriced items I've ever seen, lol. That's $8 for the wire and $3 per butt connector, making this repair cost $20 at the Audi parts counter. Talk about markup. I'd get some wire, solder it in, and be done. Solder would be a more reliable connection anyhow. And when I think airbags...I think reliable.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    This is a VERY nice DIY. .
    A lot of Audi wiring fixes - most noteably the wiring supplying the coilpacks require crimp/butt connectors due to changes in resistance that the solder introduces into the circuit. This resistance change might affect future proper operation of the ckt.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Oct 31 2006
    San Antonio, TX
    I got you beat, I went to the local dealer here yesterday to pick up these parts.....
    Wire - $25
    Connectors - $10 EACH (SERIOUSLY!?!?!?)
    Total $65
    Looks like I'll be doing the Autozone/RadioShack version of this fix. Anybody know the gauge of that wire?
    Oct 06 2008
    you can pick up the stuff to do this job at oReillys...not supposed to to solder...especially on the airbag circuit...
    Master Certified Audi Tech in the DFW Area VAGCOM EQUIPPED!!!!
    Stephen Zink
    [email protected]
    Like us on Facebook @ZinkWerks
    Sep 03 2009
    San Antonio, TX
    hmmm...I also wonder if this will fix my problem. I had my airbag light come on about a year ago. But I've been lazy and haven't gotten around to checking the code.
    -subscribed-
    MY BUILD
    Oct 31 2006
    San Antonio, TX
    Guys, for the record this is 0.5mm diameter wire which is 20 gauge (AWG). It sells for $0.19 per foot at O'Reily Auto Parts. While you're there, you can pick up the butt connectors for $0.99 each. So assuming 2 feet of wire (allowing for margin of error) and 4 connectors, you're looking at $4.40 + Tax. I can't believe my dealership wanted to charge me $65, dear god.
    Veteran Member Three Rings aalipio's Avatar
    Sep 03 2008
    05 S4 V8 02 A4 1.8T
    N las vegas
    Gotta do this! Suhweet! Why is it so common for the airbag light to occasionally fault out? Both lights on my b6a4 and b6s4 are now on! Sheesh
    Established Member Two Rings Bobby417919's Avatar
    Mar 14 2010
    Concord, NC
    Ok so I went to do this weekend and the bottom of the b6 is a little different, and its pictures are moved right now.. so before I cut it out I want to be sure. Is this the correct connection to cut out?
    Veteran Member Three Rings S4King's Avatar
    Aug 01 2009
    Houston, TX
    Is this code part of the repair?
    Sep 03 2009
    San Antonio, TX
    Quote Originally Posted by Bobby417919 View Post
    I cut out the connector but still have an airbag light...I'm guessing I'm going to have to VAGCOM it to clear the code???
    MY BUILD
    Senior Member Three Rings 04 S4's Avatar
    Nov 01 2011
    2005 Ford E250 Work van
    Bonney Lake, WA
    Quote Originally Posted by sa_seahawker View Post
    Yes you will.
    This is actually the reason I bought vagcom :P
    2004 S4 (Tip) - Dolphin Grey metalic Traded 4/3/13
    2009 Q7 Prestige S-line - Daytona Grey
    Senior Member Three Rings diaftia's Avatar
    Oct 19 2007
    Danville, CA
    Does this TSB apply to more than just B6/B7's? My RS6 is doing this. I clear the error and it comes right back.
    03' RS6 - Mugello Blue, Ebony Interior. 19" V710's
    Sold - 2006 6SP Silver B7 S4 - APR Exhaust, piggies, JHM Tuned, VMR V708's
    Sold - 01.5 B5 S4 6-Speed - Neuspeed Exhaust, GIAC-X ECU, Short Shifter, 034 Diverter valves and TBB, VMR V708's
    Established Member Two Rings RoccityRider's Avatar
    Apr 04 2011
    Rochester, NY
    Will this work for "airbag fault to ground"?
    08 A4 2.0T S Line | APR Stg 2 93 | 034 Turbo Inlet Pipe |APR Test Pipe | DTM Rear Bumper | RS4 Rear Sway Bar
    Deactivated Two Rings
    May 09 2012
    New England
    I did this repair today, great writeup. If the light comes back, I'll post a reply. Otherwise, assume this was a good fix.
    Here are the search terms that apply to this fix: 01218 and 01217.
    Established Member Two Rings rawtor51's Avatar
    Nov 26 2011
    VW Golf GTTDI, Audi A6 C7.5
    Aberdeen, Scotland
    Quote Originally Posted by RoccityRider View Post
    Sorry to bump this old thread back up but i would also like to know about the above quote.
    R19 RRW Audi A6, R19 DUB MK5 VW Golf
    Sep 03 2009
    San Antonio, TX
    Quote Originally Posted by rawtor51 View Post
    I'm guessing if your car has never had any airbags deployed, then probably yes. If you have had a deployment and sent it to a body shop, take it back there and tell them to fix it. Most reputable shops offer lifetime warranty on their repairs. Even if it doesn't fix that problem, you should probably just go ahead and do it anyway...
    MY BUILD
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    The dealership wanted just over $800 to replace the airbag, did this today and looks good so far. Best $3 I've ever spent.
    2004 Light Silver 6MT S4
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    Hey guys, need a little help here if possible. I have an B6 A4. I'm getting a diff code than what I've saw on here. I did the wire trick with the 2 wires and connector and deleted the code. The code comes back a second after I clear it. The code I am getting is. 01221- Crash Sensor Side Airbag; Driver Side (G179) 012-Electrical Fault in Circuit - MIL ON Any help is greatly appreciated.
    P.S. Some of the DIY photos on this thread are missing with an error code.
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Nov 09 2007
    Arlington VA
    bump for missing pics in the dyi
    Jul 21 2013
    Westchester, NY
    can update missing pics on dyi? want to do this soon on my b6.
    Apr 07 2011
    Quote Originally Posted by B6JoeS4 View Post
    Quote Originally Posted by szinkuti View Post
    Look at the comments above^^
    It's a very easy fix. If you pay attention closely in the picture, there is a blue and black wire that were cut. After that you would cut on the other side of the connector to eliminate the connector. You're just adding an extension to each wire so they reach each other without the connector in place. So you take the wire you bought and the butt connectors and connect blue to blue and black to black with the extra length of wire. I was confused at first also with the most important pictures not being hosted anymore but after reading the comments it's a very simple procedure.
