Page 20 of 20 FirstFirst ... 10181920
Results 571 to 585 of 585
  1. #571
    Veteran Member Three Rings ipop07's Avatar
    Jun 09 2009
    Kitchener, ON
    BBS E28 F:18x10, R:18x12 + accuair elevel and airlift
    '18 Golf R / '21 Atlas R-line / '09 A4 Wagon
    instagram: ipop07
  2. #572
    Established Member Two Rings RaudiB5's Avatar
    Aug 11 2010
    99 Passat Varient 1.8TM, 01.5 Stage 2+ Shaved Imola S4
    Granada Hills,Ca
    1st car,
    01 A4 1.8T QM
    Suspension specs: D2 coil-overs (Blasphemy I know, suck it!) with 35 way dampening about 23 1/2 FTG and dampened 34 front and 32 rear.
    Also Front and Back have been corner balanced ;).
    Wheel specs: Audi OEM Pie plates 17x8 et 35 with a 20mm Spacer rear et 15.
    Tire size: 225/45/17 Hankook V12 Evos = smiles :).
    Cherry Pie. by Pure Fitment, on Flickr
    Almost Merica. by Pure Fitment, on Flickr
    2nd car,
    01 S4 Avant,
    Suspension: ST 1st Gen coil-overs 23" front and 23" 1/2 rears. I still need to adjust them. (Le lazy)
    Wheel specs: S5 reps in 18x8 et 35 (for sale or trade if anyone wants them)
    Tires size: 235/40/18 Hankook V12 evos.
    Break. Fix. Wrench. Repeat!
  3. #573
    Aug 30 2014
    United States
    I believe you are referring to this car.
    Not my car.
    Wow that needs to get low.
    These wheels look pretty good on this B5 Passat
  4. #574
    Active Member One Ring Eivind's Avatar
    Apr 26 2012
    Norway
    Here's a couple of pictures of mine. Not the best ones, but the best I have after the respray.
    Not even completely assembled yet (things move a bit slow for me in the winter). It was originaly silver, but now it is L D5Q "Shadow Blue"
    Wheels are B8 A4 OE 17" with 205/50R17 Nokian Hakkapeliitta R winter tires. Lowered with ECS add-on coilovers on Eibach/Bilstein B12 Pro Kit.
    I've got a set of of similar 17" OE B8's with 225/45R17 for the summer.
    GTF 25.35 front, 25.08" rear.
    How it was before, with some rust removed in Photoshop:P With just the B12 Pro Kit I think, and 215/35R18 on MB 18x8"
    Eivind
    '00 Audi A4 Avant 1.9 TDI quattro | AVF swap - ABT tune | Bilstein/Eibach B12 Pro-Kit w/ECS Coilover Add-On | Focal audio
    '87 Mercedes-Benz 190E 3.0
  5. #575
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    01 A4 with sport suspension shocks and springs with S4 knuckles and brakes. Elbrus IO6 wheels 16x7.5
  6. #576
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Quote Originally Posted by quattr0 View Post
    I am fitting 255/40/18 dunlop winter sport M3 tires already on a RS6 18x8.5 ET30 on a B5. Right now, I have 235/45/17 on Konig wheels 17x8 ET35. The thing is the current wheels clear the fenders by a lot. I actually wonder why some of you guys need them rolled. The problem would seem to be the control arms, especially the rear ones. They are only half an inch away from the tires I have right now (17 in). Upgrading to 18 in with wider tires seems like an unworkable situation. Ironically, based on my setup, any rim over 17 and the tires should rub against the rear arms, so I don't know how you guys do it.
    Someone needs to go to their car, check the clearance between their back tire and their control arms and reassure me. Especially the 18 and 19 in rim havers.
    Quattr0, the noise
    Im looking to do almost the same thing, im going to 18x8 et35 with 245/40/18s this winter also. im a little smaller but i dont know about the clearance. i run 16x7.5(et ????) 205/55/16 right now
  7. #577
    Established Member Two Rings Eddie_b5's Avatar
    Sep 24 2015
    2001 Audi A4
    New York
    I know this thread hasn't been used in a while but maybe we can get it going again! Curious to see who's running what now!
    This is my 2001 b5 a4
    Wheels: WCI CC10
    18x9.5 et15 square
    205/45/18 all around
    Raceland coilovers :( (I know it's upsetting) more low to come when winters over !
    Eddie_b5
  8. #578
    Nov 21 2015
    Hampton Roads
    I did the S4 brake upgrade.
    Is there a list of wheels that fit WITHOUT spacers?
  9. #579
    Oct 14 2006
    west coast
    KW V1 Coilovers, BBS CH 17x8.5 ET 35 wheels:
    *could lower it much more if desired, but its a daily beater for me.
  10. #580
    Established Member Two Rings drift4's Avatar
    Aug 15 2015
    BMW 335I / BMW 533I EURO CONVERSION
    Fairfax Virginia
    B5 A4 Avant - soon to be in the oldtimer section
    my humble B5 A4 2.8 Avant Sport a sitting on Bilstein HD Dampers with Eibach Prokit springs
    VMR 19x8.5 wit a +35 fitted on 235/35/19 bridgestone S-04 pole posi
  11. #581
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    18x8 BBS RE et35 with Vogtland coils
    225/40R18 Michelin Super Sports
  12. #582
    Veteran Member Four Rings Joe Jr.'s Avatar
    Mar 09 2017
    Longmont, CO
    Quote Originally Posted by drift4 View Post
    19s are a bit big i think, but i like those wheels.
    Need another!
  13. #583
    Sep 01 2014
    Houston Texas
    I need a solid answer on this one and trust me ive searched. I know many will say "Just get 225's and run 10mm spacers." I get it... But what im asking advice for is which spacers do I get to fit my 18x8 b6 avus wheels with "235/40" tires. Thanks in advance. This is a narrow body, 1998 Audi A4 1.8T Quattro currently on stock suspension with a full S4 kit (If that matters)
  14. #584
    Mar 09 2017
    Longmont, CO
    use this website. you'll need to know the offsets on those wheels, which you can find on the inside of the wheels. plug in all the numbers and see where you're at.
    https://www.willtheyfit.com/index.ph...h=8&offset2=50
    Need another!
  15. #585
    Aug 15 2015
    Fairfax Virginia
    B5 A4 Wheel and Suspension Thread
    19x8.5+35 on 235/35/19 Bridgestone S04 / Footwork is Bilstein HD’s dampers with Eibach ProKit springs. Surprisingly the ride is comfortable and when driven spiritedly very minimal pitch & roll which i was surprised.
