Results 1 to 16 of 16
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Headlight tab repair kit, any good?
    I'm about to get a good deal on a OEM HID headlight with bulb and ballast included. Now, only catch is that the top two tabs are broken. I found the appropriate tab repair kit. So the questions, is it pretty easy to repair the broken tabs and how well does it hold up? Thanks.
    Feb 20 2009
    Sudbury on
    Re: Headlight tab repair kit, any good?
    my tab repair works well
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I used one on my last set of ecodes. Install took less than 5 minutes and I never had a problem with it.
    May 17 2009
    Idaho
    Sweet. As always, thanks for the quick replies.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Bumping from the dead. I just checked my headlight, I have 1 broken tab on the passenger side headlight... I don't see screws in there holding the tab piece on ? Am I missing something, the repair kit on ECS
    http://www.ecstuning.com/Audi-B6_A4-...lights/ES3252/ shows 2 small Phillips screws. The tab piece on my headlight seems to be molded... Any help ?
    Established Member Two Rings nezach's Avatar
    Nov 03 2007
    02 A4 3.0 Quattro 6spd
    Chicago, IL
    Original tabs are part of the headlight housing. In order to use repair kit you will have to cut the one tab that's still left on the headlight.
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by nezach View Post
    Can anyone confirm this ? If I cut the remaining tab... the molded bar is still in place, the part pictured on ECS website..
    Anyone know about fixing broken rear tabs?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Cut the tab and make sure the molded bar stays in tact. The repair kit will sit up against the molded bar perfectly, then two little screws will secure the repair kit to that molded bar.
    Eeezy squeezy and works very well.
    Oct 02 2006
    Wadsworth,OH
    Sorry to chime in on this a bit late, but yes - pretty much exactly what greg said. These B6 tab kits mount to that existing bar and hold everything secure. I know it seems odd to remove the good tab, but that is how the kit is designed. Keep in mind, the kit is for one headlight only, you'd need one for each side and they are side specific.
    Nov 07 2006
    02 A4 1.8t
    New York
    Interesting. Thanks for the information everyone. Hey Chris can you tell me the kit I should go with? I saw a 40 dollar one and a 130 dollar one lol. It's the left headlight top right tab on an 05 s4 single xenon.
    Also is there any tab repair kits for the bottom holders? Thanks.
    Oct 02 2006
    Wadsworth,OH
    Sure, just go with this left side kit. These kits are all you should need. As far as I know these are the only tab kits we have available too.
    Nov 07 2006
    02 A4 1.8t
    New York
    Anyword about fixing a broken bottom piece where the headlight screws down ?
    Okay sounds good. Just the screws into the molded piece and I'm set? Do I need any adhesive ?
    Oct 02 2006
    Wadsworth,OH
    I'm not familiar with a bottom tab replacement. As for adhesive, it isn't necessary.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    I used this thing
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Nov 07 2006
    02 A4 1.8t
    New York
    Haha howd that work out ?
    Dec 18 2011
    Colorado Springs
    Necrobump!
    Any DIY on how to utilize the repair kit?
    ...hey, at least I searched.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
