Results 1 to 10 of 10
    May 08 2009
    Holmdel/NJ
    OZ Ultraleggera Lug Bolt Fitment
    I have a question to those who have Ultraleggeras. Do you guys have ball seat lug bolts or cone seat? I just want to make sure that I have a correct fitment hardware on mine. I was sent ball seat bolts with my wheels.
    Sep 23 2006
    Houston TX
    Re: OZ Ultraleggera Lug Bolt Fitment
    If they're like the Superleggeras (which they probably are) they are a special ball seat (R12 I believe) and slightly different from Audi OEM ball seat (which I think is R13). Tirerack carries the correct lugs if you're concerned about the correct lugs. But if they sit in the lug holes with zero play, they're probably fine.
    May 08 2009
    Holmdel/NJ
    Thanks, man. I wanted to make sure. I've had wrong hardware sent to me in the past, so I ahd to ask.
    Senior Member Three Rings Devitan's Avatar
    Dec 21 2008
    Silver Audi S4 2005 B6
    Connecticut
    Fractus, please give us a write-up on how these go. I am interested in purchasing the ultraleggaras but am scared about potholes and wheel bendage.
    | APR Downpipes | Milltek Non-Res Cat-Back | APR 93 Octane Flash | K&N with Stock Air Box & Flapper Mod | Stratmosphere Short-Shift 40% Reduction | JHM Intake Spacers | APR Snub | JHM Lightweight Front and Rear Rotors | 29mm Hotchkis Sway Bar (H-Sport)| JHM LW Crank Pulley | Intake Bypass Valve |
    //AMA
    May 08 2009
    Holmdel/NJ
    I haven't had any problems so far, and I drive to NYC from NJ every day. I try to be very careful as far as potholes are concerned though some are unavoidable especially in the rain when you can't see much. The ultrallegeras are excellent wheels, I must say. I had an 18" set on my previous car for about 15 months with 225/45 tires without any problems.
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    Quote Originally Posted by Devitan View Post
    A write-up for rims...ok here goes...
    1.) I bought them
    2.) I mounted them
    3.) I bought wheel locks
    4.) No bends over 1 year....mix of mild/aggressive street & light tracking
    ^^^^^Best write-up of all time if I do say so myself
    -B
    Senior Member Two Rings pecka13's Avatar
    Jun 13 2012
    Darien, IL
    Im about to purchase a set, and I see you guys are talking about different bolts.
    Are they required or what? I dont want to damage the wheels with oroginal bolts or will it be ok?
    Sent from my HTC Glacier using Tapatalk 2
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    I have Ultraleggeras (as opposed to Superleggeras) and they're ball seat and I use the same bolts for my O.Z. as for my OEM (I use spacers for my OEM to have the same offset as the O.Z.)
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Jun 11 2012
    I have these wheels and I live in New York 19x8 and its a pain in the ass!!!! Freaken bent so easily!!!!! I love the wheels but stay away from the Grand Central!!!!!
    JHM 93//JHM SS trio//JHM LWFW & Stage 4//JHM Intake Spacers//034 MAF hose//JHM LW Pully//Vogtland coilovers//Fast Intentions Cat-Back//AMS Autowerks Custom 2.5 Dps//Stern Motor Mounts//Apikol Snub//Apikol Rear Diff mount//034 Trans Mount//
    Jun 11 2012
    Quote Originally Posted by fructus View Post
    You haven't been on the grand central??? lol they put speed bumps on the highway!!!!
