Results 1 to 10 of 10
    Sep 25 2006
    '04 White 6spd 1.8tq USP
    Tampa, FL
    widowmaker oem jack.....>_< arrghhh
    ok ive heard all the horror stories about the shitty oem jack that seems to be made from tin foil and balsa wood buuuuut i figured i would just jack my car up anyway...and of course as im lifting the car it begins to lean...and BLAM it falls over leaving a nice mark on the underbelly...yay
    ANYWAY! i bought a nice sturdy trolley jack like this one (http://www.toolstation.com/images/li...bbig/12136.jpg) but noticed that the contact point of the jack is just going to bend the hell out of the little ridge that the stock jack fits onto... and there isnt an obvious other area to put the jack... i read around and read that some people use the frame... but the underbelly of the car is covered in plastic....so where exactly is this spot? i just wanna lift my car up! :*(*** pictures or just a good description would be appreciated, thanks...
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Re: widowmaker oem jack.....>_< arrghhh
    Day 1 of owning my Audi I found the widow maker and couldn't figure out for the life of me how to use it. So I threw it away and put my Honda jack in the trunk instead.
    The spot should be about 6 inches back, behind the front wheels.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    similar to our car:
    http://www.audizine.com/forum/showth...ght=floor+jack
    and get one of these for the pinch weld:
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You could buy a jack pad to go into the lifting cup or put a 2x4 between the jack and car, if height permits. EDIT, beat to it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 25 2006
    Tampa, FL
    awesome, thankya!
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    the stock jack sucks.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Deactivated Four Rings
    Sep 30 2008
    n/a
    I need a flat tire jack or someone needs to lift on my fender when i put a jack under my car because its so lowww
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    ^^ thats why I keep these in my trunk:
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    I'm surprised Audi hasn't issued a recall or something on the jack. I was surprised to see the same size jack in the B6 as my old B5 [which wasn't known for it's staggering strength either].
    I got my B6 maybe 3" - 4" off the ground before said jack collapsed. Glad I was able to get out of the way in time.
    Now I keep an OEM BMW 3 Series jack in my trunk. It's easily double the size and strength of the Audi's. Fail.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    it takes a little finesse to make sure the jack is properly seated. once i've done that, i'm usually good to go. i know the jack looks flimsy and everything, but i've changed plenty of tires and never had a problem.
    i just make sure i'm on level ground and i carry wheel chocks in my trunk anyways. when i'm away from home, i actually use it to jack up the car before i put jack stands on it, like a regular jack. only reason i use my hydraulic jack at home is because it's easier and i hate trying to figure out how to put the damn OEM jack back in that little holder thing.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
