Results 1 to 36 of 36
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    simplest ipod/iphone connection
    obviously theres stuff like this all over this side of the forum, but after searching there are so many different types i didnt know was right for me. i have a b7 with rns-e and 6 disc cd changer. can anyone tell me the cheapest purchase to plug an ipod/iphone charger/player into the cd changer port? dice has one but its 150 without it's little cradle. any links would be really appreciated.
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Jan 18 2005
    North NJ
    Re: simplest ipod/iphone connection
    Do you want to control/charge the ipod from the radio or do you want a very simple interface that you just control from the ipod?
    Senior Member Two Rings AudiA4b6US's Avatar
    May 10 2005
    Chicago, IL
    if you are using software 0260 (US) or 0650 (Europe) then the cheapest way to connect an iPod is to retrofit the AUX IN. Should be less than $30 and allows to connect any device with headphone jack.
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    thanks for the input guys, i want more than just an mp3/headset style jack and i would want something that both charges and plays. depending on the price difference, i would like to be able to see the songs on my nav screen and control the ipod/iphone. but if that is significantly more expensive then i can live with a charging/playing wire where i control only from the iphone.
    thanks again
    Jan 18 2005
    North NJ
    I'll try to break down what we sell for your car and how it works.
    Simplest:
    Blitzsafe M-link
    http://enfigcarstereo.com/shopsite_s...LINK1_V1B.html
    This interface will connect to your ipod from the data plug and charge it. That's it. You control all of the ipod functions from the ipod itself.
    Advanced:
    Dice I-Audi-R
    http://enfigcarstereo.com/shopsite_s..._I_AUDI_R.html
    The Dice will charge your ipod and allow you to control its functions from the radio. Your playlists will come up as different cd's and you can track up/track down the songs as well. Much better than the OEM Audi Ipod since it has no limit to playlists. Add's an auxilary in as well which can be switched through the radio.
    Top Tier
    Dension GW16AC1/AC2 Gateway 100
    http://enfigcarstereo.com/shopsite_s...N_GW16AC1.html
    http://enfigcarstereo.com/shopsite_s...N_GW16AC2.html
    This allows you to have text on the MFD in your center console. FULL control over the ipod's functions in IPOD-GW mode and can switch over to IPOD-UI mode through the menu screen. It includes a full ABC-Search for all artists and songs. Learning curve is a little steep but after a few weeks you will be able to navigate through your ipod very quickly through the steering wheel controls. This also has an aux-in that you can access from the menu screen.
    Dension GW33AC1/AC2 Gateway 300
    http://enfigcarstereo.com/shopsite_s...N_GW33AC1.html
    http://enfigcarstereo.com/shopsite_s...N_GW33AC2.html
    This has the same functions as the Gateway 100's just with the addition of a USB-in for portable hard drives and thumbdrives. Again it has full text for that as well.
    Quote Originally Posted by jimmya4 View Post
    thanks again
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    thanks for that mike. ill probably pick up the first link you showed me. i wanted a charger but the number one reason for wanting the connection was so that the passenger can plug their ipod in or look through my iphone or what ever. thanks for all the info
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    just bought it mike, hopefully you can help me out if i have questions when i get it. thanks again
    Jan 18 2005
    North NJ
    No problem just give us a call or email for any questions or concerns
    Established Member Two Rings bagher's Avatar
    Jul 01 2009
    2007 Audi A4 2.0T sline
    Vienna, VA
    can you stream audio (pandora app on iphone) with any of these?
    2007 A4 2.0TFSI Quattro S-Line Tip K&N|Tint|Plastidip Grille|painted reflectors|debadged
    Jan 18 2005
    North NJ
    Quote Originally Posted by bagher View Post
    Yes they will. The Dension needs to be in Ipod UI mode(control from Ipod) to get the audio from Pandora. Otherwise works fine.
    Jul 01 2009
    Vienna, VA
    that's awesome I need to get one then
    Veteran Member Four Rings Saracen's Avatar
    Apr 25 2009
    PNW
    Questions about the GW16AC2:
    -Does it work with an iPhone 3GS?
    -Does it include a dock cable?
    -Will it charge a 3GS
    Thanks in advance, if everything is confirmed I'll be pulling the trigger :)
    Active Member Two Rings scythe1969's Avatar
    Apr 20 2009
    Orange County
    I'm just wondering... I ran across this post a couple days back doing the research for exactly this option.
    http://forums.audiworld.com/showthread.php?t=2760704
    Will the BlitzSafe VW/M-LINK1 V.3A work the same as the BlitzSafe AUDI/M-LINK1 V.1B? It just seems that the v.3a is simpler to connect (one cable vs. 3?)
    Any information would be appreciated.
    Nov 18 2008
    Calgary
    I have the B7 S4 with the symphony system. I just had a Dice system put in using the second CD config it works great and I can control the ipod through my steering wheel. i have no text but it works well
    Jan 18 2005
    North NJ
    Quote Originally Posted by Saracen View Post
    -Yes
    -no sold seperately
    -Yes
    Jan 18 2005
    North NJ
    Quote Originally Posted by scythe1969 View Post
    If you have the external cd changer in your glovebox(which came on RNS-E equipped cars) then you can use the V3a.
    Apr 20 2009
    Orange County
    Thanks Mike, you can expect my order today. I appreciate you taking the time to share the knowledge.
    Established Member Two Rings c_snapper's Avatar
    Apr 03 2009
    2006 Audi A4 2.0T
    my local installer is quoting me the best price for the USA Spec device. After reading this thread, I want to go with the Dension option. Is the Dension better than USA Spec, or do they do the same thing?
    i want
    - control via my steering wheel control
    - charges my ipod
    - track title display on both the unit itself AND the dash display.
    Will the USA Spec get the job done, or should I fork out more for the Dension?
    http://www.fuelly.com/sig-metric/17809.png
    ^look at my fuelly to see how i'm doing with my gas mileage
    Jan 18 2005
    North NJ
    The USA-Spec is a great unit and will give you control of your playlists and track up/down, but will NOT give you text at all. The Dension will give you the text and better control of the Ipod. You cant go wrong with either unit its just a matter of how much control you want with your Ipod.
    Mar 08 2009
    Canyon Lake, Texas
    A little help please,
    I've read through a lot of post about iPod integration, but still a bit confused.
    I have an early ’05 Audi S4 with a symphony radio. It’s the one with the 6 disc CD built in, a cassette, and satellite. I like the Dice Electronics i-Audi-R/5V that is listed on the Enfig.com site. I do not need, or want, the satellite radio to work, so I’m not sure if I need the extra cable they sell or not?
    So, it looks to me, that all I need is the:
    and the keys (42nd Draft Designs 42-002)
    Is there is anything else required?
    One last question. Is there a security feature in my radio that will shut it down once I unplug it? I bought the car used, so I have no security code to get it working again if necessary.
    Thanks for your help,
    Robbie
    Active Member Two Rings Kerr's Avatar
    May 22 2008
    2004 A4
    FL
    Will the blitzsafe work with the iPhone 3gs? I drive a 04 A4 and the headunit says "Audi Concert" on it; which blitzsafe do I need. Also, how do you get the head unit out? I couldn't find a how-to thread.
    Thanks
    May 22 2008
    2004 A4
    FL
    Quote Originally Posted by Kerr View Post
    Thanks
    Bump for some help.
    Thanks
    Senior Member Three Rings JohnTC's Avatar
    Mar 30 2009
    '02 A6 Avant, '06 525xi
    North Jersey
    Will the Dice I-Audi-R work with the latest video Nano 16gb? Can you use the 1/8" stereo jack for a sirius plug and play, have an ipod plugged in and switch from one to the other? I would love to get rid of my cassette adapter.
    Active Member Two Rings TorqueChap's Avatar
    Aug 25 2009
    Philadelphia & The Bahamas
    Hi Mike,
    Wondering what the product landscape currently looks like. I have a B7 S4 Avant with the MMI/6CD system. My GF has over 13k MP3s which I can help myself to.
    Needs:
    1. Ability to play either my iPhone or a cheap iPod (which I can just permanently keep in the car)
    2. Ability to see text on the MMI (don't care if it's on the iPod/iPhone as that'll be tucked away in the dash most likely)
    3. Ability to charge the iPod/iPhone
    Wants (it'd be nice but don't care to spend extra for it)
    1. Ability to store the iPod/iPhone in the arm rest
    2. Be nice to have satellite connected still, but with that many tunes I can easily live without it
    3. Be nice to have the 6CD connected, but can live without it if a less expensive option exists
    What have ya' got for me? Also, am I missing any key questions to ask you?
    I live in Philly, but have family in North Jersey.
    07 S4 Avant w RS6 Rims
    97 VW Golf Wagon (RHD)
    Jan 18 2005
    North NJ
    Quote Originally Posted by rc_a View Post
    Robbie
    If you don't care about losing satellite then yes all you need is the keys and interface. As long as you dont disconnect the main power harness it wont lose power and require a code. The dice only disconnects the external audio source plug (the red one).
    Jan 18 2005
    North NJ
    Thanks
    Yes it supports the Iphone 3gs including charging. You would need the Blitzsafe Audi Mlink1 V1b http://enfigcarstereo.com/shopsite_s...LINK1_V1B.html
    Jan 18 2005
    North NJ
    Quote Originally Posted by JohnTC View Post
    Yes it will work with the new Nano including the charging. If you want to switch between aux and ipod you go to CD6 Track 1 (Ipod) CD6 Track 2 (Aux)
    Jan 18 2005
    North NJ
    Quote Originally Posted by TorqueChap View Post
    Hi Mike,
    Needs:
    When you say MMI do you mean RNS-E navigation? As of right now there is nothing that will retain your external cd changer if you do, but if you have a Symphony in the internal changer will be retained. Like many others I would recommend the Dension for your car as it will do the charging, play, and control your Ipod. You can run the Ipod cable up to the armrest if you like.
    Any other future questions concerning the Ipod kits we sell and compatibility I would take a look at the awesome blog posts Christian wrote up http://enfig.wordpress.com/
    Jan 06 2005
    1998 A4 1.8TQM
    Norristown PA
    Per your last reply, is that correct that if I have the Audi Symphony double din unit and choose the Dension unit for Iphone adapter that I will be able to still use the internal CD changer?
    Apr 04 2011
    Boston
    Bumping just to say thanks for this great writeup. I was seriously confused about my different options. I just bought a 2008 a4 that I believe has the upgraded speaker system and has an ipod connector already installed in the glove box but the navigation is terrible to the point of unuseable. I think I am going to get the ipod/aux connector and get a cheap ipod to leave in the glovebox. I would get the spec.dock but it appears to get in the way of climate controls and look cluttered (IMO).
    Again, thanks!
    Established Member Two Rings monty2982's Avatar
    Dec 30 2009
    Olympia/Washington
    Just wondering if there are any options for non ipod/phone guys that use just a 3.5mm aux headphone jack? I have android and want to use a cable not bluetooth and be able to do the same things like charge the phone and use the steering wheel controls.
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    Quote Originally Posted by monty2982 View Post
    You Probably already found it but the blitzsafe aux does just that. You also need the RCA cable.
    http://enfigcarstereo.com/VW_AUX_DMX_V5.html
    http://enfigcarstereo.com/ENFIG_35RCA_6.html
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Jul 12 2004
    Dec 23 2011
    Kiman
    Thank you for really good information and links.
    Senior Member Two Rings S4nikator's Avatar
    Jun 29 2010
    British Columbia
    great thread! Mike or Christian, please advise if this set up http://enfigcarstereo.com/DENSION_GW17AC1.html will work with the iPhone5
    i.e. is there a iphone 5 cable?
    Jul 19 2013
    Pittsburgh, PA
    It is compatible with the Apple-branded adapter. From Enfig's description: iPhone5: Requires the Apple lightning to 30 pin converter.
    You can get the adapter for $25 on Amazon. Unfortunately, Dension doesn't have an Apple Lightning cable.
