Results 1 to 15 of 15
    Established Member Two Rings emenny81's Avatar
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    Tiptronic steering wheel buttons
    My steering wheel buttons only works for down shifting for upshifting doesn't work on both sides, is there anything that I can do using vag com to fix it ???
    May 06 2009
    01S4, looking for a second
    indy
    Re: Tiptronic steering wheel buttons
    Do they light up as they used to?
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    well they dont light up, I dont really car if they light up, I just want them to work, its pretty weird that the upshift wont work on both buttons but the down shift does.
    hopefully if the buttons dont work I dont have to replace the whole steering wheel.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    dose the unshift work fine with the shifter? You way want to tak ethe steering whell one sout and clean then ect, but kinda odd that both don't work, any codes in the TCU?
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    Yeah the upshift works fine on the shifter, and I have no codes on vag-com, I ran it this weekend, I have an EGT that looks like its bad, but that has nothing to do with it.
    on the shifter when I move it over to tiptronic mode It kind of gets stuck, I should probably take that apart and see if any cable is cut or loose.
    Im gonna look for a write up on how to remove those panels.
    May 06 2009
    indy
    I don't know if the TCU switches the buttons on directly or via a relay. If it is with a relay I would start there...
    Try reading this and see if it helps.
    http://forums.quattroworld.com/a6/msgs/3985.phtml
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    wow this document has a lot of information, thanks.
    I'll check this in couple days on my day off.
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    I thought automatic cars shift for you
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    I noticed that the buttons dont light up.
    Aug 02 2008
    2001 AUDI S4
    ANAHEIM, CA
    I still haven't been able to figure this out, looks like im gonna have to go to the dealer.
    I also noticed my driver side mirror doesn't auto dim like the other one does??
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    Quote Originally Posted by DanS4 View Post
    lol
    __________________
    2000 S4 SRM K24's
    2002 Audi TT, 225q
    2012 VW Tiguan
    2013 VW Jetta
    Established Member Two Rings ///BlueS4's Avatar
    Jul 24 2011
    Milwaukee, WI
    I know this is an old post but i thought id ask, did you ever find out what the problem was with your steering wheel buttons not work?
    Jul 24 2011
    Milwaukee, WI
    Bump.....
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Quote Originally Posted by ///BlueS4 View Post
    Mine stopped working completely. I disconnected the battery and it started working again. But after a few months it acted up again. I'd try disconnected it first.
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Jul 24 2011
    Milwaukee, WI
    do you know if the tiptronic buttons on the steering wheel are connected to the relay for the horn? my horn doesn't work either and I don't hear it click from the relay when I push on it so I think it's bad.
