Results 1 to 40 of 40
    Feb 02 2009
    Montreal
    Front subframe replacement? wtf
    Went to the dealer last week because of a clicking noise when I would brake, advance and turn my wheels. Turns out they found it to be my front subframe.
    They ordered the piece and will replace it. I was shocked, how can this fail? I figured the bushings were worn or something.
    The service rep confirmed that it wasn't a bushing but the actual subframe. How can this happen?? My car has 82k kms!
    Out of curiosity is the part expensive? I can't find it online anywhere.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Front subframe replacement? wtf
    Maybe it's really the rear from a bmw?
    -Kris
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    I had this exact same issue with the front subframe. Dealer wanted $1500 to replace it as I was out of warranty at the time. Brought it to my indy mechanic who found out that while it was the subframe, the crap fold/pinch welds Audi decided to use was the cause. He welded up the seams along the folded areas of the subframe and clicking noise was fixed. Cost me an hour of labor ($60) to fix it.
    See pic: The arrows are pointing to the fold and pinch parts of the subframe. Those are all around the subframe piece. He welded up the seams along them.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Feb 02 2009
    Montreal
    wow 1500$ thank god I'm under warranty.
    What causes the clicking sound though?
    May 03 2005
    Boston
    It was the subframe flexing a bit around those folds. He was able to replicate the sound by putting a large pry bar between the top of the subframe and transmission then applying a little bit of pressure down onto the subframe.
    EPL S2 + TCU
    Previous Cars:
    Feb 02 2009
    Montreal
    hmm. Thanks for your response. I'm amazed at all the little things that have gone wrong with my car since I purchased 4mths ago.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by Philio View Post
    Pff rookie, I bought mine 14 months ago and expensive shit is still breaking on a regular basis.................
    Senior Member Two Rings wickedrick's Avatar
    Mar 11 2008
    2004 quattro 6MT - kawasaki
    Montreal
    i have the exact same problem, pretty weak if you ask me ... and i was making fun of my friend with his e46, shoul'd have keep my mouth shut lol !
    dealer is replacing mine this week under CPO...
    in about a year and a half, dealer replaced for at least 10000$ under CPO, i hope it stops since my waranty is almost done !!
    *** Oh and Philio, i think it's the montreal roads that are smashing our subframe to pieces !!!!
    May 03 2005
    Boston
    Wow, $10k?! I thought about buying a extended warranty after the factory one ended but decided to take the chance. Quotes I got were about $3000-$3500 for another 2 years or up to 100k miles. From 50k - 100k miles, I only had two major unexpected repairs:
    1. Steering rack leaked. That repair did hurt a bit, $1500.
    2. Wiper motor bracket seized, $500.
    Total cost was still less than a warranty in the end. Since those two unexpected repairs, it's been regular maintenance and replacing wear and tear items (shocks, control arms, etc).
    EPL S2 + TCU
    Previous Cars:
    Feb 02 2009
    Montreal
    Quote Originally Posted by wickedrick View Post
    10k...I'm climbing slowly to that mark too.
    I've had the car 4mths and my list so far is as follows (I'm sure I'm forgetting some stuff)
    - 2 coilpacks
    - heater core
    - catalytic converter
    - fuel sender
    - something under the shifter
    - Front wheel bearing
    - oil dipstick funnel
    - serpentine belt
    - and finally the front subframe
    Mar 11 2008
    Montreal
    my list goes on :
    1: complete new rad
    2: almost every gasket and seal
    3: control arm and bearing's
    4: subframe
    5: ABS module
    6: front airbags sensor
    7: lumbar support
    8: heated seat
    9: seat airbag + connector
    10: check valve
    11: window switch
    12: light switch
    13: coil packs.....
    and i had to change :
    1: flywheel n clutch
    2: rear brake pads
    3: timing belt
    and im sure i forget a lot ...
    at least i can say i used my CPO
    and now im pretty sure my flex pipe is shot since when i start the car cold, i hear the exhaust from the front !!
    and it seam that my car doesn't handle right, but ill wait and see after the subframe fix
    Mar 11 2008
    Montreal
    - 2 coilpacks
    - heater core
    - fuel sender
    - serpentine belt
    did you get a check engine for the catalytic converter ?
    May 03 2005
    Boston
    Some of those I would consider wear and tear and not "it broke" kind of repairs. Control arms, gaskets, seals, clutch, brake components and timing belt are all just wear items. Those would be expected on any car, not just Audi and is part of regular car maintenance. On some cars, they may last longer than others but at some point they'll wear out. At least your CPO is paying off!
    EPL S2 + TCU
    Previous Cars:
    Feb 02 2009
    Montreal
    yup, it happened right after 2 coilpacks failed so I guess it was related.
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    I'm having the same issues and found a part #, Supplier, and Price if anyone is interested. My sub frame is really beat up with rust and dents so replacing is more attractive to me.
    Part # for 1.8 Manual ONLY = 8E0 399 313 BD
    Price= $439
    Supplier is http://www.miramarvw.com/. Parts Department: 800-924-0561
    They're a dealership in San Diego so if you're not local, shipping will be a considerable price. (Shipping to Denver is looking to be about $40. They don't have one in stock so he guessed on the weight via FedEx)
    Have your FULL VIN when calling. Hope this helps!
    Previous
    USP B6 A4
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    MIramar seems to know what the hell is up. That's good to know. They are 10 minutes away from me.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Registered Member Two Rings
    Feb 09 2008
    nyc
    Has anyone had a front subframe fail twice? I just had it replaced under warranty and now two weeks later the same noises are back. What do they make these things out of - tin foil?
    Apr 12 2007
    Milwaukee
    miramar is genuinevwaudiparts.com
    Jul 18 2007
    Lancaster CA
    I know this is an old thread but Gallep did the clicking go away after the subframe replacement or did it eventually come back even with the new one?
    I need to get mine welded. Dang noise is driving me up the wall!
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by AudiCVT View Post
    We were roommates all through 2009. To the best of my knowledge, he has not replaced his subframe.
    Mar 22 2004
    Castle Rock, CO
    yep, I haven't replaced it yet due to lacking funds. Got married :)
    Previous
    USP B6 A4
    Aug 26 2005
    IMO, having the subframe welded as already mentioned by "gdawg\ 05a4", instead of removing the original part and installing a new subframe, is the only way to go, regardless of the warranty. The welded subframe will be stronger than the new part, and the original subframe does not have to be removed to weld the seams. A welded subframe must have the welds rattle can primed and painted though.
    Vorsprung durch Technik
    Veteran Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    If the little things that go wrong/need repairs really bother you, then maybe you should be driving a transportation appliance like a Toyota instead of an Audi. My Avant has had all the typical little problems also. However, owning and enjoying driving an Audi provides so much more refinement and quality of the experience, I don't consider the little problems as worth a second thought, they don't matter to me at all. My Audi satisfies me every time I drive it. Sometimes, I delay going home because I am having so much fun cruising in my Audi. Not everyone will be sensitive to the qualities an Audi offers and won't appreciate the obvious and subtle aspects of advanced engineering and quality construction an Audi provides. Most of the Audi owners here on Audizine are enthusiasts, as that is the case, routine little problems don't usually concern us much. Practically all makes of complex advanced design cars have characteristic problems.
    For many average drivers, a transportation appliance is all that is needed and is the better choice.
    This is really funny "maybe you should be driving a transportation appliance like a Toyota"
    I have never seen a post like this from you...
    well apart from the humor, I always wondered what was that "clak" noise on the b6's when you jack them up by the front subframe. I also tried to replicate the noise on mine since I changed all front suspension components and, i just let it be. Well I guess I will have to weld the subframe.
    Veteran Member Four Rings Styleprojekt's Avatar
    Nov 17 2006
    Salt Lake City
    God damn you guys have horrible cars. My 02 had 1 problem which was me blowing the steering pump doing donuts, besides that I cant think of anything that ever went wrong on my car in 4 years ownership besides stuff that I break by being an idiot
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by Styleprojekt View Post
    It's cause your low n' slow haha
    Nov 17 2006
    Salt Lake City
    Quote Originally Posted by [email protected]. View Post
    Which obviously pays off ;)
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Same here, I've had my '03 for 18 months now and in 30k km's I've done T-belt, brakes, and an oil dipstick. Nothing has broken, leaked, or stopped working...and my car has 210k kms.!! Maybe the Previous owner fixed everything for me hehe :P
    I'm just here for the free coffee
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by gdawg'05a4 View Post
    Good pic, but what is the typical failure mode? Do the pinch welds fail, allowing the sub-frame channel to open up?
    Jul 18 2007
    Lancaster CA
    I just got my car back from the automotive welder. Had him weld up all the seams he could get to on the subframe without taking it out. He cleaned it, welded one side and let it cool before doing it on the other side so that the heat didn't warp it, then painted it for protection. I am a happy camper. No more clak, click, pop, beeack sounds. I'll report back in 6 months to see if it's still the case. Dang these noises started 50K miles ago and now it's gone, finally. For a while I was felt like that guy in the free credit report commercial...when the girls pulled up and then his car jerked - in my case it was with an added clak, clunk or click. Thought it was the caliper at first. But after much searching on this forum I was able to remedy the problem so thanks guys, esp the tech who was able to figure that it was the subframe.
    Jul 03 2010
    New York
    I need to get my car up in the air to actually inspect for this, but for those of you who have had this problem, did the noise first appear while turning at slow speed? I've got something of a groaning noise occurring only under slow-speed turning (like pulling into a parking space, for example).
    Any way, anyone want to answer my previous question? ^^^^ i.e. What actually fails? Is it the spot-welds that fail, or is the part simply held together via the pinched stamping, and that's coming apart over time?
    Dec 12 2006
    Charlotte,NC
    I got weird noise's also, i keep forgetting to check when its on the lift. but my upper control arms are shot also, so it might be that
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Aug 26 2005
    The several parts of the front subframe are crimped together. Depending on how rough the roads are in your region, the stresses sooner or later loosen the crimps on the subframe allowing the several parts to move in relation to the other, causing the clicking and popping noises. Welding the seams stops the relative motion between the several parts of the subframe. New replacement subframes should be welded and painted before installation to avoid the problem from happening again.
    Jul 03 2010
    New York
    Good thorough response - thanks!
    Sep 02 2014
    Salem ma
    I have a weird scrape sound under my feet when I pull out of park I can feel it on the floor panel I'd love to know what it is
    Jan 24 2012
    Calgary, Alberta, Canada
    Can anyone re-host the pics of this? I want to see if my subframe issues are in the same place.
    Thanks guys!
    Oct 29 2005
    10speed
    San Francisco, CA
    FYI you can use a B5 subframe. Can probably grab one at the junkyard for $25.
    - Clint
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Necro bump. Can anyone post pics of where these seams fail on the B6 front subframe?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Jul 03 2010
    New York
    Quote Originally Posted by boy412 View Post
    I know there's a good pic in here somewhere - you might want to try search a bit.
    I recently tried to fix mine with a spot welder but I was in a rush and was unsuccessful. I think if using a spot welder you'll need to get the surfaces cleaned up to expose some bare metal and use some C-clamps to clamp down for better contact on either side of the target weld point.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by DPDISXR4Ti View Post
    Found it. Clicky Click
    Clint has already mentioned that a B5 subframe will work as a replacement. And I read elsewhere that a B7 subframe will work as well? I don't want to get TOO far ahead of myself but any knowledge on this I can collect the better. Going to crawl under the car later and see if I can identify any issues.
    ~Eric
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    FWIW, I am not sure a B7 subframe would be any better since it can fail just like the B6 one.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
