Page 1 of 5 123 ... LastLast
Results 1 to 40 of 180
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Error Code P0299: Turbo/Super charger underboost
    So I got a check engine light last night after reaching about 5000 rpms (don't go that high too often) and took it to Autozone and got this code pulled. The description their computer put out for 'Volkswagen' is as follows:
    Explanation:
    Faulty wastegate bypass regulator valve
    Probable cause:
    1. Mechanical damage at turbo/super charger
    2. Faulty charge Air pressure sensor
    So all that I can glean from this is that it was caused by either the diverter valve or MAF sensor. Since I've heard that a torn DV doesn't usually throw a CEL, and that I didn't notice a loss in boost (don't have a gauge to exactly confirm it), that would leave the MAF. I don't have a K&N so no oil on the MAF from that.
    He cleared the codes, and it didn't come right back, but on the drive home I didn't get too high in the RPM range, either.
    Guy's have any thoughts?
    PS: I guess the fuel injector cleaner he sold me after pulling code P2099 (fuel injector failure) won't help much......oh well guess it won't hurt to throw it in a tank.
    EDIT: I figured if anyone found this while searching and wanted to know what was done in my case to resolve the issue it would make sense to add it. I took off my MAF sensor first as that is relatively easy to do and found no reason for it to have sent the code. Next I took off the DV and found a slight tear in it. The tear was not big enough to cause all boost to leak, but enough that at higher RPMs and higher boost, the computer would notice the leak. I ordered the new "D" revision diverter valve and put it on. After riding around and getting into higher RPM range the CEL has yet to return.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Feb 09 2008
    2006 A4, 2006 4Runner
    Colorado Springs
    Re: Error Code P0299: Turbo/Super charger underboost
    DV is usually the culprit, but not always. When mine failed though, the loss of boost was definitely noticeable.
    Established Member Two Rings Chr1sJohnson's Avatar
    Sep 28 2007
    07 Audi Q7, 83 CJ7, 07 Harley Night Rod, 67 Triumph Bonneville
    Charlotte, NC
    Hey did you ever resolve your issue? I am currently having the exact same problem. I took my car to GMP performance in Charlotte and their computer read CEL P0299.
    My turbo doesn't seem to be boosting at all.
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    When my Forge DV was loose I got that code, not sure if this helps but it seems like a diverter valve issue. IMO
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Check the DV, otherwise it's possible to have a small boost leak.
    Then again, my buddy just had his turbo replaced on his 2.0T FSI at 39K because it had a faulty wastegate.
    Could be worth checking into.
    Sep 28 2007
    Charlotte, NC
    Quote Originally Posted by djwimbo View Post
    Do you know what led to the faulty wastegate? I actually put 110 octane fuel in my car without knowing it contains lead. Perhaps the fuel lead to something more serious? My car runs perfect until I really get on it.. there is no boost what so ever.
    Jul 28 2009
    Jupiter Florida
    I had the same p0299 turbo underboost code and replaced the DV over a week ago with revision D, the p0299 code has come back, any clue as to what to look for next? That's the only code.
    Mar 09 2009
    Irmo, SC
    You might have a boost leak elsewhere. If you have any way of doing a pressure check, I'd recommend that. The heater hoses that carry the air to and from the intercoolers could be at fault. The MAF sensor could also be at fault for reading incorrectly. This might happen if the MAF sensor was dirty.
    If you have access to a full VAG-com and can run boost logs, you should be able to tell if it's actually a leak or a bad sensor.
    Veteran Member Three Rings Stea1th's Avatar
    Aug 25 2009
    New York
    mine was a faulty wastegate
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I'm still getting my p0299 code to.. I'll try to check out my MAF and the DV is the latest piston driven one.....
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jun 15 2008
    Providence, RI
    i just had this code with my 06 A4. ended up being a bad wastegate and the whole turbo assembly was replaced
    Veteran Member Three Rings CystmX's Avatar
    Feb 04 2010
    Andrews AFB, MD
    I got the code about a month ago got it cleared and it hasn't came back on. However I would like to add that I don't feel the car drives the same since then. I've gunned it a couple of times and it just feels sluggish.
    Senior Member Two Rings bergy12's Avatar
    Mar 13 2009
    Potomac MD
    I've had this code for awhile now. Comes on when I go wot and usually clears after a few cycles. I've checked the dv and a few other things but still havnt found the problem.
    2015 S4 Black Optics /Sports Diff/ B&O/ Carbon Fiber/ EPL Stage 1
    Sold: 2005.5 A4 Quattro
    APR S3 K04 Conversion, JHM HPFP, 142 Bar Rail Valve, GFB DV+, RS4 LPFP Controller, CTS Turbo FMIC, Zury Fabrication's Custom Turbo Back Exhaust, BSH Stage 2 Catch Can, BFI Snub Mount, AudiUp Turbo Inlet Hose,Koni FSD/ Eibach, RS4 Sway Bar.
    Jun 15 2009
    2007 Audi A4
    IL
    I had mine for about 1 year now, and i have nothing but problems with my car. Also talked with people with APR and REVO, told me that these engine FSI 2.0T are piece of carp. That’s why Audi/VW replaced the engines with TFSI much better engine!!! I hope to get a better job and get rid of that piece of crap car. I spend crap load of money and time on it. Good luck with the codes. I have engine light on mine as well. But i just put tape over the gauge cuz i can’t stand looking at it anymore!.
    Jan 05 2012
    Shreveport, La & KCMO
    I just had this come on yesterday and got the P0299 code. Checked the hoses and they looked fine (my car also went in a ditch ) so I figured it had to be the DV. Felt sluggish and went through 3/4 tank of premium in 240 miles! Luckily the stealership had the part on the shelf. Went and paid 125 (including tax) for the new revision D diverter valve. Since I'd already ripped off my belly pan it was easy to get to but those stupid nuts holding it on was a pain to get off. I read some conflicting information and used a Torx 30 to get them off, only to find that they were actually 5mm allen head bolts. I had to go buy a 2" 1/4" drive spacer to fit with my wrench and bit because the bit was too long. Anyways, got the old dv off and saw a small tear in the diaphragm, so that was the culprit. Thank God. Put the new one on and she runs like a sewing machine. And the tick-tick-tick I used to hear loud and clear has quieted down. Hopefully the gas mileage will improve but I haven't driven it much since. FWIW.
    Jul 10 2012
    Orlando, FL
    got the P0299 code after upgrading ECU to stage 2. My DV was fine when I check it - had newer revision. No noticeable boost pressure loss.
    What is the best way to diagnose this CEL?
    Established Member Two Rings redlegs13m's Avatar
    Oct 04 2009
    09 shelby gt500 kr
    Cary, NC
    does anyone know if a PCV failure will trigger the P0299 code I just had my DV replaced less then 6 months ago. I am getting noticeable suction under the oil cap while the engine is running, so from what I have read my PCV is toast. I also have the APR stage 2 flash but that was done over 2 years ago so I'm pretty sure that's not the culprit in my case.
    "For those Who Have Fought For It, Freedom Has A Special Flavor The Protected Will Never Know."
    -UNKNOWN
    B7 A4 6speed carbonio air intake//billy boat stealth exhaust//apr stage II ecu upgrade//koni FSD+eibach pro//podi stepper guage and column pod// blacked out oem grille // blacked out rings front and rear//RS4 rear sway bar owned but not installed// vmr test pipe// tail light tint
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    Quote Originally Posted by redlegs13m View Post
    ^This
    I had P0299 Code for some time. I deleted this error and after some hard driving it came back.
    I knew my PCV was bad, because of oil cap being sucked in...
    Went with BSH PCV Fix and problem is gone.
    2005.5 Audi A4 B7 2.0TFSI Quattro 6MT
    |Visuals: Lip Spoiler CF / Headlight Blackout + Clear Corner / LED Number Plate / Smoked LED Tail Lights / RS4 Grill / Night Braker Plus / S-line Door Blades / Gunmetal RS4 18" Wheels|
    |Performance: ECU Tune / Test Pipe / K&N Air Filter / Vast Perfromance Stage II Clutch / S-line Suspension|
    |Maitenance: BSH PCV FIX / Diverter Valve Revision D / Fuel Pump Cam Follower / Purge Valve N80 / Seafoam / Coil Packs Revision F / Spark Plugs NGK BKR7EIX|
    Oct 04 2009
    09 shelby gt500 kr
    Cary, NC
    Quote Originally Posted by NODO-GT View Post
    are you talking about the pcv plate or the catch can system.
    i know there are a lot of options i'm just trying to figure out the most cost effective way to fix this that is not detrimental to my vehicle in any way.
    -UNKNOWN
    Jul 30 2010
    Tbilisi
    PCV Fix is a plate option for about 90$.
    Dec 03 2012
    United States
    Where did you purchase this? Have you seen a DIY?
    Jul 30 2010
    Tbilisi
    Bringing an old thread back!
    Again Problem is back... all mods in my discription.
    I have noticed that whole winter I didn't get this code, but it came back as temperatures rides again. I comes at WOT....
    I have no clue what to do, cleaned MAF, Replaced DV, Installed PCV Fix...
    the only thing left wastegate? or are there any other options?
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    good luck man. I have changed so much crap out trying to see why I still get the code. I still really only get the code in higher gears when I am doing like 4th and 5th gear pulls. I have yet to have it pop on me during logs pulls in 3rd, but it does pop up when I'm not logging, weird up lol. Damn car is grumpy man.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    I've recently joined this club... I think i need to adjust the wastegate on the k04 after all the reading I've done on the subject. I am deciding if I should mess with it, or go with this.
    Has anyone adjusted their wastegate or have any experience with forges wastegate?
    Aug 05 2011
    CO
    Look up jimrobbington. he did a wastegate adjustment had has a DIY in the tech forum n the B7 thread
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Aug 03 2012
    '11 Touareg
    SEPA
    Found it. Thanks Seal.
    Most of the other threads I've found have been with vw's
    Mar 09 2009
    Irmo, SC
    If individual components are not at fault for this code, it could just be that you have a boost leak in a hose somewhere - even a pinhole could be enough to trigger the code while not be noticeable in daily driving. The only way to diagnose that would be to do a pressure test. There are some DIYs out there on how to do this.
    Jul 30 2010
    Tbilisi
    I want to do boost leak test.
    Which test is better, smoke machine test vs pressure test?
    I have option of paying 30$ for smoke test or building pressure tester myself...
    I guess this tests will not show any problems with wastegate right?
    I also have low MAF readings, could that be a reason for boostleak?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    It depends on what you want to do. Pressure test or smoke test will both get the job done. It won't have effect on yor wastegste because the pressure isn't enough to move it.
    If you own an air compressor I would make the pressure testing tool. Jimeobbington has a nice write up on it. Otherwise if you want to save yourself some time just get smoke tested. Having your own tool is nice because you can diagnose quickly, you can work from home which is cheaper than the dealership/expensive shop, and after you sped the money on the supplies for the tool all you're boost leak tests will be free!
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Tapatalk double post
    Mar 03 2008
    Wifie's Subaru
    Pittsburgh
    If you still have the original diaphragm style DV, I bet it's torn. Mine tore when downshifting to pass a schoolbus. The code cleared after replacing the DV with the new revised one.
    Search, there are some good DIYs. BTW, I'd much rather have a bad DV than try to chase down a boost leak somewhere...
    Established Member Two Rings frankvan's Avatar
    Feb 08 2012
    B9 S4, B7 RS4, B8 A4, Cherokee, Sprinter Camper, Volvo XC60 T6, Ducati Panigale
    St. Albert
    just got this code (0299) today while driving on the highway.
    Cleared it and it has yet to come back, however my boost gauge is only showing a peak of 5 and holding at about 3.5 (yesterday it peaked at 15 and held at 13 psi).
    DV? Wastgate? Intake leak?
    Feb 08 2012
    St. Albert
    Yup, dead diverter valve. One big tear (red) and pinhole tears forming (blue) where the rubber diaphragm "pinches" when it's compressed. Definitely a poor design.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Im getting the code occasionally but when I reset aka removing a battery terminal then reinstalling it goes off for a few months..there is a slight lost in boost but not anything worrisome...Where in Canada can I pick a DV valve instead of a dealership...ordering from the US shipping is almost $25 plus duties.
    Jun 15 2009
    2007 Audi A4
    IL
    I got this bad ass code this morning while driving on the high way in 4th gear. I hear that my turbo makes funny sounds when it goes down to idle, sounds like a rattle between 3.5k RPMS to 1200 RPMS, only when its about to idle at 700-800 rpms.
    And while driving, i was to lazy to switch the gears and downshifting, decided to add more gas, well I didn't notice any leg like some of you guys, but engine light came on.
    So I"m thinking, 2 things could go wrong or 3 lol,
    PCV Valve, Divert Valve which i have the new Revision, or Turbo is about to take a dump! I"m at 88K miles on my car..
    I haven't had real problems with the car for the past 2 years. now winter is coming and yea... shit is about to start!
    BTW where can i buy OEM turbo?
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    I've had this issue ever since I went APR STG1. DV is brand new and I'm yet to perform a pressure test, so I can't rule out a boost leak. Other than that, I would be leaning toward the wastegate. I'll adjust it per the DIY when the time comes.
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jun 15 2009
    2007 Audi A4
    IL
    ON mine it sounds like it could be a bad turbo, I drove it this morning, and was looking on ODB II with tablet to see if any leaks or any odd things happening, and i couldn't find anything,,, it hits 15-16 PSI at full boost no issues... F-ing cars lol!
    I will be looking at DV Valve to see if anything is wrong there...
    I got APR STG1 as well, :)
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    brendan, haven't you been stage 1 for like ever haha??
    i've had this code when i was stage 2, only started happening a year after i bought a tune for the car...
    but i've had a boost gauge the whole time and it was really obvious that i was still hitting 21 psi
    still happens today, a full engine build and BT later. no one knows what causes it
    Jun 15 2009
    2007 Audi A4
    IL
    I have cleared mine yesterday and didn't show up even after few hard pulls... oh well F it, it it comes up back up, Ill just blow that car up :)
    Active Member Two Rings jcr223's Avatar
    Dec 09 2011
    PA
    Most Likely a faulty waste gate If you have already replaced diverter valve, and concluded there is no boost leak. If you roll your passenger window down and let the engine decel you will hear a slight tapping noise, similar to a baseball card in the spoke of a bike as the RPM's wind down. I'm currently dealing with this as well....
    I seek a new turbo .... :)
