Results 1 to 12 of 12
    May 18 2008
    tn
    Smile Pioneer AVH-P4000DVD installed
    Thanks to Enfig and Crutchfield for all my adapters and to gray6spd for getting the head unit shipped out so fast!
    Was going to do myself but at the last minute I figured I would let a professional install it. Thanks to Radio Clinic in Chattanooga!
    I have the iPod cable, Sirius radio and my video bypass hooked up!
    Established Member Two Rings whoosh's Avatar
    Feb 07 2009
    Belfast, Maine
    Re: Pioneer AVH-P4000DVD installed
    Looks great! What wiring and dash kit did you use?
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    did you use enfigs new can-bus cable? so steering wheel controls and everything work plug and play?
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    May 18 2008
    tn
    Quote Originally Posted by whoosh View Post
    Metra 70-1787 wiring harness
    Metra 99-9102 dash kit
    Metra 40VW53 powered antenna adapter
    Pioneer ADT-va133 double din install kit
    A relay for defeating the video while stopped feature
    I didn't use the Enfig can bus controller because I don't have steering wheel controls.
    Veteran Member Three Rings gray6spd's Avatar
    Jan 18 2009
    is nonexistent
    texas
    Looks awesome!!! Im glad it ended up in great hands. Enjoy it man!
    PREVIOUS:
    2004 1.8T Dolphin Grey- Quattro - 6MT - Sport Package - K&N - 35% - Stage: still in college and broke -
    2015 S4 3.0T Sepang Blue Pearl - DSG - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber - Totalled by a damn F150
    CURRENT:
    2015 S4 3.0T Daytona Grey Pearl - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber
    2012 Infiniti G37 Sport 3.7L Obsidian Black - Eibach Springs - K&N -
    Proud of my pink coolant.
    Feb 07 2009
    Belfast, Maine
    Can you explain the video bypass relay? Thank you.
    May 18 2008
    tn
    On the relay you have numbered tabs, 86, 87, 87a, 85 and 30. On Tab 87 and 86 you attach a ground wire. Tab 85 to the remote wire coming from the headunit (P-cont / amp turn on) and then the parking brake wire (from DVD player) goes to tab 30.
    it allows you to watch video while in motion. A warning screen comes up and says legal mumbo-jumbo, you hit ok and it works!
    Feb 07 2009
    Belfast, Maine
    Thanks^
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Quote Originally Posted by bmidd View Post
    Do you connect your amp to the remote wire connected to the relay?
    May 18 2008
    tn
    no because I'm still using the factory amp and speakers.
    Established Member Two Rings Jerzyboy973's Avatar
    Jun 08 2009
    00 A6 2.8 / 04YamaR1 & 07R6
    Astoria NYC
    Quote Originally Posted by revbjeff View Post
    If you are using an after market amp you would still connect it to the blue remote wire from the head unit.
    May 15 2009
    lone tree
    Did your stereo come with the trim ring or did the one from the adt-va133 install kit work?
