Results 1 to 28 of 28
    Active Member Two Rings dmeteny's Avatar
    Apr 27 2009
    2008 Audi A3 S-Line Titanium
    Pittsburgh
    AC smells like piss
    Why's it smell like piss when i turn on the AC of my '08? To my knowledge no one has pissed anywhere in or around my car.
    What could be causing this?
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: AC smells like piss
    mold building up in your ac system tell ur dealer there should be a tsb out on it.... if not they offer ac deod services for cheap
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Replace your cabin filter, and you should be fine
    May 19 2009
    Alabama
    new vw's and audis have this prob , replacing your cabin filter will not help
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    we do these all the time here in az. just get a a/c bomb and follow directions. remove pollen filter and a/c setting low fan speed low with recirc on. put the bomb in passenger foot area. open the bomb and shut doors let a/c run for 30 min. open and air out car.replace pollen filter
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Established Member Two Rings lilken21's Avatar
    Jul 20 2007
    I bought my '07 A3 used and the AC had that piss smell - I took it to the dealer and told them about the AC stank and they took care of it.
    His: '07 A3 3.2 DSG quattro Brilliant Black// KONI COs // H&R front and rear sway bars // Neuspeed cat-back exhaust // EVOMS V Flow // Haldex Gen2 control w/switch // Revo ECU upgrade // VF Engineering motor mounts // 12.5mm front / 17.5mm rear ECS spacers ...more to come
    Hers: '08 A4 Avant 2.0T tiptronic quattro Quartz Gray // APR ECU StgI // B5 front lower spring perches // 17.5mm rear ECS spacers...more to come
    May 19 2009
    Alabama
    you are right the ac service will work nicely it may take two
    Senior Member Three Rings jokas's Avatar
    Jun 11 2004
    2003 Audi A4 1.8T Quattro
    North Jersey
    1Z Einszett Klima-Cleaner - A/C Odor + Bacteria Cleaner
    can be purchased from phil here:
    http://www.detailersdomain.com/index...PROD&ProdID=41
    also always check around, usually a coupon or something floating on the board...
    Senior Member Two Rings tekieru's Avatar
    Feb 27 2009
    08 Infiniti G35x/09 VW GTI
    San Francisco, California
    this kinds of shit scares me about Audi/VW.
    FML - never get the car i want... now im stuck with a black 08 G35x = /. i want AUDI or VW!
    Established Member Two Rings tdota3mike's Avatar
    Mar 12 2009
    2006 Audi A3 2.0T
    Toronto ON
    Quote Originally Posted by tekieru View Post
    its been in BMW's much much longer ;) its a comman issue with german cars... frankly this is the last thing i would be "scared" of...
    Apr 27 2009
    Pittsburgh
    Thanks for your replies. I'll call the dealer on Monday.
    schmally, what's a TSB?
    BTW, for those of you thinking you may have the same problem. I've noticed it only smells when using the AC and its worse on humid/hot days.
    Veteran Member Three Rings pcasso87's Avatar
    Feb 12 2009
    Jetta a4
    OMFG piss smell, lol you could have not described it better. Mine smells like piss as well!!!!
    Veteran Member Three Rings mikevets68's Avatar
    Mar 30 2008
    Retired. 2007 Brilliant Black Audi A3
    Irvine
    Mine smells more like a musty 10 month old sock! lol
    euro.techniks | West
    2011 Phantom Black Audi A4 - Sport Package Premium+
    Retired 2007 Brilliant Black Audi A3
    Feb 12 2009
    Jetta a4
    Quote Originally Posted by mikevets68 View Post
    Mine smells like mariachi ass and thai hooker!!!!
    Jul 20 2007
    Quote Originally Posted by pcasso87 View Post
    wow - you've stuck your nose in some mariachi's a$$
    Mar 30 2008
    Irvine
    Quote Originally Posted by lilken21 View Post
    pwhahahaha!
    you haven't?
    Jul 20 2007
    you haven't?
    don't ask don't tell
    Established Member Two Rings Longfist86's Avatar
    Nov 01 2008
    08 MkV GTI, 09 Jetta
    Dade county
    the dealer will perform an "airsept" treatment. if you want you can run your heater on full blast for about 1/2 hr and spray lysol in the fresh air vents let it circulate through the sysyem and you'll be good.
    I have found that this problem occurs more often if you constantly use your recirc button.
    GERMAN CAR DEPOT
    2130 Fillmore St.
    Hollywood, FL 33020
    954-921-1515
    www.GermanCarDepot.com is your dealer alternative.
    Registered Member Two Rings BOLLOCKS_TO_IT's Avatar
    Apr 29 2009
    2004 AUDI S4
    Earth
    i have an 04 S4 and my AC smells awful, i just changed the cabin filter and it didnt make any difference, you should definetly go to the dealer and get them to clean out the AC system
    Apr 27 2009
    Pittsburgh
    Thanks again for the responses. I'm definitely going to let the dealership take care of this problem.
    Is this something that'll I have to deal with repeatedly?
    Feb 12 2009
    Jetta a4
    Quote Originally Posted by dmeteny View Post
    If you have a lot of mariachis in your car and thai hookers yes
    JK.... I cleaned it two months ago and its ok for now.
    Apr 27 2009
    Pittsburgh
    I have a strict no mariachi/thai hooker policy now. Strippers and non-Mexican folk bands welcome.
    Thanks, picasso87.
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    I can explain exactly what's goin on and what causes this.
    Basically, you are using your A/C on hot and humid days and then abruptly turning it off when you shut your car off. The inside of your air ventilation system builds up condensation really bad and that liquid gathers up and goes stagnant. Mold forms and that is what you are smelling, built up moldy condensation.
    To solve this, the best way is to do this: A few minutes before you reach your destination, switch to econ and let the ambient outside air dry your system out and normalize the temp of the ventilation system interior so that it does not condensate when you shut your car off. If it already smells, open all your windows and run the heat on high for 10 minutes to dry the system out really good to start with, that should give you a clean start for the most part.
    A lot of cars do this these days, especially expensive cars with advanced climate control systems (go figure).
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Feb 12 2009
    Jetta a4
    Quote Originally Posted by DELUX View Post
    That sounds pretty damn logic to me , good suggestion !!!
    BTW: For some odd reason every time i switch on the econ mode my windows start to get hazy why the hell could this be, is it because of the mold???
    Established Member Two Rings Ryan.'s Avatar
    Mar 08 2009
    '02 A4 3.0 6-Speed
    Roswell, GA
    No thats because econ mode shuts off the AC compressor and the air coming out in the car goes from being ice cold to warm and maybe even a little humid if there is condensation in the AC evaporator
    its like breathing onto your windows :)
    Aug 27 2008
    06 A3 2.0T
    San Diego, CA
    Good thread! Lots of good lil' tips!
    06 Brilliant Black A3 DSG 2.0T | OEM 18" Ti wheels | Neuspeed Rear Sway Bar | APR ECU Flash | OEM Ti grill | 20% Huper Optik tint
    Apr 27 2009
    Pittsburgh
    DELUX, thank you.
    You = Mr. Wizard.
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    lol i dont really have anything productive to add, but i LOL'd when i saw this thread title as the preview of the A3/S3 section
    -Grant
    ig: g_strachan
