Results 1 to 8 of 8
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    19mm Neuspeed Anti-Sway Bar Install on Avant
    Last Sunday I installed the Neuspeed RSB (thanks Brian) on my Avant. The bar was sold as 22mm, but with crude measuring, I'm confident it's in fact 19mm with the upgraded sub-frame reinforcement brackets.
    All went well as you can see by the photos:
    But I have a few concerns (yes I searched and spent hours reading every RSB post available):
    I lubed the bushings well with marine grease as expected. I noticed that after all was installed, I could shift the bar slightly back n forth in the bushings. The bar has no welded in stops like some of the Neuspeed units I've seen and the poly bushings don't grab the bar tightly.
    Is this because of all the grease I used? Is it supposed to do this? Does your RSB do this?
    2nd issue:
    After lowering the car back to the ground, I can't even get my pinkie (flat way) to fit between the end-links/uprights and the rear axles. I've been driving it this way for about 3 days w/ one run up/down a twisty back road. I crawled under and could not see that there are any signs of them actually rubbing/damaging anything.
    Is this because I'm lowered that I have to be concerned about this clearance? Do stock height PPL have this problem? I know the solution is metal end-links, but I only paid two bills for the bar shipped and I'm not excited about dropping another $47 each on links.
    Any comments on this?
    I know of another solution that has been tried with success and posted before:
    http://www.robsaudiworld.com/neuspeed.htm
    This document shows 1/4 inch spacers can be placed behind the bushings to provide more clearance. Scroll down.
    So I made up some aluminum spacers today, but have not installed them yet.
    Q: Do you think I have enough clearance without them, or have I just not done enough spirited driving yet that I'm detecting a problem?
    Anyone else have this RSB kit and how much space do you have between up-links and axles?
    Any input appreciated - sorry so long. Thanks!
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Account Terminated Two Rings
    May 25 2007
    Stage 3 EPL 2001.5 B5S4
    Madison, WI
    Re: 19mm Neuspeed Anti-Sway Bar Install on Avant
    Well I know that the bar was on a B5 S4 sedan that was wrecked and I am not sure if the sedan and avant model sways are interchangeable....
    Sep 03 2008
    Wareham, MA 02571
    Quote Originally Posted by ajb_unc View Post
    I was assured that they are, and from reading, I believe this is true. I'm well aware of where the bar came from.
    Thanks for the input - maybe I will look into this more.
    EDIT: Fits Avants!
    zoom
    2000-2002 Audi S4 - Neuspeed Sway Bar Kit - Race - Black
    Our Price: $365.64
    Free Shipping
    Quantity:
    Part Number: N242502194
    MFR#: 2502194
    NEUSPEED ADJUSTABLE SWAY BAR, REAR, BLACK -- 19mm, The Ultimate In Handling, Eliminates Body Roll, Safety And Appearance, The Highest Quality Steel With A Liquid Look, Race Quality Ball-Joint Ends Provide The Best In Sway Bar Response, Poly Bushings And Custom Formed Brackets Utilizing Grade 8 Hardware, Make Mounting A Snap, Highly Engineered Bolt-On System
    Finish: Black
    Series: Race
    This Product Fits the Following Vehicles: Live Help
    2000-2002 Audi S4
    * 2000-2002: Base; 6Cyl 2.7L;
    * 2001-2002: Avant; 6Cyl 2.7L;
    The problem with clearance is def not isolated to Avants...
    Sep 03 2008
    Wareham, MA 02571
    Guess nobody runs the Neuspeed bar...I'm going to bed...
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    I run the Neuspeed 19mm and I'll look into it. I don't think mine has been hitting the axles thou and I'm lowered.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    How do you like the performance aspect of the sway bar? I'm looking at getting one soon for the rear and was looking into a Neuspeed sway bar.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Sep 03 2008
    Wareham, MA 02571
    Quote Originally Posted by skunkoncrunk View Post
    Bars great so far...like I say, I've only been running it for a few days. Only did one twisty road run, no skid pad or anything. I have it set on the softer setting for now as I want to get a feel for it w/out any snap oversteer or anything.
    The car seems a little more neutral and the rear comes around a bit easier now. I'm still playing with it and may try out the firm setting when I'm comfortable with the install. The sub-frame brackets are sturdy as hell. Impressed so far, but will report back later...
    Sep 03 2008
    Wareham, MA 02571
    Quote Originally Posted by Dimcorner View Post
    Great, cool...thanks for the response...
