Results 1 to 40 of 42
    Registered Member Two Rings DieselRoxie_B6's Avatar
    Sep 24 2007
    2002 Audi A4 1.8TSport Package
    Hollywood, CA.
    ABS and Caution light on ???? What does this mean ????
    Last night, out of nowhere my Caution light with a triangle came on and the ABS light. Just those two lights are on. No CEL light. Anybody know what this means??
    Please advise if this is anything to be concerned about??
    I have a photo of the lights on, but don't know how to post it up on here???
    Veteran Member Three Rings hbodo08's Avatar
    Apr 06 2009
    04' a4 3.0 ** 02' envoy slt--85' iroc z 28 (7400 original miles) 2010 Mercedes e350 4 matic
    The ville, Ohio Akron, Ohio
    Re: ABS and Caution light on ???? What does this mean ????
    post it using photobucket.. and i think had this problem if i can see the pic to be sure
    I drive it like i stole it , then again
    /____________________\
    [_oo_\===0000===/_oo_]
    \_o___[HMB-30A4Q]___o_/
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Thermostat.
    Scan the car for errors.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by Tgr_Clw View Post
    Thermostat.
    WHAT?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 06 2009
    hey dirtybrd dosent this sound like my problem when i went through the car wash
    Sep 24 2007
    Hollywood, CA.
    Let's see if I did this right. [IMG][/IMG]
    Sep 24 2007
    Hollywood, CA.
    I don't have the VAG machine. Damn : (
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by hbodo08 View Post
    I don't recall.
    I'm back bitches!
    Apr 06 2009
    Quote Originally Posted by dirtybrd View Post
    I don't recall.
    http://www.audizine.com/forum/showthread.php?t=285597
    this was my problem and the same lights were on
    Apr 06 2009
    I don't recall.
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    its ur brake light switch
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by schmally View Post
    x2 on that one. I had my ESP light stay on because of my maf but when i was reading about it a brake sensor was a common cause for this. Don't recall the ABS light being part of this though. But scanning will do you no good since you don't have a CEL....
    - Justin -
    Sep 24 2007
    Hollywood, CA.
    So what do I do? How do I fix this?
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    WHAT?
    Sorry. Meant to type that it was most likely the brake switch.
    Don't know wtf I was thinking.
    Appearance: OEM+
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Quote Originally Posted by DieselRoxie_B6 View Post
    Do you have a cold air intake? Does it happen when the car is started at cold start? meaning in the mornings? Do you hear your jet section pump kick in? Does the lights go away?
    other thing can be your breake light switch..
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by msharifi View Post
    Why would a CAI do this? Unless it was the MAF sensor, in which case he would have a CEL saying his MAF sensor was reading too low or "incorrect flow" or what not. And that wouldn't cause the ABS light to come on as well.
    If it's his brake light switch the light should only come on when there is a signal applied to the brakes from what i remember. I think someone initially figured this out because they tried starting their car in park (on a tip of course) without the use of the e-brake and the light wasn't there, but as soon as they applied the brakes the light came on. Just one thing to try out. And if you're a manual you could try this on flat ground, just take off the e-brake and start it without using the brake pedal. See what happens.
    - Justin -
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by SeatownB6 View Post
    There are hundreds of codes that can be stored without tripping a CEL. Have you used vag-com before?
    Senior Member Two Rings spelunking's Avatar
    Apr 05 2008
    Tampa, FL
    Um, I'm absolutely positive it's because THEY ARE ACTUALLY USING THE TAPE PLAYER!! I mean seriously?
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by skeeball View Post
    I don't own a VAG-COM, as i'm sure the OP doesn't. Unless he has access to one, or someone local from here can hook one up for him, he would have to use the same thing everyone else without one does, and that's a simple OBDII scanner from somewhere like autozone which would only read his codes. But yes i've used a VAG-COM before, it's just a very expensive piece that i wouldn't expect most people to own. But yes, with a VAG-COM you could find issues without having a CEL.
    - Justin -
    Sep 20 2006
    Baltimore
    There is a standard OBDII PID, or p-code, for the brake light switch (P0571). So it may show up on a standard OBDII scan. Dollars to donuts that is the culprit here since it's the most commonly found issue that fits the symptoms. But it's not the only one and scanning would take the guesswork out of it.
    Here is DIY on replacing the switch. It's an inexpensive part with a high failure rate that is easy to replace. So doing so wouldn't be a bad troubleshooting step. You can also save a few bucks by picking one up from a VW dealer as opposed to an Audi dealer.
    Jul 04 2008
    Seattle, Washington
    yeah the problem is that the symptoms fit the problem, he just doesn't have a CEL. But if the issue hasn't triggered a CEL wouldn't a standard OBDII not read it like a VAG-COM could?
    - Justin -
    Sep 20 2006
    Baltimore
    If the code is stored, the OBDII scanner should be able to pull it. I use a vag-com though.
    Jul 04 2008
    Seattle, Washington
    oh, well it seems like from my experience with using an OBDII scanner and then using John's VAG-COM is that the VAG-COM pulls up all the codes including past codes and intermittent codes and the OBDII only pulls up the current codes that are triggering a CEL. Although i've never come across any codes that come up that don't trigger a CEL unless they are a past code or intermittent in the first place.
    - Justin -
    May 19 2009
    Alabama
    replace ur brake light switch they are cheap get one from ur dealer
    Sep 24 2007
    Hollywood, CA.
    Quote Originally Posted by spelunking View Post
    Correct a tape player, that is an adapter to hook up my iPhone to play my music. We're in 2009, thought you would know about tape adapters.
    Please strictly useful info, from knowledgeable people that can help me on this matter. No talk about non sense, like a tape player.
    Sep 24 2007
    Hollywood, CA.
    No cold air intake. And no it's not when it's cold only. As you see it was 78 degrees last night. So the car was warm.
    Weird thing is, that this morning when I turned on my car, the lights were off.
    Apr 05 2008
    Tampa, FL
    Serious much? Relax guy, it's just a post in a car forum, not every single last post on audizine has to be serious. Tape adapters also aren't anywhere near to being relevant in 2009, but whose counting right?
    Sep 24 2007
    Hollywood, CA.
    1) I'm a girl.
    2) You really must have nothing else to do.
    Aug 13 2008
    Orange County Cali
    At cold start if the CAI does not work you get that 2 lights on it happen to my self when I had a cold air intake and once I put back the stock the problem was gone.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    I'm having the exact same issue. Sometimes it comes off after a few restarts. I'm thinking it's my MAF as I've been having MAF issues since last year, but if the Brake Light Switch is only $5, I'd rather it was that.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Aug 13 2008
    Orange County Cali
    I meant to say is does the lights turn on when you first turn your car in the morning. Say you park your car at night and start it the next day does the light turn on or stays on all the time?
    Jul 04 2008
    Seattle, Washington
    Yeah and that would be associated with the MAF. If the CAI doesn't work it's not flowing over the MAF correctly, which is what causes the ESP light to stay on. I have an aftermarket CAI and i reversed it and removed an elbow to fit better without realizing the MAF only reads one direction because of an air inlet channel. So as an affect of that my MAF was reading too low causing my ESP light to stay on. The MAF and the ESP run on the same circuit along with the brake switch, which is why if one is bad or going bad it will trigger the ESP light. But i'm not sure about the ABS since if it's MAF related it most likely won't be on. Mine was MAF related and was just the ESP without the ABS light.
    - Justin -
    Sep 24 2007
    Hollywood, CA.
    Quote Originally Posted by Pr0n View Post
    What exactly is the MAF? Sorry for the dumb question. And how would I repair/fix this?
    Sep 24 2007
    Hollywood, CA.
    No not at all. They rarely come on. I have owned the car for about 2 yrs. and they have only came on about twice or three times at most. Then they will go away all of a sudden.
    Sorry for the confusion.
    Established Member Two Rings Audi_Doody's Avatar
    Nov 25 2008
    2004.5 Audi A4 1.8T Q 6spd B6
    San Diego, CA
    Hi there. A MAF is a Mass Air Flow sensor. It comes straight off of your airbox or CAI (Cold Air Intake) if you have that in place of an airbox. Looks like this:
    One of the guys who suggested this would know more about what needs to be done. Although, I'd start with the cheapest possible solution (the brake light switch).
    Just figured I'd try to help out.
    Audi A4...The luxury car for people who can park themselves. http://www.youtube.com/watch?v=bKYz5WJFr48
    Nov 25 2008
    San Diego, CA
    P.S. Nice B6 by the way. Very Clean. Good luck with the problem. God knows I've had my share of issues with my B6.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Seriously, this is like the third thread about the same problem - different users. Did you recently go through a car wash or a hard rain?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Jul 10 2007
    trunk
    Quote Originally Posted by MikeWire View Post
    rain can cause that too?
    Stage 0 minus - .5
    Apr 21 2009
    yes
    Mar 08 2007
    Air and water
    SATX
    In one of the other threads, the OP found that his ECU cover was not sealed and water got into the bottom area of the ECU box and shorted a few things. I think the fix was to dry the area out and seal it up.
    The other thread I was referring to was an auto car wash incident - the OP found that an ABS or some other sensor had been disconnected and threw a MIL.
    So, maybe check those couple of things and let us know. :)
    -Mike
    @countdowngarage
