Results 1 to 12 of 12
    Dec 11 2008
    '05 Avant Ultrasport; '97 Jeep
    Right Rear Wheel Squeak
    My rear suspension in my Avant is not quite stiff enough or high enough to take a 4 passenger + luggage load without scraping the tires on the wheel wells whenever hitting slight bumps.
    After a couple hundred miles of driving like this, my right rear wheel squeaks intermittently. Most of the time it will squeak when going straight or turning left, and almost always doesn't squeak when turning right.
    Anyone have an idea of what may have caused this?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Right Rear Wheel Squeak
    Sounds like a bad wheel bearing. Does it squeak when braking as well, or do you think you might have blown a shock?
    Senior Member Two Rings mlchael4's Avatar
    Jan 12 2009
    '02 A4 1.8t Sport Package
    West Burbs, IL
    Is it a squeaking noise..or a grinding noise?
    My car makes a slight squeak or whoosh of air when it hits bumps. (I think that’s normal shock operation)
    Mike
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by UltrasportFreak View Post
    With that little piece of information I would GUESS that it is likely a wheel bearing. That is how my rears failed. Only thing I think is different is that it is not a squeak it is more of a grinding/squealing noise that comes and goes till it doesn't go away and makes it too loud to talk on a phone while driving. Then there is always the possibility of the wheel bearing itself just exploding.
    Now I have a front one on the way out now too @ 105k
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 28 2008
    Northern NJ
    Quote Originally Posted by A4SoftWalker View Post
    I have the same issue I thought it was my brakes.. Cause it happend only when breaking at slow speeds but this sounds more likely. Any website sell Wheel Bearings for cheap.
    Things I am selling just PM me
    - RS4 Pedals (Automatic)
    - USP Lower Valence
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by Retard Riot View Post
    I found this one yesterday MJM Autohaus OEM Front Wheel Bearing.
    Thinking of ordering from them or ECS Tuning... Tonite
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Dec 11 2008
    Strangely enough, today, after letting the car sit for almost 24 hours, I had no squeaking whatsoever. It was almost as if have the suspension so low with a full car and grinding the tire on the wheel well caused some friction somewhere else, but over time, the friction was released and was running fine.
    Is it possible to get stiffer or raised suspension? I'm sure it is, but I have heard from a few different Avant people that they have the same problem, so that's what makes me question it...
    May 13 2008
    NoCal - EBay
    When I had my 16mm spacers on the rear (17 x 8 35mm offset 235/45R17) with my Hotchkis swaybar my rubbing stopped. So that might help stiffen up the rear suspension compression a bit.
    Just a suggestion...
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Make sure it's not that friggin rear seat latch. Pretty damn squeaky
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    This same sort of thing happened to my gf's car. It was her left rear wheel. It just ended up being that her rear brake pad was so worn that a little piece of metal that stuck up was grinding. It didn't trigger any brake wear sensor or anything either. But it was really loud when she went in reverse, and was like a high pitched squealing sound going forward that you could barely hear unless on the freeway. Didn't sound like any noise i've ever heard brakes make, especially because it was constant and not just when brakes were applied.
    - Justin -
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Would a bad wheel bearing cause a vibration??
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Dec 11 2008
    Quote Originally Posted by manhertm View Post
    No it was definitely outside on the rear wheel, I had my passengers stick their head out the window while it was occuring. I cant figure out what it would be, cause I drove 500 miles with it squeeking, so I would be very surprised if it had something to do with something being stuck to the brake pad or something of that sort. I kind of want to get a bunch of people in there again and see if it happens again...
